My JVC TV recently began getting a batch of thin white/clear horizontal lines at the top 1/5 of the screen. The bottom-most line is more solid white and its length varies by constantly moving (a busy side-to-side blinking...). Months ago, I noticed a slight rainbow-colored patch in the top left corner of the screen. Eventually, it went away. When this batch of lines appeared, it would only be when I first turned the TV on. After a few minutes the line would disappear. I made sure I moved everything that could produce electrical static interference away from the TV. No improvement... It's always been plugged into a surge protector. I paid $219 for it apprx.8 years ago. Not looking to pay almost triple for a new LCD/HD/Flatscreen TV. However equally not sure if I can learn how to open it up and do surgery. Don't most repair shops charge 200 deposit anyway? What does it normally cost to fix my problem?Sorry... Here was my post. It got cut off.
You can't post conmments that contain an email address.
your JVC needs an electrolytic capacitor replaced in the vertical circuit; if you don't know someone who knows electronics then i would phone several repair shops and get a quote to do repair. Shouldn't take more than 1/2 hour and part not expensive.your JVC needs an electrolytic capacitor replaced in the vertical circuit; if you don't know someone who knows electronics then i would phone several repair shops and get a quote to do repair. Shouldn't take more than 1/2 hour and part not expensive.
You can add horizontal lines in Word 2007 document quickly without having to use the ribbon on the top of the page. A very easy way to add horizontal lines in Word 2007 quickly is by using the keyboard shortcuts. This method will save your time. You will be able to insert lines of many different designs by using the keyboard and not having to use the mouse at all. In order to add horizontal lines in Word 2007 document quickly, you can use one of the following procedures: 1.If you want to add a simple straight line, type three dashes (---) and press Enter on the keyboard.
2.For this style of a horizontal line, type three asterisks (***) and press Enter. ...........................................................................................................
3.Type three underscores ( ___ ) and press Enter to get this line: _____________________________________________________________
4.Type three equal signs (===) and hit Enter to get this line.
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
CNETI'm experiencing thin black lines from the top of the screen to the bottom. ... by babes808gpa / January 15, 2010 1:42 AM PST ... lines are about 1/4 inch apart from top to bottom of screen. starts on the right and about a 1/3 of the way toward the ...have the exact same problem, my lcd tv has multiple lines are horizontal it ...
? 3:05
https://www.youtube.com/watch?v=KiqJuMiEiak
Jun 8, 2013 - Uploaded by Sameh Moustafa
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the picture SOLVED .... I just have one black line ...
? 2:49
https://www.youtube.com/watch?v=h4XWCxUsSVU
Sep 2, 2014 - Uploaded by ShopJimmy.com
I have thin horizontal black lines on the top and bottom areas of my TV. .... Hi, I have a 2011 64-inch 3D Samsung PN64D8000 Plasma TV.
? 4:52
https://www.youtube.com/watch?v=k2QpYJp6MU8
Apr 12, 2014 - Uploaded by cr4zyw3ld3r
Hi my LG 47ln5700 tv set has thin greyish black horizontal lineson one side of the .... I hope this works good with Samsung LCD as well....
Your printer head - the ink cartridge in case of most HP deskjet printes, in most cases is defective and you need to replace it to have a clean print.
Anyway, read this tutorial, has some good tips:
Horizontal line WITH SOUND is only vertical output stage problem.horizontal line without sound is osc problem.So kindly verfy that.If h line with sound then
check vertical ic and ver supply voltage.
Due to vertical section failure horizontal line apprears. You did not mention about picture. Green horizontal line means with picture or without picture. With picture means there is some leakage. Without picture only singe horizontal line means vertical section totally not working. Particularly green horizontal line means maybe leads to jungle ic failure. Please mention your simptom clearly what you get and what you will not get both video and audio. It will be helpful to answer. Based on your question this is my small information.
causing of horizontal lines is leaky or defective capacitors. check big value capacitors around the board at Horizontal area. check the filter capacitor as well. good luck
