After powering on my Lexicon DC-1, I heard cracking sound and saw smoke with distinctive burnt odor coming out from the unit.
Previous to this, I heard on two occasions loud sound coming out from the unit when powered up.
Any suggestion on how to resolve the problem will be much appreciated.
You need to replace the whole unit. A motor which smokes when you are using it means the motor is burnt out or you are putting too much pressure on it making it work too hard. I have a feeling it's burnt out. I don't think you can repair it.
Easy answer: You DON'T set the polarity because this particular device takes a 9 VAC at 2.1 amp adapter. (Not a DC one like so called universal ones)
It sounds like you have one of those universal adapters which probably would not deliver the 2.1 amps required even if the lexicon took DC. Note that stuff might light up, but the unit will not work using a DC adapter..
You had better get an official power supply for this unit as what you have will NOT work, period!
I did a quick search to try and find a link to a supplier, but they are RARE !!! Every one I found would require you changing the plug to match the Lexicon.
You should just order the correct one from Lexicon.
Are you sure it's smoke? It could be condensation.
It seems to me that smoke would have a distinctive odor. Condensation would not. Some vehicles produce visible condensation from the vents when the weather is humid. This would not necessarily indicate a problem with the AC system.
In the event of a power outage, the RV-8 will display a BROWN
OUT!! PRESS STANDBY message. To turn the unit on, use the
STANDBY button. For more information, see “POWER
MANAGEMENT” on page 3-3....
POWER MANAGEMENT ON, OFF
"Setup" >> "Power Management"
Opens the POWER MANAGEMENT menu, which is used to automatically
put the RV-8 into standby mode during brownouts.
When set to ON, the RV-8 detects low voltage levels or a momentary
loss of power and puts the device in standby mode. In the event of a
power brown out, the RV-8 will display a BROWN OUT!! PRESS
STANDBY message. To turn the unit back on, use the front panel
STANDYBY button.
When set to OFF, the RV-8 will attempt to function during a
momentary power loss, however software settings may become
corrupt and need to be reset.
When the RV-8 is in standby mode, pressing the button turns the
unit on and activates all zones that were active in the previous
operating session.
The RV-8 does not power on.
1. Make sure the rear-panel power switch is set to the | (“on”)
position.
2. Attempt to power on the RV-8 with the front-panel Standby button and remote control On button.
3. Examine the power cord to ensure a good connection between
the rear-panel AC input connector and the wall outlet.
4. Check the electrical circuit and breaker.
DC-1, DC-2 an MC-1s have the same power supply. The power supply usually lasts about 5 years before it goes. A New power supply is usually about $ 65.00. There is usually a $300.00 LABOR FEE. Check out THE SERVICE BENCH in MA. Phone number is 781-769-4338.
