Question about E-Machines eMachines Desktop PC
T2085 will not turn on
I have an EMachine T2085, I've had it for at least 3 years with no problems. It was working fine this morning, no power surge or outage happened.
This evening it will not turn on at all. The power light does not come on, no fan noise... nothing... completely dead.
I've read some of the other posts and looks like it might be a power supply issue?
What are recommendations... ? And just how difficult is it for me to replace power supply myself?
  • 1 more comment
  • Marie2008 May 09, 2008
    Thanks for the links... yes, I've tried changing outlets and testing the one plugged into... no power button on back of tower.
    Luckily I still have access to my laptop and my wireless network...
    My main concern is that I have files on my desktop that I absolutely need to access.
    Do you have a link to tell me which power supply to purchase and motherboard if that needs to be replaced? I want to be sure of getting the right supplies to get it up and running again.
    It's an EMachine T2885... I made a mistake in my original post.
    Thanks!
    Thanks everyone, as you can tell, I'm very new to this...
    dave117 if you could point me in the right direction with a link...
    it sounds like right now the external USB housing for the drive sounds like the best idea.
    My laptop is a Toshiba Satellite a215-s5825, so I'm not sure what would be compatible... actually not even sure where to begin.
    Thanks for your help and patience : )
  • quinton_garr Apr 08, 2009
    i opened the hard drive and took out the battery and put it back in know the hard drive will come on and wont go back off and notyhing is showing on the monitor
    Problem Solver:
  • 5 Answers
Replacing a power supply is a rather simple affair. Just make sure that the new one purchased has the correct power connectors for your computer. The motherboard will probably have either a 20 or 24-pin connector. Many new power supplies will work with both of these connectors.
Put on your anti-static wrist strap, unplug the power and open the case. The power supply will be connected to the motherboard in at least 2 places and to various other components (CD/DVD drives, hard drives, etc.) disconnect these wires from the everything.
The power supply is most likely connected to the computer's case by 4 phillips head screws. Unscrew these from the back of the computer case and remove the old power supply. Be careful because the power supply may be hanging a centimeter over the case and may fall when unscrewed.
Line up the new power supply with the screw holes on the case and screw the screws in from the outside of the case. Do the top screws first, it will be easier. After that, connect the 20 or 24 pin power connector to the motherboard. Connect the 4-pin processor connector and any other devices (CD/DVD, Hard drive, case fans, etc).
Close up the system and plug it back in. Some power supplies have a switch, make sure its in the on position and power up your system. That's all it takes.
Posted on Jul 10, 2008
Posted on May 09, 2008
    Scholar:
  • 35 Answers
If you are looking to order the "correct" parts then you could locate them at this link
http://bestbuy.partsearch.com/Model/Gateway/E-Machines/T2885.aspx
What you might try instead is buying a power supply from a retail store that doesn't charge a restock fee (according to that link it is a standard ATX power supply and judging from the specs I would say it would be a 20 + 4 Pin type) and once you have purchased the power supply you could hook it up and see if this is the only thing causing the problem. If it is not, then return the power supply for a full refund. If it is the motherboard, buying the original motherboard for that unit could be more expensive then buying a new computer. Keep in mind, you could buy a motherboard that matches the specs for your machine but isn't the type that originally came with your computer for less, however you would then need to purchase a new copy of windows.
    Genius:
  • 1,027 Answers
  • Mark Williams
    Mark Williams May 09, 2008
  • Mark Williams
    Mark Williams May 10, 2008
    Don't know about where you are but our local Radio Shacks (3) have an external usb case for hard drives for $19.95
    Novelist:
    Scholar:
  • 134 Answers
Obviously you have tried change of power cord, move the pc to another power outlet or test the one you are plugged into with a desk lamp or hair drier or whatever.. Also, some pc's have an on/off switch at the back of the box, especially if it's a tower pc, check that first.
Now, do you have access to another PC? Because it's easier to check this web site out, to see how to replace the power supply.. If not, post here for more help. Rgds,
http://www.hardwaresecrets.com/article/362
or
http://www.associatedcontent.com/video/2917/how_to_change_or_install_a_power_supply.html
Hope it helps, Rgds.
  • Dave117
    Dave117 May 09, 2008
    This may not be the soluton you need, but if you are desperate for the files on the hard drive it may pay to get an extenal usb housing and mount the hard drive in that, as a temp. solution. that way, you will have access to your data. Looks like 'mewms_14904' has sorted the power supply issue.. One thing to keep in mind, if you need to replace the motherboard, it may not be a trivial thing. I mean, it's not uncommon to have problems getting the same kind of motherboard, then the RAM &/or CPU might not fit etc, etc. Also, changing over the CPU can be quite tricky and needs to be done with caution. Anyway, hope it works out. Rgds,
  • Dave117
    Yes, the external HD shud be ok for your laptop..
    Here is a link to how to put your hard drive into the housing. Actually, they make it look a bit harder than it really is.. But have a look & if you have questions, just post them..
    http://www.connectworld.net/cis/external..." target="_blank" rel="nofollow" http://images.google.com.au/imgres?imgur...
    There are so many different brands of housings.. You can buy them without hard drives for around $40 to $90.. Depends on where you shop. The best stratagy might be to remove the hard drive from your existing PC & take it to a computer store & ask them to install it. Might be the quickest & most painless way..
    If you do that, carry the hard drive in an anti static bag (if possible), not a plastic bag. Don't want to damage it. Remember, you will need to get a 5.25" drive housing, not a 3.5".. The 3.5" is for laptop hard drives. Once the hard drive is in the housing, you should be able to just plug in the USB cable to your laptop & get your files. Rgds,
Gateway ZX4300 - power adapter problem
Verify all specifications of your previous charger and new chargers/adaptors.
Jun 24, 2013 | Computers & Internet
My JVC flat screen won't turn on, tried unplugging and resetting. Stand-by light is still on. And it's attached to a surge protector than to the wall. I've only had this for 1 year.
More than likely its bad capacitors on the Power supply very common problem with most models. You can get repair kits or replacement power boards from www.tvrepairworld.com
Dec 09, 2012 | JVC LT-42X579 42 in. LCD TV
My emachine EL1352G-41W wont turn on?
Power supply is most likely your problem--many desktops with this issue have before it happens an issue where it has to be turned on several times and will finally come on and stay on.
The power supply in most cases is a unit that can be removed and tested (most shops charge little or nothing for this.)
If you are able to get it out look for bad filter caps on that board--some examples:
If puffy caps are found you have two choices---replace them all or if possible buy a generic power supply replacement............
Jun 11, 2012 | Computers & Internet
Just curious, I have an Emachine T2085 and was wondering what the larget processor you can put in the stock motherboard
It is a socket A motherboard, so any processor for it will be ancient. In reality, it might be cheaper or not that much more (old parts get expensive, in fact, newegg lists no socket A procs) to replace the motherboard, ram, and processor with something more modern that will give you more kick.
Jul 24, 2011 | E-Machines T2085 PC Desktop
Dynex Te685avr backup battery doesnt work
If the battery outlets do not work, typically the Dynex TE685AVR UPS (battery backup) just needs a new battery. These batteries usually last 3-5 years.
The model of the battery is a WKA12-7.5F2 and can be purchased at: http://www.replacementupsbattery.com/Product_pages/wka12-75f2.html.
Jun 26, 2008 | Dynex (TE685AVR) UPS System
it does sound like a power supply. you can pick one up for around 80 bucks retail. they aren't that hard to install. 2 plugs on the mobo and one for each drive you have installed. all you do is unscrew the current power supply (4 screws on the back), then unplug all wires connecting the power supply to the components. then take out the old power supply and work in reverse with the new power supply.
if the computer doesn't work after that, it is possible that you need a new mother board. in that case, personally i would return the power supply and start looking for another computer.
but hopefully it is just the power supply.
Agent 10708
May 29, 2008 | E-Machines eMachines Desktop PC
Canon PIXMA MPA830 power loss
I had a similar problem after a power surge. But when I left it unplugged for 10 minutes and then plugged it back in it powered up just fine.
May 21, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Envision EN7410e monitor
Just fixed mine. Maybe it's a few years late. Hope you guys still have the display. It's the power supply board. I've just replaced 4 bulge capacitors near one edge of the PS. They are 2x1000uF 10V, 1x470uF 25V & 1x470 10V. I salvaged my parts from an old CRT monitor. Hey you can go green with your repairs too!
Apr 25, 2008 | Envision EN7410 17" LCD Monitor
Emachine with XP home edition doesn't start
Hi hearalso, down to the basic's. Replace power cord.
No help there than, remove the case's side panel to expose the motherboard. (Normally it is the left side panel while facing the front of the PC.)
Look closely for a small (green in color) led light. The power cord must be connected to the PC & connected to you're power strip but do not press the power on button on the PC.
The green led tell's you the board is receiving 5volts. Check all connections. Un-plug & reconnect every data & power connector in your PC. (Double check). There is a fuse inside your power supply that may have blown. Check you're manual page, Approva Statements B-1. Fuse Warning Instruction Caution.
Check fuse in power supply. (Unplug power cord before opening).
If you can not power up the PC after all of the above than if possible, swap out the power supply.
Replacing the power supply is the last step.
If you have more questions, feel free to ask.
Good Luck!
Mike
Apr 09, 2008 | E-Machines eMachines Desktop PC
E-Machines eMachines Desktop PC Logo
164 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
