Need rubbon cable youngshin 20861 60V 105C VW-1 tank's
2 Suggested Answers
SOURCE: cvilux e208903 awm20706 105c 60v vw-1 looking
cctv
Posted on Jan 28, 2013
I need to drain all of the fuel out of my 2000 VW Beetle. What is the easiest way to do this? I suspect the fuel has gone bad as it has been in the gas tank over 1 year. The car will not idol correctly...
add some sea foam to the tank with a bottle of octain( found at all part stores. then let it sit for a few hour. next run the tank almost empty, replace the fuel filter if accessible then top the tank off with new fuel. no real need to drop the tank and empty it,
Sep 27, 2013 | 2000 Volkswagen Beetle
Which model of Inverter Board does HP pavilion f1503 uses? My backlight keeps on dimming after 10 secs of start up. please be spefic with the model number
The part is a "ribbon cable" for an lcd monitor...ribbon made by Youngshin (AWM 2896 30V 80C VW-1).
2 ribbon cables for a hp pavilion f1503 LCD monitor (the two from the AD board to the TCP)
The LCD panel is made by HannStar (HSD150SX84).
Also, looking for other LCD parts, particularly:
the AD board for a Proview Pro-576 (I assume Sylvania PL-576 & Mag LT576s are similar); Board #: 200-100-AS576 Rev: B MV5-S2?
It uses a sampo inverter (QPWBGL8621DG) & a AU Optronics M150XN05 LCD.
Jun 20, 2012 | HP Pavilion F1503 15" LCD Flat Panel...
I need a diagram to replace a fuel tank on a 1987 vw cabriolet
1987 Volkswagen Cabriolet 1.8L FI SOHC 4cyl
1985-89 Scirocco and Cabriolet
  1. Disconnect the negative battery cable and drain the fuel tank.
  2. Remove the rear right wheel housing cover.
  3. Disconnect the large breather hose from the filler neck.
  4. Pull the gravity valve down leaving the hoses connected.
  5. Unbolt the fuel pump bracket from the body and lower the pump.
  6. Remove the fuel tank screw.
  7. Disconnect the fuel pump hose and pull the blue hose from the return line.
  8. Disconnect the brake hoses from both sides of the rear axle and plug them.
  9. Disconnect the rear axle from both sides of the body and allow it to swing down and rest on the handbrake cable guides.
  10. Unhook the rear muffler support lugs.
  11. Disconnect the filler hose from the tank.
  12. Support the tank, remove the tank fasteners and lower the tank enough to disconnect the fuel gauge sending unit wires and breather hoses.
  13. Remove the fuel tank.
To install:
If installing a new or used tank, make note of where the old foam strips were installed, and install new foam strips on the replacement tank in the same locations.
  1. Raise and support tank. Connect the small breather hoses and fuel gauge sending unit wires. Install the tank fasteners.
When connecting the breather hoses, position the hose clips so that they do not make contact with the body.
  1. Connect the filler hose to the tank and connect the rear muffler support lugs.
  2. Raise the rear axle off the handbrake cable guides and install.
  3. Connect the brake hoses and bleed the brakes.
  4. Connect the return line and fuel pump hose.
  5. Install the fuel tank screw.
  6. Raise the fuel pump and attach the fuel pump bracket to the body.
  7. Put the gravity valve back into its original (raised) position.
  8. Connect the large breather hose to the filler neck.
When connecting the breather hose, position the hose clip so that it does not make contact with the body.
  1. Install the right rear wheel housing cover.
  2. Fill the tank and connect the negative battery cable.
Fig. 1: Fuel tank assembly used on the Rabbit Pick-up. Other models are similar
Hope helps (remember to rate and comment this).
Sep 21, 2010 | Volkswagen Cabriolet Cars & Trucks
Vw polo 1 litre has idling problems it keeps reving to around 800 rpm then droping to around 400/500 all the time engine being cold or warm makes no difference. It's a w reg with 50000 miles
im also havin a problm with 99 polo 1.6 it revs high low high low and if da tank is below 1/4 it dies of while driving iv changed tank unit,trottle body, sensor nd after i changd tank unit da foat reads opsite way sum1 plz help me
May 20, 2010 | Cars & Trucks
Cvilux e208903 awm20706 105c 60v vw-1 looking
cannot play H.264 video clips stored on my flashdrive
Sep 04, 2009 | Sharp Televison & Video
Same as you!
there is a release cable in trunk go through back seat pull trunk release then with light you should see gas tank release cable
Jul 22, 2009 | 2005 Volkswagen Jetta
Dell 1600N MF Laser Printer- Blank vertical strip on all prints
you need do follow steps:
1) take out the cartridge find a cover there is the drum inside, the drum you can see the color on the drum surface
2) check out and clean any pieces of paper or dirty waste toner stuck there, because there is a waste toner cleaner on the drum surface which is like a long rubbon strip (something like that) you can spin anyway a little to clean.
3) if you check out any different color (vertical round drum), that is the drum surface worn or scratched. you can see the worn area show light color than normal area.
so you need change it better. 4) if the color all very same and still not fix, you need check again something stuck the drum surface near cleaner rubbon.
hope help you fix it, please take a rating let me know how much helped you thanks! keep in touch your question please.
May 21, 2009 | Dell 1600n All-In-One Laser Printer
Samsung Ulta Q1
stylus is controlled by the softwares , sensors are working fine in the pc . software problem is mpre likely then a hardware , try re-installing the OS , if it doesnt work the only you refer the company people (the manufacturers)
Nov 06, 2007 | Samsung Q1 Tablet PC
Televison & Video Logo
154 people viewed this question
Top Televison & Video Experts
Electro Med Services...
