Question about Eclipse CD2000 CD Player
Eclipse cd2000 car stereo
I had a tune up done on my car and they unhooked the battery cables. Now my stereo will not turn off, or let me do anything like it is locked up. what can i do?
  • Anonymous Nov 15, 2008
    Unhooked and reconnected battery cables and the screen flashes "all off" or "CD" and reset button doesn't help.
  • 138 Answers
Does it have a reset button or switch.. usually found on the underside of the face plate
Posted on May 09, 2008
How do i dismantle dash-board
Some vehicles may require taking the steering column out, but start by taking covers under the dash off just about anything that you can visualize that has a screw, be sure to unhook the battery cables just so you don't set off anything,unhook airbags when you get to them,take some pictures if you have a phone it will help you to remember, but i would. Only. Take off what is needed to get the job done
Nov 02, 2015 | 1998 Mercury Grand Marquis
No security code audio system
These units do not have a security code like some radios. Instead, they are coded using a CD. You insert a CD into the radio and it codes to that disc. You need that same CD if you ever want to unlock the player. If you don't have it, you are SOL. Eclipse is no longer in business and they were the only ones that could reset it. The system is known as "ESN Security".
ESN Security: This unit is equipped with the Eclipse Security Network. You can register a particular music CD as a "key" device which unlocks the security. If the registered CD is not detected, the navigation and audio functions will be disabled when the main unit is disconnected from and reconnected to the vehicle's battery.
Dec 16, 2013 | Eclipse CD2000 CD Player
How do I reset the computer in my dodge magnum 2007
Proper way is with code scanner with erase capability. Or you can try to unhook your battery and turn on the headlights, wait about 5 min. then reconnect battery. If you have stereo with code lock make sure to have code before doing.
Oct 17, 2013 | 2005 Dodge Magnum
2008 Mitsubishi eclipse radio not working after battery change
Unfortunately in newer vehicles, they sometimes need to have the computer re-flashed IF you unhook the battery with the radio on. It's a crummy deal. The dealership will probably have to re-flash the computer. You could try turning the stereo off, then disconnect the cables on the battery for a minute, then re-connect and POSSIBLY it could reset the system and it may work again. Don't get your hopes up, this may not fix it.
Nov 11, 2012 | 2008 Mitsubishi Eclipse GT
How do you remove a steering wheel on a 1993 Cadillac Sedan Deville?
remove the cover screws located at the back of the steering wheel, in the recessed holes, CAUTION: before doing anything with the steering section of your car ,, unhook the NEGITIVE battery cable first , then unhook the positive and wait 10 minutes before doing anything else,, this will allow the air bag system to discharge. when your done with your repairs, Hook it back up in the reverse order,,
Aug 31, 2011 | 1993 Cadillac DeVille
Mitsubishi Eclipse Spider Gt-S I cannot figure out how to get the fascia panel and face plate off of the radio to get to the numbers needed to retrieve the radio code. How do I take the panels OFF?
Hi
The stereo in the Eclipse can be removed with nothing more than a Phillips screwdriver
Disconnect the negative battery cable from your Eclipse's battery. Remove the two Phillips screws along the bottom of the radio/climate control trim panel. Lift up the bottom of the trim panel to unlock the lower retaining clips. Work your fingers around the sides of the panel to loosen the other clips and remove the panel. Remove the four Phillips screws holding the stereo in place. Slide the stereo out of the dashboard and disconnect the wiring harness and antenna cable from the back of the device.
Also check this link if it helps:-
http://www.ehow.com/how_5938157_remove-eclipse-car-radio.html
May 04, 2011 | Mitsubishi Car Audio & Video
I have a Ford Escape 2008 model - after a service, we received the car back with the CD/Stereo player locked. The Ford dealership are unable at this stage to provide me a code for the unlocking of the...
yeah they should be able to unlock the stero /unhooking battery without retreiving codes will lock up stereo . i would tell them get codes or get new stereo
Nov 05, 2010 | 2008 Ford Escape
Mitsubishi Eclipse Spyder 2001 what fuse for the power windows part #
I've been messing with the stereo and took the seats out to check the amp. I don't think I disconnected the negative cable on the battery and now the windows won't do anything and the top won't go up or down. What did I screw up?
Sep 17, 2010 | 2001 Mitsubishi Eclipse Spyder
Eclipse CD2000 CD Player Logo
312 people viewed this question
Top Eclipse Car Audio & Video Experts
xxxxxx xxx
Are you an Eclipse Car Audio and Video Expert? Answer questions, earn points and help others
