Question about Health & Beauty
Dear Team, itook the multistyler recently I,am trying to staighten my hair the moment i straighten it will be staright but the next few hours it be the same as earlier my hair was.Kindly suggest.
  • 17,130 Answers
Hi, Just my dear advice that the straightening of the hair happens perfectly only with the correct heat and applied pressure. If you can get this to your hair styler, he could demonstate the best way or can comment on the efficiency of the product.
Must see if the heat is enough or the positioning is correct,
Posted on Aug 31, 2010
Testimonial: "thank you for your good feedback.must be this was the first time i was using so i feel i have not done it preoperly."
How to fix your curly hair?
shampoo and condition with a hydrating formula. Towel dry, and apply a curl defining cream. Let hair air dry. Apply a few drops of argon oil to ends
Mar 02, 2015 | Sexy Hair Health & Beauty
Does anyone have any good tips for straightening hair? I am new to this.
1. Make sure your hair is dry
2. Use oils
3. Prep the flat iron at the right temperature
4. Straighten your hair with your overall style goal in mind
5. Brush don't comb!
6. Add volume
rehost_2016_9_13_0dc297ae-7caf-4215-b998-71d5ca0093eb-fblmica31ak52inb20judn4s-3-0.jpg
Feb 20, 2013 | Health & Beauty
I have really curly hair and I love using the iron to straighten it when I go out, but I find that within an hour it is starting to get curly again. What can I do about it?
Have you tried using a serum? Put a bit on before you start straightening and then a bit more after. You can even take it with you in your bag when you go out. It should help to control the frizz problem a bit. But steer clear of your roots or you will just end up looking greasy.
Where do I find a rear drum bearing and seal?
From the ApplianceJunk.com Forum:
Duet washer started getting louder and louder during the spin cycle. When I manually turned the basket I could feel that the bearings were shot. A quick search of the internet confirmed that this problem was no fluke. I found an illustrated parts breakdown of my washer online, and saw that Whirlpool only offers a replacement rear tub assembly, at a cost of $408. Needless to say, I was peeved. I paid about $960 two years ago for this machine, and now it will require $6-700 in repairs. Unacceptable. So, having a mechanical background, I started to tear into the machine myself. I tore it all the way down to the rear tub half. I found what appeared to be the problem with my machine, hair. Hair worked its way to the bearing area, slowed unseated the seal, and then acted as a conduit for water to enter the bearing cavity. The seal itself actually looked fine. Yet the steel hub that the bearings are pressed into was badly corroded, as were the bearings, and even the driveshaft had corrosion on it. I pounded out the cheap factory bearings, cleaned up the bearing cavity and driveshaft, and replaced them with some higher quality Toyo's from my local bearings and drive store, P/N's 6206ZZC3 & 6205ZZC3. Unfortunately they didnt have a suitable replacement seal in stock. I didnt damage the factory one too badly upon removal, so I straightened it up with a couple of hammer taps, made sure it sealed nicely against the driveshaft, and reused it. The new bearings cost me $20. I made sure I sent a nastygram to Whirlpool, they offered me a replacement rear tub for 50% off, I told them to stick it. Hopefully I get at least 3 more years out of it, I've already started looking for my next machine, I'm likely going to buy a SpeedQueen. Anyways, if your tub bearings are shot and you have the will, they can be replaced yourself for a fraction of the cost of a factory rear tub half. My advice, take notes during disassembly, keep all the hardware from the different components you remove separated from one another. Dont be afraid to use permanent marker to write reminders directly on the components as theyll be hidden inside the reassembled washer when done. I did the repairs by myself, having a helper wouldve made things much easier. As for tools, I was shocked at how few I actually needed. A nut driver or torx apex, a 1/2" socket and rachet, some slip joint pliers, a wrench to remove the drive pulley, and a hammer and punch to remove/install the bearings.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 28, 2011 | Kenmore 45087 Front Load Washer
Hi my hair straitnes have stopped working, one min they was on and the next they went off please help
dear pauls prince if you spoil the quality of your hair, please treat them carefully and cautiously,do not use any straighteners,your hair is so elegant and I'm sure.Use different balms for hair care.And I wish you the very best
Jun 03, 2011 | Remington S6500 Sleek and Curl Ceramic...
How do you use a conair straightener? what does the dial with the numbers mean?
The settings 1-10 are for wet and easy-to straighten hair. Like hair that is a little thinner or almost straight.
The settings 11-17 are for damp hair that is about average thickness.
The settings 18-23 are for hair that is thick or wavy.
Lastly, the settings 24-30 are for dry hair that is harder to straighten.
So, the higher up you go, the higher the difficulty the hair is.
Hope this helps! :]
May 31, 2011 | Conair Health & Beauty
I need directions on how to use the Revlon ceramic Straightener model RVST2024
I love my hair straightener. It doubles for a clean modern straight look to sexy voluptuousness Kim Kardashian curls without going to the salon. If you do it right your hair will look professional and feel so soft.
1. Clean and Wash Hair: I always like to have clean hair before I style it, it isn't necessary but it makes me feel more refreshed.
2. Make sure your hair is dry. I prefer to air dry because it is the healthiest way to not damage your hair. But if you want to get more volume, using the blow dryer works well.
3. Before using any straightener make sure you get heat protector gel or spray because this will help make sure your hair does not become damaged when styling.
4. I like to split my hair up into sections to get them out of the way by using hair ties or hair clips. Sectioning your hair also helps a lot of if you have specific styles you are going for.
5. Finally, do not turn on the straightener too high because it's a sure way to damage your hair. Instead, consider low-med. If it's your first time, don't rush it because you will get burned. Give yourself an hour or more! Learning how to do it the first time can be frustrating and it doesn't always look great the first time. With some practice you can also create curls with a straightener as well.
Other tips: They have specific wet-dry straightener which can be used on wet hair but unless you have those, do not use the straightener with your wet hair because it'll give you split ends and damage your hair.
Here are some more tips for straightening that might be useful for you.
Dec 18, 2010 | Health & Beauty
My hair straighteners will not come on. I have changed the fuse and this made no difference
see that happened to me u just have to thro it away and get a new one trust me it wont work again 3 of my family memeber r butician hair ppl or whatever salonist wehatevea u wanna call them so i get free straightener hair dryers and stuff so i dont have to worry :)
Dec 20, 2008 | Conair Professional Ceramic Hair...
Health & Beauty Logo
50 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
