Question about Hoover Refrigerators
Freezer not making ice - Hoover Refrigerators
  • Hoover Master
  • 17,130 Answers
Must start from either a faulty compressor or a gas leak. So put off fridge to cool off then switch on , If there is no cooling in about 2 hours, the compressor or the gas pumping is down provided there is gas in the system. So if the compressor is working warm, please take help to get the compressor pumping or the gas checked so as to confirm. Then estimate and decide.
Posted on Aug 31, 2010
Is it an icemaker? Either the water valve is bad or the freezer isn't cold enough or the ice maker is bad. Is it just a ice cube tray? Then it's not cold enough.
Aug 25, 2016 | Samsung RSH1DTMH American Style Silver 524...
How do i get the ice maker to make more ice?
Set freezer temp to lowest number, use "ice plus" feature. (it goes back to non-ice plus after about a day on it's own though) Dump excess ice into freezer storage bin if it gets full to keep it making more ice if needed.
Sep 25, 2010 | LG LRFD22850 Bottom Freezer Refrigerator...
Can a chest freezer make an ice for 16 hours?
yes sit can make a ice . just increase the temperature thermostat to maximum
Feb 18, 2010 | Bosch 8.72 cu. ft. / 247 liter Chest...
Jenn-Air bottom freezer ice maker not working
I took the arm of the ice-making machine out of the slot and put it back in, pushing it snugly inside the slot, then raised and lowered it several times. Then, with the arm in the up (stop making ice) position, I felt inside the ice-making tray, where I noted there were ice cubes as well as a sheet of ice at the base of the ice-making tray. I poured approximately 24 oz. of hot tap water into the tray to melt the sheet of ice. I turned the freezer temp control to "warmer". I think the freezer temp setting was too cold, causing the ice maker to freeze the water before it could make cubes. I have a working ice maker again!
Cynthia
Sep 07, 2009 | Jenn-Air JFC2089H Bottom Freezer French...
Ge monogram bottom freezer ice maker spills ice
It takes weeks for ice to dissipate in a freezer.
You may can adjust your cut off lights or wire cut off to cut off before it's so full.
Jul 01, 2009 | GE Monogram ZICS360NRRH C... Bottom...
Frige is cold, freezer is cold & freezing . . . Ice maker not making ICE.
Hi: As we don't (as in I) know the actual temp. in the freezer, this is a simple and free try. Cold is cold. The temp in the freezer has to be 0 degrees to make ice. They are thermally protected. A good guess for temp. is your ice cream. Is it rock hard? A lot of refrigerator thermometers are inaccurate. Just try setting your freezer colder. Ignore human nature and don't check the freezer every 30 Min's. You will never get to 0 degrees. I hope this helps, Jeff
May 31, 2009 | Refrigerators
Bottom freezer "on" but not freezing and not making ice
Refrigerator running but not that cold, freezer running also but not freezing at all. Also not making Ice
May 17, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice maker doesn't make enough ice to supply two senior citizens. This is the 2nd refrigerator we have had installed this month. What can we do to increase the amount of ice it puts out. The ice bin has...
Found in the FAQ section on Samsung.com:
Samsung refrigerator freezers produce about 120 cubes per day, which is in line with most manufacturer specifications.
Empty the ice tray and let the unit run for 24 hours.
If fewer than 50 cubes are produced during the 24-hour test, then your refrigerator requires service. Please contact Samsung Service at 1-800-SAMSUNG to schedule a service appointment.
If your freezer is producing 50 to 90 cubes per day, try the following:
  • Set the freezer temperature display to a lower setting. Freezer temperature must be 5 degrees Fahrenheit or less for the ice maker to work properly.
  • Make sure that the water valve on the refrigerator water supply line is completely open. You can find the water valve where the refrigerator water supply line taps into your house water line.
  • If you have a water filter in your refrigerator, change the filter cartridge. For instructions, see your Users Manual.
If you want your freezer to produce more than 120 ice cubes in a day, try the following:
  • An ice maker typically makes 1 tray of ice every 90 minutes. To shorten the amount of time the freezer takes to produce a tray of ice, set the freezer temperature display to a lower setting.
  • If your refrigerator has a Power Freeze function, press the Power Freeze button to speed up the ice making process. In the Power Freeze mode, both the compressor and the freezer fan run for 10 hours continuously. The ice making interval is reduced from 90 minutes to 55 minutes. If the ice bucket fills in less than 10 hours, Power Freeze stops automatically.
NOTE: If you have just installed your refrigerator, it will take 6 to 12 hours for the refrigerator to produce ice.
You should throw away the first three batches of ice cubes that the ice maker produces (approximately 30 cubes) to ensure the ice maker is making ice from clean water.
Feb 06, 2008 | Samsung RM255LASH Side by Side...
Frigidaire side by side doesn't make ice
If the Temperature in the Freezer is not cold enough, the Ice maker will not make ice. Make sure the freezer is below 10 degrees or so. Zero is where you want it for the best ice production. What was the reason for defrosting in the first place? Should be frost free?
Jan 31, 2008 | Frigidaire FRS3R5EMB Side by Side...
Refrigerators Logo
47 people viewed this question
Top Hoover Refrigerators Experts
Charles T Nevin
Charles T Nevin
Jim Goldsmith
Jim Goldsmith
Are you a Hoover Refrigerator Expert? Answer questions, earn points and help others
