Question about Canon EOS Rebel K2 35mm SLR Camera
Wide angle/fish eye lens
Any suggestions on a good one to get not to expensive i was looking at a .42 or .28  but im new with this camera so advice would be great.  also with this camera is it possible to get additional flashes on the stands and that whole jazz
2 Suggested Answers
Agent Allan
  • 480 Answers
SOURCE: wide angle/fish eye lens
Hey matty reps,
I found one wide angle lens attachment that should work for your camera and I have attached a link to it so you can see what you think. I have little experience with these types of lens attachments, and have heard they're not nearly as good as having a wide angle/fisheye lens that mounts directly to the camera. If you don't mind losing autofocus you can usually find very cheap manual focus lens that are very high quality lenses for sale at some local camera shops. I hope this helps!
http://www.sakar.com/p-105.aspx?categoryid=142
Sincerely,
Allan
Go Ahead. Use Us.
Posted on May 30, 2008
Quantaray f=18mm tech-10 lens for nikon. Is this a fish eye lens?
Technically 16mm and above are considered a wide angle lens, below 16mm is a fish eye. What are you wanting to photograph and what effect are you looking for??
Oct 23, 2013 | Quantaray 50mm f/2.8 AF Tech-10 for Canon...
Tokinka 11-16 dropped in water
Unless you have a lens collimator and other equipment needed to ensure proper alignment when reassembling the lens, take it to a good camera shop and have a properly trained and equipped professional clean it.
Jul 03, 2013 | Tokina AF AT-X 11-16/2.8 Pro DX Ultra Wide...
I have a Nikon D-40 I'm currently using a 55-200
Fisheye is the extreme of a wide angle lens. I think you are not using a fish eye lens, but a fish eye adopter. That is a lens that will "shorten" the focal length of a lens most of the time with 30 % sometimes with 50% when you put it in front of your lens. So you could make a 24 mm lens look or act like a 12 mm.
On your tele lens this only will slightly shorten the 55 mm, but even 50 % of 55 is 27 mm and can't be seen as a fish eye.
I think when you put this on a short lens, the picture you get will be round, like you were using a real fish eye.
Feb 28, 2012 | Nikon Cameras
When I try and use my 72mm .45x wide angle lens there is a warped area in the center of the picture. When I look directly through the lens itself i see it too. Is there a way to fix this
No. It's an optical fault and is either a manufacturing defect or a design flaw.
Such problems are VERY common with ALL no-name brand supplementary screw-on lenses and not entirely uncommon even on branded similar models costing vastly more and intended for a specific make and model of camera.
Supplementary lenses are simply a get-you-by compromise, they will never be anywhere near as good in terms of image quality as a lens designed to be a wide angler or telephoto from the outset but will allow you to capture image which may otherwise be unattainable without a lot of additional expense and equipment.
Jul 05, 2011 | Zeikos ZEWA72B 72mm Wide Angle Lens
Can i change my lens to other lenses like fish eye, wide angle or macro lens or even zoom lens?
This is a fixed lens camera so the short answer is no. However there are third party accessories lenses that can be screwed to the front of the lens to give a "fish eye" or telephoto capability. To get "Macro" there is a kit available which has a series of three close up lenses these lenses screw to the front lens element of your camera allowing for some pretty impressive macro capabilities.
Again to answer your original question no you can't change the lens on your camera
Apr 05, 2011 | Fuji FinePix S9500 Zoom Digital Camera
Someone asked me to take photos with my Nikon D90. I have the 18-105mm lens that I got with it. Is this able to take 'wide angle' photos?? I know there are special lenses made specifically for wide...
The 18-105mm lens at the 18mm end of the zoom range is a pretty fair wide-angle lens. Look through the viewfinder and turn the zoom ring (the big wide ring at the front of the lens) one way and then the other. The 105mm end is the view that looks like you're using binoculars, the 18mm end is the view that looks like you're using binoculars backward.
Oct 28, 2010 | Nikon D90 Digital Camera with 18-105mm...
Hey matty reps,
Sincerely,
Allan
Go Ahead. Use Us.
May 29, 2008 | Canon EOS Rebel K2 35mm SLR Camera
Lens
Have you ever heard the expression "Good, Fast, Cheap ...pick any two" ? Well, it's that situation. The kit lens is cheap, and it has a good zoom range (including wide-angle) but it's not very high quality. The best lens for you is probably the 17-55 EF-S -but it is $1000. It is a great lens, and it's efficient and light sensitive, along with image stabilization. Without knowing your budget, I would also recommend the 28-135 EF IS, but it doesn't cover the wide angle range. That one is $400. There's also the 17-85mm, which also has Image Stabization. That one is about $500.
Aug 09, 2007 | Canon Digital Rebel / EOS-300D Digital...
Wide Angle Lenses
wide angle lens aka fish-eye lens, means only the centre of your photo is clearly focused - especially in long distance scenery shots.
Sep 13, 2005 | Kodak DC290 Zoom Digital Camera
Canon EOS Rebel K2 35mm SLR Camera Logo
16 people viewed this question
Top Canon Photography Experts
old marine
old marine
pontelemon
pontelemon
Are you a Canon Photography Expert? Answer questions, earn points and help others
