Question about Refrigerators
Freezer keeps getting warmer. It's up to 20 degrees. We keep resetting the temp to -6. Help
  • 117 Answers
Ref model number please???
Posted on May 09, 2008
Traulsen G sereis 2 door freezer keeps running past set temp of "0" degrees keeps freezing all the way to -35 degrees and I have to shut it off to keep it from running? any advice??
It basically sounds like the temp sensor is not sensing the box temp that the control functions on. Other wise, the control may be stuck. Traulsen seems to have a fairly descent tech support line. Call them for steps on how to read the controller.
Feb 04, 2014 | Traulsen G-Series G22000 Solid Door...
Refrigerator shuts off at correct temp. but does not turn back on
problem thermostat call a technician to properly diagnose and fix
Apr 10, 2017 | Refrigerators
Temperature warning light keeps going off. Resets
hi brian 20 degrees is too warm for a freezer i think you may have a dirty condensor coil its usualy under the freezer or on the back also check and if it has a fan on the outside make shure its turning let me know what you find and you can e mail me at
Jun 09, 2010 | Kenmore Freezers
Freezer Temp keeps getting too high
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Dec 21, 2009 | GE Freezer  14.8 Cu. Ft. Manual...
Freezer is too cold (-14 degrees) and fridge is too warm (51 degrees). The freezer keeps gettting colder but the fridge part keeps getting warmer.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
The temp sensor for the freezer may be reading the warm air in the fridge so is not cutting the compressor off.
Sep 25, 2009 | GE Profile PDS20MFS Bottom Freezer...
Freezer temp
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} hi!! we have read your problem..every problem has a solution.the temp depends upon your need.if you are using stronly freezers for storing food items like meat, then you can set the temperature to (0-10) degree celsius. else you can set it to (5-15) degrees.always keep the liquid items closed in the refrigerator failing to which it causes also costs dearer since you have to defrost then. so always keep your food items covered.hope your problem is tackled..have a nice day
May 22, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Top mounted freezer on refrigerator not working
Move the refrigerator to a room that is at least 50 degrees F.
Temps on most refrigerators are regulated by the fresh foods temp. If your garage is let's say 35 degrees, the fresh foods temp will most likely never raise enough to turn the refrigerator on. With the refrigerator never running, the freezer compartment will warm to 35 degrees, resulting in everything melting. Even if garage is a bit warmer, say 45, the refrig will not run long enough for the freezer to maintain a low enough temperture. If the garage temp falls to below freezing, say 20 degrees, the food in the fresh foods compartment will freeze. (outdoor beverage dispensers have internal heaters to prevent product from freezing !) Please don't rate this if not a Fix-Ya for you, as anything else lowers my score.
Jan 22, 2009 | Frigidaire 5 cu. ft. / 142 liter Chest...
Freezer tempature
Depends on the product you want to keep in the freezer. Usually you want to try and stay between 0 and +10 degrees for most items. Ice Cream must be -10 degrees minimum. Any warmer and it won't keep. Hope this helps.
Good Luck
Dec 24, 2008 | Nor-Lake Freezer Norlake Refrigeration 6'...
Refrigerators Logo
87 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
