Question about Vacuums
Manual for Prestige Coffee Maker Deco 50669-C
I RECEIVED THIS FROM MY DAUGHTER SO HAVE NO INSTRUCTIONS BUT THE WATER ISN'T HOT ENOUGH FOR MY COFFEE
the element might of burned out. Is it a used coffee maker? Elements do burn out from time to time and you might have to just buy a new coffee maker.
Aug 16, 2011 | Vacuums
Need to clean cuisinart 12 cup coffee on demand coffe pot. How do I clean?
Do you have the DCC-2000?
To delime a multi-cup coffee maker, mix white vinegar with water (1/3 vinegar and 2/3 water) and fill the water reservoir completely. Then turn the coffee maker on. Wait until the unit completes the "brewing" cycle and beeps 5 times. Turn off the coffee maker. Discard the liquid after the cycle. Then fill the reservoir with clean water and turn on again. When this cycle completes, again discard the liquid. Repeat the water rinse if you notice an odd taste to the coffee afterwards. (If the coffee maker still has deposits, repeat the vinegar cleaning cycle and rinse cycles.) There are commercial deliming products, mix them with water following the package directions.
The manual for the DCC-2000 is available as a link here: http://www.cuisinart.com/products/coffee_bar/dcc-2000.html . The direct link to the manual is http://www.cuisinart.com/share/pdf/manuals/dcc-2000.pdf .
I hope this helps.
Jun 19, 2011 | Vacuums
When i make a cup of coffee with my kuerig coffee maker my coffee is coming out with coffee grinds though it. how can i fix this problem?
Your coffe may be ground too finely for your maker.
Is your coffee maker flat-bottom or cone shaped? Or is it a french press?
Your coffee needs to be ground according to the brewing method. Too coarse and it will be watery, too fine and it will be too dark, or you might get grounds.
May 06, 2011 | Vacuums
I have a coffee maker that makes 36 cups of coffee. How many cups of ground coffee should I use to brew 36 cups?
I would ordinarily use half the amount of scoops of coffee as the amount of cups the coffee maker makes. A scoop being a Tablespoon of ground coffee. Less if you want it weak and one or two more if you want it very strong.
Apr 09, 2011 | Vacuums
I have a mr coffee machine and the red light for cleaning comes on, and I lost my directions on how to clean it, so I am asking you for your help
Click HERE for the manual. Cleaning instructions are on page 11.
If this is not your coffee maker click HERE and click the little arrows below "Browse coffee makers" until you find yours. You can then download the manual or go to the Frequently Asked Questions (FAQ) to find a solution. These options are located at the bottom of the web site under "Customer Service"
Hope this helps..
Mar 27, 2011 | Vacuums
Need to find a repair shop In Yuma AZ 85365, for an Estro Coffee Maker/Espresso Maker
here is a list of a few in Yuma that can fix your coffee maker.
1. M+S home appliance (928) 341-9792
2. Desert Sun appliance (928) 210-7151
3. Tony's appliance (928) 782-3235
c...
Feb 05, 2011 | Vacuums
How do I clean my Keurig coffee maker?
I clean my Mr Coffee by pouring a half water/white vinegar into the water holder andturn the coffee maker on andlet the vinegar do its thing. A refill with a little lemon juice in the water gets rid of any vinegary smell left behind.
Jan 04, 2011 | Vacuums
I need the manual for farberware fsu 236 coffee maker. How much coffee for 36 cups of water?
For medium strength coffee, start with about 2 cups of coffee. Adjust for taste in later batches until it's the strength you want.
Nov 24, 2010 | Vacuums
Vacuums Logo
418 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
