SOURCE: Dishwasher pump keeps running
This is caused by a water leak into the base pan,it will trigger the anti flood and the machine will continously drain out even with the door open,you need to establish what is leaking,if you leave the appliance standing for a few days it will start again as the water will evaporate however if the fault returns you will definetly have aleak on the appliance which will require further investigation.
SOURCE: Neff dishwasher not filling up with water
neff dishwasher will drain water goes in but the top and bottom spray do not work tablet falls in goes through cycle but will not wash. iangas
SOURCE: I replace torn outlet hose on my Neff S4438 built
make sure you still have power going to your unit. sometimes they are plugged into a regular wall plug under the sink or you can also chrck the circuit breaker @ the panel most of the on the out side of the house
SOURCE: How do I find the product code for my Neff
You will find the Enr. and Fd. numbers on the top inside edge of the stainless in the centre near the door switch. It is etched into the stainless and it can be difficult to see in certain lights or the angle you look at it but it is there.
Hope this helps.
