Question about Xerox DocuColor 12 Printer
Erroe code 10-103 dc 12 - Xerox DocuColor 12 Printer
    Problem Solver:
  • 15 Answers
Fuser switch
Posted on Sep 05, 2010
Error code 5418 priter hp 3600
54.18 - An error has occurred with one of the tonerlevel sensors Black - 1. Make sure that connector J1020 on the DC controller is seated correctly. 2. Replace the memory-controller PCA. 3. Replace the DC controller.
May 25, 2015 | HP LaserJet 3600n Printer
How can l remove this erro code in ir cannon 2318l it showing e000 100 0000
Dear Its the problem with LSU (laser scanning unit).
Pl. do as.
1-clear error list in service mode.
2-check all harness to LSU.
3- Clean all optical path, ie. lenses inside LSU with lint free cotton cloth only including polygon motor.
4-cross check LSU
5-Cross check DC-CON card.
Thanks.
Mar 05, 2015 | Cannon Office Equipment & Supplies
How will l remove this erro code in lr cannon 2318l it showing e000 100 0000
Dear
Pl. do as.
4-cross check LSU
Thanks.
Hi sir i have a xerox dc 12 giving error code 10-500 after replacing a new web cartridge
This code means that printer is not detecting the cartridge. you can try to to remove it and re seat it or it could be faulty, her is a list of all of the codes.
http://www.metrouk.co.uk/pdf/xeroxdc12faultcodes.pdf
Hope this helps.
Sep 16, 2014 | Xerox DocuColor 12 Printer
Erroe cod
=High density for the target at patch detection=
1. Clean the scanner's window.
2. Use your hand to check if the shutter of the Registration Patch Sensor Unit can be open.
3. Check if the window of the Patch Sensor (UN43/ UN44) is soiled.
4. Check scar on the ITB.
5. Check movement of the Registration Shutter Solenoid (SL02).COPIER > FUNCTION > PART-CHK > SL to move SL02
6. Check the harness/connector between the DC Controller PCB (UN09/J12) and the Patch Sensors (UN43/J4007, UN44, J4006).
7.Replace the Drum Unit (M)
8.Replace the Registration Patch Sensor Unit
9 Replace the ITB Unit.
10. Check conduction of the fuses (FU5, FU8) in the DC Controller PCB (UN09).
11. Replace the Primary Transfer High Voltage PCB (UN04)
12. Replace the Developing High Voltage PCB (UN07)
13. Replace the Primary Charging High Voltage PCB (UN06)
14. Replace the Auxiliary High Voltage PCB (UN08)
15. Replace the Replace the DC Controller PCB (UN09)
Apr 26, 2014 | Canon for IMAGERUNNER C2020 C2050 C2058...
E000733-0001 error cod
at first cheak the flat cable between D.C to ip. or chenge the cable.
may be dc or ip damaged
Feb 24, 2013 | Canon imageRUNNER 5000 Copier
Will spin but wont drain
If your machine is a FAV6800A or FAV9800A the issue more than likley a clutch issue. Any erro codes like DC or UC?
Do you want to try to DIY the repair? If so I can help you.
Feb 13, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Xerox dc 12 error code 9-357
9-357 Black Toner Dispenser Broken.
Dec 19, 2009 | Xerox DocuColor 12 Color Copier
PROBLEMS WITH FIERY AND DC 12
sir u do first one thing
1,check cable betwen fiery & dc 12 machine
2, press 0 + start enter code 6789
3,go to nvm read/write
4,enter nvm 759-053 code -enter 1
5, next 759-054 code-enter 1
Dec 09, 2008 | Xerox DocuColor 12 Printer
Xerox dc 12 copier system faulit 9-354
Hi ,
Sir I am have dc12 mech
its giving error code 9-354.
send me the solution as soon as posible.
Aug 09, 2008 | Xerox DocuColor 12 Color Copier
Xerox DocuColor 12 Printer Logo
48 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
