The clothes are soaking wet at the end of the cycle. I tried re-balancing the load and also re-running the load on a different cycle and the clothes were even wetter.
    President:
  • 1,294 Answers
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
And pl rate me if helped.................
Posted on May 09, 2008
Have a kenmore washer and I have to run everything thru 2 spins cycle
If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn clutch.
Oct 25, 2011 | Kenmore 22422 Top Load Washer
My washer spins out very slowly and the water drains but the clothes are very wet.
f the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag), a worn clutch (GE/Hotpoint), or a worn motor pulley or tub bearing.
Nov 30, 2010 | Westinghouse WWS833ES Super Capacity Top...
When the cycle is done my clothes is still soaking wet
Hello becca_m2012 ,
Is the machine a FAV6800A or FAV9800A. If it is one of those models are you failing in Spin Cycle of the Wash Cycle with a dC or Uc error code to the display? Lets nail down the model number and I will try to point you the repair path......Rich
Nov 16, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Spin cycle
it sounds like there is either an obstruction in the pump, or the load is getting off balance during the spin cycle. two things to try, fill the washer with no cloths in it, when it starts to agitate, stop the cycle and put it in drain/spin cycle. the water should be out in under a minute. its hard to see because the door locks, but you can hear a difference in the pump when its out, or after 60 seconds, press cancel and open the lid to check. if the waters out in that time, the pumps ok. then run it through the spin diagnostic with a load of cloths. make sure the cloths are wet, and a normal load you wash. this will check to see if the load is getting off balance, and shutting down during the spin cycle. let me know if you still have the problem. good luck, shane
Aug 23, 2009 | Maytag Neptune Washer
After the spin cycle runs the clothes are still soaking wet
I had that problem at one time with my old washer and what it ended up being was the Washer Dog Agitators were broken and causing the it to slip and not spin correctly. I would try checking the Dog Agitators.
Here's A picture of a typical top-load washer breakdown to show you where they are located --->Here<---
I hope this helps. If that is the problem I bought mine at Sears for about $8, normally in stock item.
moz-screenshot-2.jpgLet me know if there is anything else I can do.
May 25, 2009 | Washing Machines
My clothe come out very wet at the end of the wash cycle
If the pump is clogged and can't release all the water it won't go into final high spin. Remove lower cover and locate coin catch and unscrew it. Water will come out, so be ready. If it's full of stuff, this is probably the problem.
Mar 13, 2009 | Kenmore HE2 Plus Front Load Washer
LG front load washer/ clothes still wet after final spin
The heavy jacket prevented the washer from spinning at a rapid pace, so I added a heavy bathrobe to absorb some of the water and to balance the load. The washer then spun very quickly and drained out all the water.
Jan 07, 2009 | LG WM-1832C Front Load Washer
Does not Spin out the water at the end of a load
If it spins the balance is okay. Check out your filter now. And then the pump (after the spigot prob below) Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Jan 06, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Washing Machines Logo
35 people viewed this question
Top Washing Machines Experts
