Question about Sangean ATS 808A AM/FM/SW Radio
Can I get a circuit for the powere distrib for Sangean ATS-808. Someone has applied an overvoltage. Thankyou Kev. Kelly
SOURCE: Sangean ATS 803A
Don't be mis-led by the working display. I had the "no power" problem with a working display too. I measured the voltage of the two AA batteries. One was 1.33 volts and the other was only 0.76 volts. Replaced the weak AA and everything worked. I suspect the 'enable' circuitry fails around/below 2.1v.
Posted on Dec 17, 2008
radiorob1
  • 17 Answers
SOURCE: Wiring schematic for Sangean ATS 818cs
Yes, go to:
www.thiecom.de/ftp/sangean/ats818/ats818acs-servicemanual.pdf
Posted on Aug 04, 2009
  • 70 Answers
SOURCE: operating instructions
http://www.devicemanuals.com/guide/Radio/Sangean/Sangean-ATS-505-User-Guide-TkRRek1Uaz.html
Posted on Apr 10, 2010
caroldon
  • 17130 Answers
SOURCE: I have a Sangean ATS 818cs portable radio but no 6v lead input
Yes you can use any 6 volt DC for your radio but the most IMPORTANT thing to remember is to connect the terminals in the correct direcction. First of all you can solder a red wire from the positve terminal of the battery and a black wire from the negative terminal of the battery. This must be connected to the source of your 6 volt battery.You can buy a good DC jack socket female to be fitted into the vacant spot of your radio and use a male jack to supply the DC. Only be carefully to see the polarity. To avoid any reversing of polarity use can even connect a diode in the forwarrd bias towards the positve terminal. This will prevent any wrong connection of polarity to damage your set. Helpful? Good day
Posted on Jul 15, 2010
SOURCE: My Sangean ATS 808 AM/FM/SW Radio reciever shows a
Hello, I assume that this only happens when you are using it on batteries and the unit works when plugged into the mains. If this is the case it most likely is a faulty or dirty connection in the main battery chamber. Clean all contacts reload new batteries and try again.
Posted on Dec 22, 2010
I NEED A KNOB FOR THE SANGEAN ATS-909X
Sangean customer service is great, and if you contact them with the problem, they will probably give you one for free, even if you are not the original owner.
Nov 29, 2012 | Sangean ATS 909 AM/FM/SW Radio
Sangean ATS-909X Volume control has failed (no longer trims volume). A little pressure on the control will sometimes restore its function. Sounds like a bad solder joint or a cracked board. Any th
A similar problem with SANGEAN ATS-909x I have too.
When you touch the volume control ever hear the full volume.
Tap volume control side, the sound is normal.
Suppose a poor connection on the control volume.
Correction here in Slovakia is not guaranteed.
Receiver has a serial No: 0C000451 is under warranty, purchased through E-Bay from Taiwan, made 1/2011 and purchased in 2012.
It seems that I remains only a decoration.
Milan
Translation by GOOGLE
May 11, 2012 | Sangean ATS-909X Professional Multi-Band...
I want to add an external antenna, is this product available to be purchased, if so from what stores and approx. how much will it cost. My Radio is a Sangean ATS 808A. Also, is a 220 Volt power pack...
Hello eab.... I would begin by looking at Radio Shack. Take the radio in with you. The prices cover a wide price range depending on the range and quality. Joe
Thanks for choosing Fixya!
Feb 26, 2011 | Sangean ATS 808A AM/FM/SW Radio
My Sangean ATS 808 AM/FM/SW Radio reciever shows a flashing E on startup and won't operate. Any answers on resetting or other solution?
Oct 17, 2010 | Sangean ATS 808A AM/FM/SW Radio
Yes, go to:
Jan 01, 2009 | Sangean ATS 818 AM/FM/SW Radio
Sangean ATS 803A
Sep 27, 2008 | Sangean ATS 808A AM/FM/SW Radio
WX cc Sangean radio cuts out
The ATS-818 needs a transformer. The transformer converts AC power to the DC used by the radio, so no. You need the transformer.
Jan 20, 2008 | Sangean ATS 818 AM/FM/SW Radio
SANGEAN ATS505
try the power switch a few times and more force than usual.
Sep 16, 2006 | Sangean ATS 505 AM/FM/SW Radio
Sangean ATS 808A AM/FM/SW Radio Logo
43 people viewed this question
Top Sangean Audio Players & Recorders Experts
Gyula Lacz
Are you a Sangean Audio Player and Recorder Expert? Answer questions, earn points and help others
