Question about HP DeskJet F380 All-In-One Printer
It's giving the error message 'Print cartridge has a problem'. I have removed and checked the cartridges and both seem fine. The printer will not allow me to carry out a self check print. On the printer display there is a letter 'e' and an amber flashing light above it. Any info will be welcome!
  • HP Master
  • 4,737 Answers
Well, we cannot judge a cartridge by looking on the exterior surface, it's not even possible to know whether it's really dead or it's just pretending :-). We can only check them by trying it on another printer or replacing another cartridge. Even if it looks great and no physical detected/seen externally, it might have a faulty inside.
First, remove both the cartridges, clean the contacts on both the cartridges and on the printer using a cotton or other cleaning material dipped in alcohol or acetone or spirit. Never touch the print heads, they are fragile and easily damaged, moreover it's not repairable. After you are sure that the contacts are cleaned and dried, reinstall them and try again. If the problem persists with the same error. You better get another cartridge/s.
If the new cartridge/s don't work, then the printer needs to be serviced. It's contacts seem not receiving the signal from the motherbaord or there's a continuity problem. You last option is to call HP.
Good luck
Thanks for using FixYa.
Posted on Aug 31, 2010
Error B200
Get steps to Fix Canon Printer Error Code B200 instantly. Watch below video to learn how to fix Error Code B200 on PIXMA Printer Call now +44-8000465291 for instant Printer help.
Source: https://goo.gl/xskzcB
For 4+ Cartridge Printers:
Step1:-Remove All Printer Cartridges.
Do remove the individual ink cartridges from your printer. This will be opening the lid of your printer and waiting for the cartridge cradle to be placed in the correct position.
Step2:-Remove the Print-head.
This is can be done by lifting the orange or gray locking lever on the side of the cartridge cradle and then gently lifting the print-head from the printer.
Get full Step by click below link
How to Fix Error Code B200 on Canon PIXMA Printers 44 8000465291
Feb 01, 2016 | Office Equipment & Supplies
Hp4355 print catridge error
Each cartridge having printing life, as long as cartridge health condition is good it won't gives any trouble. Subjected series printer having mono & colour cartridges,1. Remove both cartridge from the printer 2. Switch on & wait till message appears for insert the cartridges..3. Insert mono(Black) cartridge, close the door & wait till message appears on screen. If message appears same as cartridge error mean that mono cartridge is faulty replace it, if message appears like insert another cartridge, it's confirmed that colour cartridge faulty.. Replace it..
Apr 28, 2012 | HP Officejet 4355 All-In-One InkJet...
Error message says "Remove and check cartridge on right" Its a new cartridge I've been using for a few weeks and it has been working fine. I have removed cartridge several times and even cleaned contacts....
The electronics on the cartridge have gone bad. Sometimes cartridges short. Take the cartridge back to where you bought it (they should give you credit for any remaining ink) and buy a new cartridge.
Aug 10, 2010 | HP Photosmart C4180 All-In-One InkJet...
Cannot print, scan or copy. Continue to receive
Solution
  1. Remove and then reinsert the cartridge indicated in the error message.
  2. If the error is still displayed, clean the contacts. Click here to see how.
  3. If the error message is Error. Remove and Check Black or Photo Cartridge , the following steps may help:
    1. Remove both cartridges, lower the latches, and close the printer access door.
    2. Turn off the unit by pressing the On button on the front panel. Wait for the printer to completely shut down.
    3. Turn the printer back on by pressing the On button.
    4. When the message display reads Insert Print Cartridges , open the access door and replace the cartridges.
  4. If neither of the steps above fixed the problem, either the cartridge or the printer is faulty.5. Replace Cartridge.Please rate my response!!!Thanks,SF
Jan 28, 2010 | HP PSC 2410 All-In-One InkJet Printer
Check print cartridge blinking cartridges refilled today and installed laptop not recognising printer as result
    • If the message on the computer does not identify a particular cartridge (it says only Print cartridge error ), follow the steps below to determine which cartridge is causing the problem.
      1. Open the cartridge access door.
      2. Remove either cartridge (not both).
      3. Close the cartridge access door.
        • If the computer message is Print Cartridge Error , then the print cartridge that is still in the printer is the problem cartridge.
        • If the computer message is NOT Print Cartridge Error (instead, it says that the cartridge you have removed is ...Either missing, not detected, or incorrectly installed), then the cartridge you have removed is the problem cartridge.
  • If the problem still occurs, the electrical contact between the cartridges and the printer might be bad. Removing and reseating the cartridges might help. Also, you can clean the electric contacts on the cartridges with a dry cloth.
Hope that will help solve your problem!
Jan 16, 2010 | HP PSC 1205 InkJet Printer
Psc750 alarm message: remove and check black cartridge.
There seems to be a problem with the cartridge. If it is printing normally, you can either live with the error, or replace the cartridge.
You can try cleaning the contacts with a q-tip and some rubbing alcohol just in case.
Jun 22, 2009 | HP PSC 750 All-In-One InkJet Printer
Won't print gives error message above power and function push button incorrect color cartridge installed---was working fine yesterday no cartridge was done...
uninstall and reinstall printer and make sure u follow the promp and put the right cartridge in the right spot....black and color....2 different chambers
Apr 19, 2009 | HP PSC 750 All-In-One InkJet Printer
Hp psc2410xi
The following error message appears on the color graphics display after you insert a cartridge: Remove and Check Print Cartridges . The printer will not print. The message does not specify which cartridge has caused the error. Solution This error message indicates that the printer cannot determine which cartridge is causing the error. Follow the steps below to solve the problem.
  1. Remove the color cartridge from the left stall (which has a blue latch) and refasten the latch. Leave the other cartridge in place.
  2. Close the printer, wait 10 to 15 seconds, then look at the LCD display.
    • If the LCD display reads Insert Color Cartridge in Left Stall , the color cartridge may be causing the problem. Follow the steps below:
      1. Clean the color cartridge contacts.
      2. Reinsert the color cartridge into the carriage and close the blue latch.
      3. Close the printer and wait 10 to 15 seconds.
      4. If the LCD display reads Remove and Check Print Cartridges , replace the color cartridge.
    OR
    • If the LCD display reads Remove and Check Print Cartridges , follow the steps below:
      1. Reinsert the color cartridge.
      2. Remove the black or photo cartridge, depending on which one is installed in the right stall. The right stall has the gray latch. Be sure to refasten the latch on the empty stall.
      3. Clean the black or photo cartridge contacts.
      4. Reinsert the black or photo cartridge.
      5. Close the printer and wait 10 to 15 seconds.
      6. If the LCD display reads Remove and Check Print Cartridges , replace the black or photo cartridge.
    1. If the error message is Error. Remove and Check Black or Photo Cartridge , the following steps may help:
    1. If neither of the steps above fixed the problem, either the cartridge or the printer is faulty
    Aug 12, 2008 | HP LaserJet 5L Printer
    Remove and check color cartridge
    the problem is the little poorly designed metal thing that is holding up the ink cartridge get's stuck between the cartridge and the printed circuit and it brakes the circuit.must have been some **** drawering on a napkin that came up with that one.wasted a nice unit for that two cent piece of metal.
    Jul 23, 2008 | HP Photosmart 2610 All-In-One InkJet...
    Error message 50c on printer
    I had the same error message 50c and "color Ink low". I knew that I still had Black Ink, and that is what I just needed for the moment, so I removed the color Ink cartridge and it started working. You'll get a message 'print cartridge missing' but just press continue.
    Hope this helps,
    MPTMPeru
    Nov 11, 2007 | Dell A940 All-In-One InkJet Printer
    HP DeskJet F380 All-In-One Printer Logo
    96 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
