Samsung aqb09jjwc/uqb09jjwc split type air conditioner keeps shutting down incool mode . When it shuts down the operation indicator (green) and turbo indicator (red) flash continuously.
    Scholar:
  • 149 Answers
Possible defective thermistors there are 2 of them
Posted on May 09, 2008
Why my unit keep shutting off after few seconds and then turbo light keep on flashing?
Operation =
Flashing Display Timer = Yes
Turbo =
LED Display = E1
Explanation and Checking points = Indoor unit room thermistor error - Open or Closed Circuit - Check and replace if required
Operation = Yes
Turbo =
LED Display = E2
Explanation and Checking points = Indoor unit pipe thermistor error - - Open or Closed Circuit - Check and replace if required
Operation =
Turbo = Yes
LED Display = E3
Explanation and Checking points = Indoor unit fan motor malfunction - Check and replace if required
Operation =
Turbo = Yes
LED Display = E6
Explanation and Checking points = EPROM error - Check and replace PCB if required
Operation = Yes
Turbo = Yes
LED Display = Flashing
Explanation and Checking points = Option code error - Check and input new option code if required via wireless remote controller
Operation = Yes
Turbo = Yes
LED Display =
Explanation and Checking points = Outdoor unit temperature sensor - Open or Closed Circuit - Check and replace if required
Jun 18, 2014 | Samsung AQV36JA Classic 36000 BTU Single...
We have 2.0 HP inverter wall mounted LG aircon, when we turn on the ac, the indoor unit only is running and shut down after 3 mins. What is the solution?
Hi Marie, does the green indicator light on the front panel flash after it shuts down? If it does...count how many times it flashes this will refer to a fault code diagnostic.
Keith.
Jan 02, 2014 | LG LS-K2430HL Heat Cool Mini Split Air...
My carrier split type non-inverter aircon always blinking
It indicates afault within the unit. Give Carrier a call and get it serviced.
Mat
Jul 01, 2009 | Carrier 36KCARMS Air Conditioner
My samsung split system a/c keeps shutting down, with the mode light flashing on the indoor unit. This unit is installed 30' up the side of the house - is it not getting enough freon and there shuts down?
I have a MH050FX A2 that is two head unit and they run only one at a time, when I turn both on, one will shut down. I get an error code of E2 01 with a, I beleive correction code of U C8. Can you help me with a diagnosis??
Kelly Sheehan
Jun 17, 2009 | Samsung AS18A6RB Air Conditioner
LG split AC keeps displaying CO and wont't turn off with remote.
The "CO" indicates cleaning operation and can be switched of via remote button under flap, labelled AUTO CLEAN.
Mat
Apr 13, 2009 | LG LSC121PMA Split System Air Conditioner
New install. 40 seconds on. 20 seconds off.
Its normal that the air coming out is warm cause you set it to heat mode. Check your setting temperature, it is normal for the unit to shutdown when it will attain the setting temperature and operate when the temperature is lower than the setting temperature(heat mode).
Mar 05, 2008 | GE Quiet-Aire Ductless Split System Air...
Heating & Cooling Logo
559 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
