Question about Whirlpool Washing Machines
Duiring the washing time water is leaking from under roof of the machine.How it will solve?
  • 176 Answers
Check all the hoses and water pump
Posted on Aug 31, 2010
2006 dodge durango that does not have a sun roof that leaks water on the Head liner and seat belt and floor when it rains or I go thru car wash? What could cause this?
I just Googled a picture.
There is a roof rack type trim on the roof.
Water flows downhill
3 possible sources:
- window trim
- windshield
- roof trim
I would be suspecting the roof trim. Determine how it is attached. Remove it. Clean the roof and all parts of the trim that contect the roof. Apply sealant in appropriate locations. Re- install roof trim.
Test
No leak!
Ta-Da!
Apr 15, 2016 | Dodge Cars & Trucks
Bosch avantixx front loader leaking underneath machine? machine only 2 years old
  • You will find a small door on the front bottom of the washing machine.
  • Open it.
  • Unscrew the filter and rinse it with running water.
  • Put it back in place and repeat the above steps in reverse order.
This should solve your leakage problem.
Aug 03, 2014 | Bosch Washing Machines
Mav4757aww leaks water during spin cycle with full loads only
Thanks for the quick responses.Pulled front cover,ran a load on high level, no leaks .Ran a load on super level and when drum spins when full of water water level rose and poured out of left front side on top of drum. Pulled plastic ring on top of drum and and found piece of seal missing where leak occured .Ordered upper tub seal, should solve problem
Jul 27, 2012 | Maytag Ensignia MAV4757AWW Top Load Washer
Water leaking from under washing machine. Took off cover. Hoses ans water pump look good. Seems water is leaking on spin cycle above the transmission.
90% of the time the water leaks from either the drain pump module or motor, or through the centre seal and bearing.Couple of not so common areas are the various pipes:small holes in the drum:the soap dish etc. Possibly remove the lid and place the washer on 4 bricks and then run the machine so you can pinpoint the area.
May 20, 2010 | Washing Machines
Water leaks into the bowl after clothes havve been removed for awile
Unplug power and see if water still leaks in. If it does, it's probably the valve.Water valves can become corroded or clogged causing slow leaks. Most are easy to replace and cost under 50$. Hope this solves it- Thanks---ED
Feb 27, 2010 | Crosley Washing Machines
GE whre5260e1ww zh133346g top load washer is leaking small amount from the bottom of the machine during wash cycle? I took the back of the machine off and the pump and motor assembly had broken off from...
Hello there:
Here is a few tips that might help you out
Hope that they are very helpful for you
Best regards Mike
Washing machine is leaking Washing machine leaks are very common. There are many places a washing machine can leak from although most leaks come from the same few places. The most common cause for a leaking washing machine is the door seal. Door seals often get holes in them and water leaks down the inside of the washing machine which then runs out under the front. Water leaking down the front of the washing machine from the door can be caused by a worn door seal (the flange part that the door glass presses against when closed) or something trapped between the door seal and the door glass which breaks the seal. If the door seal doesn't look worn, or it's too young to be worn, then try cleaning the door seal's flange and the door glass on the inside of the door. Bits of cotton, un dissolved washing machine detergent etc can cause a leak.
Soap dispenser leaks
The next most common cause of a leaking washing machine is the soap dispenser. Leaking water from a soap dispenser is often caused by a blockage, or water pressure that is simply too high. Despite seeing many leaking soap dispensers, I've never seen a soap drawer with a seal, they just rely on water not getting to the front which is not really good enough. Some Hoover soap dispensers in particular, are renowned for leaking, and over the years Hoover have had to introduce modified soap dispensers twice.
Some washing machines, can flood water out of the soap dispenser when a hose gets blocked (usually with un dissolved soap powder) Indesit, and Candy, as well as some of the later Hoover washing machines suffered from this design flaw. The hose where the water is flushed down, was right at the front of the soap dispenser on these washing machines and the hose wasn't wide enough. Un dissolved powder from a tablet or lumps of detergent through poor hot water pressure can block this hose solid. (Note: water flooding out of the front of a washing machine's soap dispenser can also be an indication of overfilling or a partial pump blockage if it does it when spinning)
Finally, black gunge in the top of the soap dispenser can cause water to spray towards the front and leak. Take out the soap dispenser drawer and look at the roof of the soap dispenser. If it's covered in black gunge, blocking some of the water holes, it could be causing problems. In extreme cases I've had to replace the dispenser.
Tips for finding a leak on a washing machine
  • If you have a leaking washing machine, and you can't see where it's coming from, shove some newspaper underneath the washing machine. The slightest drop will give a clue where the water is leaking from. Pull the sheet out regularly to check for water leaks.
  • Water can run round things and drip onto other parts. Be careful with your diagnosis, as water dripping from a hose at the bottom could actually be leaking from somewhere else higher up.
  • Leaks usually leave marks, so it's possible to see something is leaking even without witnessing it. The soap suds that come out with the leaking water leave white trails. Rust is a good indicator of a water leak too. However, if you have had a previous leak cured, the "evidence" of a leak may still be present so be sure you don't blame a part that was repaired in the past.
  • If the washing machine leaks only at the end of the wash, when water is being pumped out. Make sure water isn't backing up and cascading over the top of a blocked drain pipe in the plumbing.
  • WARNING: Don't get electrocuted trying to witness a leak. It's dangerous running the washing machine with the top or back off.
Nov 13, 2009 | GE WDSR2080D Top Load Washer
My washing machine keeps leaking from the bottom
For me there is not enough information. What hose did you replace and when does the machine start to leak ?
Dec 26, 2007 | Kenmore 24032\24036 Top Load Washer
Leaking Washer
Changing this solenoid could solve your problem. Also try to turn off your faucet if possible after you hv finished your washing.
Dec 24, 2007 | Fisher and Paykel GWL11 Top Load Washer
Machine cant get any water.
Does the water fill to the correct level ?
Sep 09, 2007 | Fisher and Paykel Fisher Paykel Intuitive...
Machine leaks
Leaking water usually comes from hoses or connections. Be sure that water appearing to be a leak isn't drain water from a backed-up standpipe (see HERE for information on clearing clogged drains). NOTE: To prevent serious flood damage that can occur if washing machine supply hoses burst, be sure to install "no-burst" stainless-steel mesh hoses and lever-type shutoff valves, as shown in the illustration. With these, you can easily turn off the levers for both hot and cold water between wash days. 1) Check the fittings where hoses connect to the faucets and to the back of the washing machine. Also look for worn or leaky hoses. Tighten couplings or hose clamps if necessary, or replace hoses altogether (be sure to turn the water off before removing hoses and drain them into a bucket after disconnecting them). 2) Determine whether machine is over-sudsing during wash loads-- this can cause the entire washing machine to overflow. Reduce suds by pouring a mixture of 1/2 cup of white vinegar and 1 quart water into the washer. Then switch to less detergent or use a low-sudsing variety. 3) Call a repairperson. The machine may have a faulty basket gasket or tub seal and bearing that must be replaced.
Jan 18, 2006 | Hotpoint Aquarius WD63 Front Load...
Washing Machines Logo
14 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
