Question about Dell Dimension E310 PC Desktop
Have a Dell E310 PC here. Had it checked and person said the motherboard was the problem. Replaced the Motherboard and continue to the blue screen of death Help!
  • 1 more comment
  • David Valdepena Aug 31, 2010
    This PC is a friends and the initial problem was that the blue screen of death was coming on immediately. Did not even try to boot. After replacing the motherboard the pc try's to boot but then fails and the blue screen comes up. Initialy it would not let me in the BIOS but after replaced the motherboard it does. Still I can not get the pc to completely boot and operate.
    I will do that and yes I do understand. Appreciate your quick response sir. Will let you know in the AM hours between 9 and 11 if it does take care of the problem as I do not have the system recovery cd here.
    Operating system is windows xp, purchased in Jan. of 06. No unusual noises.
  • 503 Answers
Try booting the machine up in safe mode. To do this restart the machine and repeatedly tap F8. When the sub menu appears choose safe mode as see if you get the same message again. If you don't and it boots to safe mode and then follow certains steps to recover the operating system.
We now need to use the Check Disk Utility to repair the problem.
Start the system in Safe Mode if the machine already isn't.
To do this click on the start menu and again click on Run. In the box type cmd a command line window will open. For Vista type cmd in the search box and hit enter.
In the command line window type chkdsk /r and hit enter. You will get a message saying that the volume cannot be locked and would you like to schedule a disk check next time the computer restarts. Type Y and then hit enter. Close the window and restart your pc.
Disk check will start and repair any bad files and fix any bad sectors before loading the operating system and could take 2 to 3 hours to complete depending on the state of the volume.
Once its done it will reboot in normal mode. See if the disk check has done its job and try using the applications that has been crashing the computer.
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Posted on Sep 01, 2010
  • Dell Master
  • 4,737 Answers
Would you mind if I ask you something more? I need to know the operating system installed on your system, i.e. windows vista, windows 7 or etc... In windows vista and windows 7, this problem is known and there are several patches to fight these bugs. Another case, you need to let me know the year of the purchased. I hope you know the lifespan of a hard disk, it should be not more than 5 years, even if it's working after 5 years, it may crash one day without any warning. One more question, listen the sound of the hard disk very carefully, if you hear any unusual sound like tick tick or tak tak or etc etc.. you have to take note of the sounds and let me know, it might sound funny but this is one of the most important part in troubleshooting a machine. Many systems with bluescreen is fixed after replacing the hard disk, i don't mean motherboard couldn't be the cause, but in your case, it's already done. Another culprit is the Ram. If you have another spare, that'd be very helpful for us in troubleshooting this. Also the data cables are sometimes involved.
Well, let me know whatever I need to know before I help you troubleshoot this. I'll send you the links for the patches after i receive your reply.
Thanks and awaiting.
Posted on Aug 31, 2010
  • 1,555 Answers
You simply need to boot through your operating systems CD inside it when it ask boot through CD just press any key. once setup starts hit enter ignore the repair option for the first time hit R when the repair option appears for the second time. When the system completes the repair your pc will be all ok. Kindly do let me know if you don't understand the procedure explained above.
  • Aruna Singh
    Aruna Singh Sep 07, 2010
    You don't require the recovery CD to repair. I'm asking for the CD of windows XP which you purchased in 06. Thats your operating system CD and through that only you can repair your pc. You have to arrange operating system CD from somewhere.
Cpu fan stopped working on dell dimension e310
Did you accidentally knock the fans little power plug out of its connection to the motherboard?
May 17, 2012 | Dell Dimension E310 PC Desktop
Help -- CPU Fan Failure bypass or pinout?
Yep I have a link below you can order the correct fan from.
http://store.cwc-group.com/y4574.html
I had the same issue here, we have 20 offices all running Dells. These fans seem to be used only on dell systems.
Feb 23, 2012 | Dell Dimension E310 PC Desktop
Well a friend of mine bought a replacement motherboard an E310 for his computer and now the it turns on but isnt working. the powerlight is staying amber and not turning green
Make sure The P4 Power connector cable is Plugged into The motherboard (pictured)flooganbarg.jpg
If that is not your problem you should look to make sure there's stand offs holding the motherboard in the case and it's not just screwed in and touching the metal case, this would cause a short and prevent the motherboard from Posting.
You may also want to check if the power button is correctly hooked up to the motherboard.
Jul 22, 2011 | Dell Dimension E310 PC Desktop
I have a dell dimension e310 desktop i beleive and it will not boot up. when i start it i hear 2 beeps. does this mean the motherboard is dead or what?
Two beeps means your motherboard RAM having some problem.
If you have two RAM install .Try to remove one and keep another .
Start your system and chek , if still problem is not solve better to contact with tech person.
Thanks for using FixYa.
May 20, 2011 | Dell Dimension E310 PC Desktop
Hi. I have a dell e310...and the desk top turns on but the monitor will not display anything...it has an amber light..sometimes.it will turn to green but then shuts off again Could this be a bad video...
depends . either the video card or motherboard see if the blue video connector is at the top or twords the bottom of the case and that will tell you if it's a card or integrated on the board.
May 13, 2010 | Dell Dimension E310 PC Desktop
Dell Dimension E310 won't boot up
this could be your motherboard, but could also be your video or audio card too. try making sure those are seated properly or try replacing one or both, if you so desire.
Jan 18, 2010 | Dell Dimension E310 PC Desktop
Blue Screen for Dell Dimension E310
1- Go To My Computer , and Right Click , Choose Properties .
2- Select Hardware , then Device manager , Then System Devices , and Choose CPU To Ati2_bing.gif
3- Update it manualy and Select PCI Bridge .
4 - It will work.
5- If u have any problem E-mail me @ support@rdptechs.net
Dec 15, 2009 | Dell Dimension E310 PC Desktop
My dell e310 will not turn on
Check the power cord make shure both ends are not loose. Check the switch on the back of the tower. If the computer is pluged in to a power strip check the surge protector most have lighted switch and a reset button. If no power at the wall outlet check that a wall switch doesn't control it and is on. Check circut breaker Or fuse pannel.
Hope This Helps
Please leave feedback
Nov 16, 2009 | Dell Dimension E310 PC Desktop
Dell Deminsion E310 will not boot
NTOSKRNL.EXE is missing or corrupt. To restore the original boot.ini file in Microsoft Windows NT or Windows 2000 you will need an ERD and follow the below steps.
Good Luck, Please dont for get to Vote/Thank You.
Dec 20, 2007 | Dell (E210882) Motherboard
Dell Dimension E310 PC Desktop Logo
mukhtar21 shaikh
mukhtar21 shaikh
