Question about Jandy AQUALINK RS TELELINK KIT
Can't get spa to refill!!HELP!!! - Jandy AQUALINK RS TELELINK KIT
  • 990 Answers
Most times this will not be in the Aqualink but in the actuator for the valves. You can check these by fliping the manuel switches on these. They will be small steel pins on the end away from the handel. These will be three way switches with the middle station being off. Check your wires first mostley where they are strapped to the pipes. These wires are small solid bell wires and will break inside the caseing if moved around a lot. These can be very pricey to replace, but if they work when you set the switch one way but not the other you may have to replace the actuator. One place to check on these is a motor shop that may rebuild them for you or have rebuilds in stock.
Good luck.
Posted on Aug 31, 2010
2001 cal spa blowing 20 amp fuse in Balboa spa pak
Probably a bad pump motor. Drain and refills are notorious for stuff like that.
Mar 28, 2014 | Dryers
Waterco 4555100e spa pump
most timers run on a 24 hour cycle may need to reset the timer so the tub will run until the desired tem is reached OR drain some water out and refill with hot water from your in-house heater..help it catch up..
Jan 10, 2014 | Pool & Spa
I emptied my spa for routine maintenance and then refilled it. When I start it the pump works but I am not getting any action through the jets. I have never had this problem before and I have had the spa...
I would suspect that there is an air bubble trapped in the pump. Did you run the hose into the filter intake and confirm water was coming through the jets when you began filling?
Mar 04, 2011 | Pool & Spa
My hot tub was just refilled yesterday and now when the pump comes on the water level lowers. I don't see a leak anywhere
If you are just refilling your spa after having it empty for a time, your shaft seal on the pump motor has dried out and has shrunk making the seal leak. Soon it will drip water into the motor housing and the motor will seize. It is very easy to change a shaft seal. E-mail if you need help
adamh@newconceptchem.com
If you
Sep 19, 2010 | Qca Spas Jewel Series Topaz Plus Hot Tub
Water temp. reading isn't the the same as the actual water temp. hot tub says heater dry
If you have drained the spa latly and refilled you could have an air lock keeping the heater dry. Simpley find the drain valve under the spa and open it till it run's water. This should help the problem by letting the pressure even in the pipeing and flooding. Good luck.
Mar 10, 2010 | Qca Spas Dream Series Dream Master Hot Tub...
I have refilled spa and on turning on the display is saying Error 6
06: Heater Thermal Cut Out has failed. It means that the spa can overheat as the built-in protection is disabled.
Call your spa repairman for help...
Jan 24, 2010 | Computers & Internet
Jandy AQUALINK RS TELELINK KIT  Logo
53 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
