Question about Gateway FPD2275W LCD Monitor
Text/picture shadow Recently I've noticed what appears to be a shadow appearing mostly with text but in some picture as well. It makes the screen look a little blurry. It's not bad but just enough to irritate me. Any suggestions?
  • lunarRock May 14, 2008
    yes, I just bought a refurbished one from compusa however it is the same gateway monitor. I was immediately dissappointed when I saw the shadow. It is extremely obvious when you compare it against my excellent norwood micro lcd monitor. I took about an hour in native resolution mode to see if i could fix the problem by adjusting every option i could tweak. Nothing. Tomorrow i will try to check for updated drivers, if that doesn't work I am sending it back to Gateway because the picture is aweful like this. Rusty this is not the way a monitor should look like so get your money back if u can't fix it.
  • dobsonsr Sep 17, 2008
    Just in the last week my HP 19in wide screen has developed this same problem. Blurry text - kind of like the old "ghost image" on television, but it's not noticeable on every part of the page - very weird, very irritating! I reset to basic XP modes on all screens, made sure my resolution was at the recommended level 1440x900, 60 mghz, I have been on tech chat with HP, checked for new drivers or updates, restored to previous working date and uninstalled recent software - all to no avail. any other help would be great!
    Scholar:
  • 33 Answers
Hi rustybob,
I have a solution for ya, but there are a couple of variables that could be involved. I assume it's an LCD monitor? How many inches is the viewing area, and what model is it? When you look at an LCD monitor, you pay attention to three main features for quality:
Contrast Ratio : This is the difference between the darkest black and brightest white. Anywhere from 600:1 (very poor) and 3000:1 (very good) are common. This could affect the display quality.
Refresh Rate : This is the amount of time it takes for the screen to entirely refresh the current image on display with a newer version. Think about watching a movie, and the screen quickly flickers to a different scene. This happens thousands of times per second. It is measures in milliseconds when discussing LCD monitors, and anywhere from 8-16 is normal. For viewing purposes, the smallest number is preferred.
Maximum Resolution : Your screen is a physically set dimension of space on your desk, but the amount of pixels that it displays can be changed by your video settings. Pixels are the small square specs of color that fill your entire screen with your images and text. The higher the resolution, the more blocks of color, the greater the 'crispness' or accuracy of detail can be perceived. This factor is most likely the cause of your blurry, or shadow effects.
When your computer is displaying picture at a lower resolution (for example: 800 x 600) there is less pixels of information between text or images. Therefore in order to simulate definition between contrasting colors, your video card will send information to your monitor that is not accurate, and often blurry or appearing out of focus. You do not need glasses, this is something the computer does to utilize your resolution (remember, resolution is the proportions of pixels on your screen, width x height).
To fix this, you need to answer one of the first questions we considered : How many inches of viewing area is your monitor? There is a term called 'Native Resolution' which refers to a set of resolutions you can set your monitor to to achieve the best visual quality.
If your monitor is square shaped, try 1024 x 768 or 1280 x 1024.
if your monitor is widescreen, or rectangular shaped, try 1280 x 800, or 1400 x 900.
In order to change your display settings, simply right-click anywhere on your desktop and select 'properties' or 'personalize' from the menu. Locate the tab labeled 'display' or menu option 'display settings' to be able to adjust your settings as you choose. Play with your resolution settings until you find one that looks clear, and you can still read. If you accidentally change your resolution to higher dimensions than your monitor can support, it will automatically revert back to your last working settings after 15 seconds.
Hope that helps!
Posted on May 09, 2008
    Scholar:
  • 35 Answers
This could be caused by any number of things. The first thing I would check is to make sure you have the cable plugged into both the monitor and the computer snuggly and that it hasn't come loose (if you haven't screwed the cable in using the thumb screws then you should). If this doesn't fix the problem I would check to make sure you are using the recommended resolution and refresh rate for your monitor (this can usually be found in the manual or if you change these settings some monitors will even tell you what the recommended settings are if you set them to something other then what is recommended). If you are using a Windows based PC you can check your resolution by right clicking anywhere there is a free spot on your desktop and choosing properties (or personalize if you are using Vista). This should bring up your display settings. If you click on the Advanced button and then click on Monitor you can change the refresh rate also. If you set it to something wrong just do not hit any keys or press any mouse buttons for 15 seconds and your computer should automatically revert to the setting you were using before. If none of these works and the cable running from your monitor to your computer is detachable then replacing the cable is recommended. Replacing it with a shielded cable that is gold tipped will provide the best connection (espically if you are using a longer cable). If none of these works you could have either a bad monitor or a bad video card. If you have a second monitor available I would hook that up and see if you see the same problem. If so, and you have already tried the resolution/refresh rate settings, it is quite possible your video card is going bad.
Toshiba 46XV645U Shadow Effect Problem
thats usually caused by a flex tab bond on the panel itself especially if the screen appears slow motion in that area.
Aug 07, 2012 | Toshiba 46XV645U LCD TV
Shadows on 40 INCH u m c television ,worst when alot of movement on screen
Hi shawdows can be cause by two things either your screen is bad or your t-con board is bad. Since the screens are so expensive it would be more economical to start by replacing the t-con board.
You can get parts at www.interliquidparts.com
Dec 09, 2011 | Televison & Video
Picture has a red shadow. especially
Convergence problem on rear projection CRT TVs.
Apr 19, 2010 | Televison & Video
Hi, the trouble with my hp 1022 is when i print something, in the printed paper appears a shadow from the original text. can you help me. thanks
use plane paper of 60-80 gsm if your printed paper is offset/screen print it will repeat and shadow appears because of high temprature in fussing unit.
Feb 03, 2010 | HP LaserJet 1022 Printer
Blue and yellow shadows appearing on my rear projevtion tv
The convergence IC's are definitely bad. This is not something you can fix yourself unless you know how to solder and are technically inclined.
Mar 29, 2009 | Philips Magnavox 51MP392H Rear Projection...
I have a LG plasma T.V., model 42PB4D. Black box/middle of screen
Try this:
In the menu go to CC and set the TV to CC1 as this is a text box appearing for captions. Hope this works!
Jan 11, 2009 | LG 42PB4D 42 in. Plasma HDTV
Panasonic 32
I have a panasonic satellite box and a Sony DVD recorder and I have been trying to put guide plus onto it without any luck, can you please help me.
Feb 08, 2008 | Televison & Video
Plasma TV Fault
What is the make and model #?
Jan 14, 2008 | RCA L46WD22 Television
Hit 53UWX10BA
convergance ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Dec 14, 2007 | Hitachi 57SWX20B 57" Rear Projection...
Gateway FPD2275W LCD Monitor Logo
221 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
