Question about ASUS M2N-MX Motherboard
No go This is a new system. I have hooked everything up. The green light glows on the motherboard. I have double checked the connections for the chassis to the motherboard. I have cleared the CMOS using the jumper to ensure that that was not the problem. What could be the problem?
  • Franklin Ramsey May 11, 2010
    I would ask that you list the components that you are hooking up to the motherboard as one of your problems could be that you are plugging in too much hardware without having a power supply that can handle it (or your power supply could be bad) or you might also be using the wrong type of power supply for the board (some power supplies only plug into the motherboard with a 20 pin connection when a 20 + 4 pin or a 24 + 4 pin is required). Also are you getting any beeps when you are trying to power the unit on?
  • 138 Answers
Try swapping your videocard to another one, a card that uses the pci slot perhaps. I guess the green lite just provides power ON indication.
Posted on May 09, 2008
I have a asus p4p800-vm motherboard I have everthing hooked up right the front panel wires power from the processor and power supply led lights hdd reset everthing but when I plug the computer up nothing...
Hi, maybe you should download a manual.
From here:
http://www.asus.com/Motherboards/Intel_Socket_478/P4P800VM/#download
Just to check you have connected everything right.
First select your operating system.
Select manual and click on global for download.
The file has to be unziped before you can read it.
Have you installed the ram module and cpu correct ??
If you have installed a wrong type of ram it will not boot at all.
Does it makes any beep sound ??
Is the powersupply ok ??
If you are useing the onboard graphic check for loose connections.
Check with the manual that all connections are in order.
Aug 28, 2011 | ASUS P4P800-VM Motherboard
My HP Pavilion a1050y won't boot up.
So you've checked the supply, but you didn't replace it, right? Sounds to me like that's your culprit. It's not able to supply the current to run the processor (the biggest draw) and the output is dropping too low to run the system. A new supply should get you running again.
Mar 06, 2010 | HP Pavilion A1050y (PU131AV) PC Desktop
First Hello. Before few days,when I turn on my PC(but I was unpluged my machine from electricity) and on monitor displays CMOS wrong set date/time,cpu frequensy.I hit BIOS set up sittings and Windows xp...
Replacing the bios battery was the correct thing to do. Answer me this. The Asus motherboard should have a green LED light lit (Standby power LED), when the system is turned off. Also keep the power cord for the power supply connected at all times. Though it is possible the replacment bios battery was all ready low on voltage or dead. When you're system is turned off the power supply continues to send 5volt DC to the motherboard which maintains the bios 3volt DC.
If the green LED is not lit than there is no power charging the bios battery and every time you boot the system the bios will have lost its settings. If the green LED is red in color, than the problem is within the standby switch built into the motherboard. The standby circuit can not be repaired. Double check all power connectors from the power supply to the motherboard. If everything has a good connection and you're bios settings continue to reset you should consider replacing the motherboard. At this point you have nothing to loose. Install the latest bios update,
(Beta Version 1010.005). 2006/02/14 update.
http://www.asus.com/product.aspx?P_ID=d2Gi3Hr6quXOk51C&content=download
Mike
Jan 23, 2010 | ASUS A7V880 Motherboard
Not powering on at all - I have been built a new computer from scratch with all brand new components. After hooking all of them up and plugging in the power source. Nothing is happening when the power...
1. Could be as simple as not having the Power Switch on the right jumper...double check.
2. The board will power up with nothing hooked to it... just power, CPU, MEM... disconect everything to just to get the board up to the bios.
3. Make sure PS is securly connected to the MB.
4. Check Jumper on the Board to make sure the Test Jumpers are not set
5. Memory is seated correctly... if you pull them out the board will start and beep...
Dec 31, 2009 | Gigabyte GA-G41M-ES2L Motherboard
Just installed the dq965gf motherboard and nothing is happening upon boot. I have everything hooked up. Whats going on?
Double check the power connection to the hard drive. Also, try a different power connector.
Then try just the hard drive without the CD plugged in.
I've seen systems not boot if the CD has a problem.
I don't know if you have an add-on video card, but if you do, be sure it's seated firmly. This, too, will prevent a boot.
Nov 26, 2009 | Intel DQ965GF Motherboard
Replaced power supply after the old one died and now all i am getting is a solid amber light on motherboard with a green blinking light on usb port
first off double check your power connections to EVERYTHING. sometimes those connections will loosen. if those connections are fine then its a faulty power supply or there isnt enough power going to everything. double check with your motherboards manufactor and see if you have enough power for everything if you dont a bigger power supply is needed
Nov 25, 2009 | Dell XPS 420 PC Desktop
Computer worked fine, unhooked it to hook up a new one, decided to hook the emachine back up to play games on, got it hooked up but it won't come on now. everything is hooked up right, i opened it up and...
make sure you hook everything with a little force especially the memory until it snaps back into place. same goes for all the cards. care should be give to the cpu, nice and easy. make sure your power supply is potential enough or has not gone bad. The MB can give a green light but there could be too little energy for the whole system.
Mar 27, 2009 | E-Machines Emachine T5026 power supply **...
Monitor light blinks
have you tried hooking the monitor up to a known working motherboard video or video card in a motherboard? it sounds like you may not have the settings in the motherboard correct jump the cmos clear to reset the motherboard connect everything then turn on your monitor then turn on the computer and get back to me in this thread.
May 05, 2008 | Computers & Internet
ASUS M2N-MX Motherboard Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
