Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Burning smell behind refregratot. After fan trggered there is burning smell like rubber burning.
  • Whirlpool Master
  • 1,606 Answers
First , clean the coils under the front of the refrig , with a vac . Then pull the refrig out and remove the back panel and check that the fan there in working . If not , remove any obstruction or replace the motor ( pt # 4387244 ) . If the fan IS working , then replace the overload/relay , which is plugged onto the side of the compressor ( pt # 8201786 (comes with instructions )) . Both are easily replaceable and will save you hundreds in repair costs . Note : Dirty condensor coils ( bottom front ) can cause the overload/relay to go out .
Posted on Aug 31, 2010
Microwave smell like burning rubber
Good Afternoon Friend,
I understand that you are receiving a burning rubber smell from your Frigidaire microwave. I also see that your appliance will run for a couple of seconds, and then you hear a weird noise, followed by a burning rubber smell. I suggest contacting your local authorized technician, especially when dealing with your microwave. They will be able to diagnose your appliance and determine what is causing that sound as well as the burning rubber smell. Hope this is helpful.
-Best Regards-
WP
Jun 17, 2014 | Frigidaire Microwave Ovens
Burning smell Kenmore 50558
If the burning smell is an electrical smell it could be motor or wiring problems which are best handled by a professional. If it smells like burning rubber it is probably the belt. If it smells like burnt wood it could be the belt slipping on the brush roll, if the brush roll is made of wood. Dust and debris can also accumulate behind the end caps of the brush roll causing friction which can cause a burning wood smell.
Mar 30, 2014 | Kenmore 5055, 50557 and 50558...
Fridge has a burning smell
Are the coils clean by the compressor?
Nov 26, 2012 | Frigidaire FRS23R4A Side by Side...
Strong burning smell coming from vents and from inside rheem electric central heat. Smells like rubber burning.
You must have to open it, try to clean it..and check for some eletric cables with short circuit or bad cables burning and overheating...check the motor fan and if it has a bad AC capacitor
check the photo, and you will have an idea.v4ndre_0.jpg Good luck!
Dec 06, 2010 | Heating & Cooling
Burning smell
Hi just read your posting.Now in my experience on your model of machine when you get a burning smell it is usually the pump.When the machine is draining the water and goes to spin do you get a burning smell then?Please try to look underneath the machine to the front right.You will should see the pump with a red or black fan attached to it.See if has any evidence of corrosion or leaking.Please reply with additional information and I can guide you throe rectifying this fault.
Jun 16, 2010 | Fisher and Paykel IWL12 Top Load Washer
Acceleration trouble, engine heat, rubber burning smell
Sounds a lot like a blocked catalytic converter...have it checked.
Jul 19, 2009 | 2002 Jeep Wrangler
Burning rubber smell and the dryer will not turn on
sounds like you need a new belt for your dryer, the smell of burning rubber is the belt slipping, thats my guess
Feb 09, 2009 | Dryers
Refrigerator burning rubber smell when it tries to turn on
sounds like the relay on the compressors is getting hot and cutting the unit out, if the fridge is quite old it may well be the run windings gone short circuit in the compressor pot. The relay switches from start to run windings so may be firing the start circuit, switching over to a shorted run winding, and then getting hot and activating the thermal cutout and hence the burnig smell, plus the start and rapid shut down of the compressor.
Mar 19, 2008 | Refrigerators
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
316 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
