Question about HP PSC 1610 All-In-One InkJet Printer
Prints only the top half of some lines.
I have changed the ink and cleaned the heads but when I print a page 3 to 15 lines will not have the bottom 10 to 50% of letters. I can't print anyting to send to anyone.
  • Winston41 May 09, 2008
    Tried it and it didn't work. Took the cartridge out again and hour later and wiped the contacts on the back and blotted the ink outlet. Then it printed like it should.
  • 51 Answers
Take the offending cartridge out and get a piece of tissue paper on your finger. Gently run the print head of the cartridge over the tissue paper. You shold see full lines of ink coming out. If not, the cartridge is out. If you see a full line of ink, reinsert the cartridge and do a clean cartridge from the tools menu
This should work
Posted on May 09, 2008
Prints half page
Printing half a page with an Inkjet machine is not normally a computer issue. So windows 10 would not normally have any effect on the printing for a printer that has been accepted by the Windows 10 Operating System. If there was an issue in the software it would be printing gibberish or not printing at all.
Printing half a page is quite possably something stuck in the printer stopping the ink from getting to that half a page if it is printing down once side but not the other.
Printing half a page being that the top half is printed but not the bottom half (Or the other way around) it could be an air bubble in the feed line which can be cleared with a printhead clean or two.
Printing half a line rather than a full line such as the top half of each letter is clear but the bottom half of each letter is not visable is a blocked printhead. A couple of printhead cleans can also fix this.
Also check to see if the printer is not confused and actually has empty cartridges even if the printer thinks they are full. Brother printers can easily get confused about ink levels. If the cartridges are actually empty, replace them and away it should go again.
Hope that helps
Mar 09, 2016 | Brother MFC-490cw All-In-One Inkjet...
XP-310 Changed black ink cartridge it now prints the bottom half of the 1st line, prints the next 4 lines and then 1/2 the next then prints the next 4 lines
Sometimes when you change ink carts on Epson printers, you can trap some air in the print head. Let the printer sit overnight, and then run a "head cleaning" followed by a "nozzle check". You can repeat the head cleaning up to 3 times before it doesn't really help any more.
Oct 15, 2014 | Epson Expression Home XP-310 All-in-One...
Canon pixma iP1000 is skipping random lines when printing
Sounds like it's congealed ink on the print head. You can buy cleaning kits and do it your self. Relatively in expensive compared to leaving it into the shop.
Nov 16, 2017 | Office Equipment & Supplies
Pages are coming out completely blank...ink is fulll...i have cleaned the print head
I'm saying the same below!
By mclamemo on Nov 12, 2009 " " re: C84 I'm using generic ink, but the red doesn't work at all. I've done all the printer cleaning programs and swabbed inside the printer with alcohol, and re-inserted the cartridge multiple times. it still doesn't print at all.
Also now even the black every few lines prints the top half of the line or the bottom half of the line, or its smeared, etc...
Help! +++++++++++++++++++++++++++++++++ I have learned from experience, that Epson2.gif does not like generic ink. You must use Epson Genuine Cartridges. Hopefully, you haven't screwed up the printer, like I did. I did try cleaning the heads and doing everything possible. Use 2 cartridges of ech set, for cleaning, cleaning, cleaning. ......But Nothing.
Had to go out and purchase a new printer.;
Good Luck :0(
Comments: Nov 12, 2009- Funny. hahahahah,
Me too! I would say, about 2 dozen cartridges to be exact.
lol :0) :0) :0) :0) :0) :0)
Asker's Testimonial " Thank you. Called Epson also and they didn't say it as directly, but advised real Epson ink too. Hope I didn't kill the printer! Generic ink for sale " - mclamemo
Oct 16, 2009 | Epson Stylus C84 InkJet Printer
Printer prints blank pages, have changed and installed new ink cartridges. wen through the head cleaning cycle bunch of times no luck. Any suggestions in fixing this?
Are you using Generic Cartridges? Pls See Below
Good Luck :0(
Oct 08, 2009 | Epson Stylus C84 InkJet Printer
Hp officejet, pro k5400 printer,when printing i get lines top to bottom on print,about 1 inch apart,tryed print head cleaning,changed the cartridges .need help ,top to bottom,only on...
That is ink or dirt on the rollers, you need to clean them by lifting the lid, as if you were putting new ink in, and wipeing the rollers that the paper runs through.
Jun 09, 2009 | Canon PIXMA iP5000 InkJet Photo Printer
Epson R230 printing unwanted lines
The problem is waste ink around head sprayer (at (bottom plate of head). Turn of printer. Move head to center. Put wet tissue (with hot water) at head cleaning mechanic pad. Move head to parking position. wait till 10 minutes. check it. You can repeat 3 times.
Jun 09, 2009 | Epson STYLUS R230 InkJet Photo Printer
4580 all in one less than 6 mos old started printing half lines
try to clean the print heads of the ink cartridges. you can do it in the HP solution center. you can run it through all 3 tests so you make sure its clean. if it doesnt work after that, your ink cartidge level might be off, because i hear they never work half the time anyways. i would buy new ink if the cleaning the heads does not work. good luck!
Nov 12, 2008 | Office Equipment & Supplies
Full ink cartriges print a few lines and skip a few lines
well..did you run a test page?
or clean the print heads?
or recalibrate them?
recommend all these steps for you
and as my 2200th solution, you are entitled to a FREE tuneup for good. find out more about that service here
Mar 23, 2008 | Canon PIXMA iP90 Mobile Printer
HP PSC 1610 All-In-One InkJet Printer Logo
215 people viewed this question
Seeker5211
Seeker5211
