Question about Compaq Evo N610C Notebook
Disabling touch pad
How do I disable the touch pad. there's no facility for doing this under controlpanel/mouse
  • 20 Answers
The touchpad should be able to be disabled through the BIOS.
Restart the computer, then push F10 to access the BIOS - if F10 doesn't work, try the other function keys and possibly the ESC key. You should find the option to disable the touch pad within the BIOS settings.
Posted on May 10, 2008
Laptop touchpad by finger not working but wireless mouse is working
It could be that your laptop is "smart" so basicly when you have the wireless mouse attached it disables the mousepad. But for more troubleshooting go to Controlpanel----> mouse to figure it out. Keep your head cool and try diffrent things out with logic.
Mar 25, 2013 | Acer Aspire 5610-4648 Notebook
I can't disable touch pad
There should be a touch pad icon in lower right where your tasbar is, right click for options to disable, if no luck! go into device manager, it will give a list of drivers, locate the touch pad, click on plus to the left and right click, there should be a choice to disable, click over that to disable.
Apr 22, 2012 | Computers & Internet
How do I disabled the touch pad and only use an external mouse and the keyboard on the lap top?
You do not have to actually disable the touch pad on this laptop to use an "external" mouse. Just plug in your mouse and it will install the drivers if needed and viola, your good to go. If you insist on disabling your touch pad however, you can do that by double tapping the top left hand corner, when you do this correctly, a little orange light will show and the screen will show a notification the the touch pad is disabled. To enable the pad back on, just repeat the same step you used to disable, and the on screen notification will indicate the touch pad is enabled!
Aug 04, 2011 | Compaq Presario CQ56-115DX Laptop
The cursor bounces around when I type, especially in Word. Do you know how I can correct this problem? I read that disabling the touch pad might remedy the problem; if so, how do you disable the touch...
As you type, your wrists could be close-enough to the touch-pad to move the mouse-pointer.
Click Start
Click Control Panel
Click Mouse
Change the setting to disable the touch-pad.
Dec 20, 2010 | Dell Latitude D610 Notebook
How do I disable touchpad when mouse is used DELL 1525 vista home
Follow these steps to change the touchpad settings on your laptop:
1. From the Start menu, click Control Panel. With Control Panel in Category View, click Printers and Other Hardware.
2. In the Printers and Other Hardware window, click the Mouse icon.
3. In the Mouse Properties dialog box, click the Device Settings tab, and then click Settings.
4. There is a setting calleed "Disable Touch Pad when USB Pointing Device is present"
Jan 28, 2010 | Dell F3534 Touchpad
Hi.my touchpad don't work at all!!I can't do anthting with my touchpad.
The pad may be defective buy a cheep wireless usb mouse for it and use it to work without the pad. the pads do wear out and the replacement would be over a 100 Bucks.
Jan 15, 2010 | Acer Aspire 5100 Notebook
How do I disable touch pad when using a mouse? ASUS K50IJ Win7 64 bit
To turn off the touchpad when an external mouse or other pointing device is present, you can goto the Control Panel and double click the Mouse properties icon.
Click the Device Select tab and check "Disable Touch Pad when USB Pointing Device is present." The cursor will no longer move via the touchpad.
Alternatively, you can permanently disable the touchpad of your laptop by clicking the "Disable Device" in the Touch Pad setting. Advanced users can disable the touchpad from the BIOS setup [press F2 when the computer is booting to enter BIOS settings]
Unfortunately, there are no keyboard shortcuts to enable/disable Touchpad movement or tapping. You can however drag the Mouse icon from the control panel to your Quick launch bar for quick access.
If that sounds too much effort, you may consider adjusting the sensitivity of the touchpad. This can be accessed from the Touch Pad tab of our mouse properties. Choose a low setting.
You can also go to link below to get help.
http://labnol.blogspot.com/2007/05/disable-touch-pad-of-your-laptop-avoid.html
Dec 30, 2009 | ASUS A6U Notebook
HOW TO DISABLE TOUCH PAD DELL LAPTOP
You should have a "FN" key on the keyboard and one of the "F" keys should have a symbol that looks like the touch-pad, hold FN while using this key should disable it, failing this in control panel, then mouse and pointers, you should have touchpad setting there should be a disable button/radius.
Sep 04, 2009 | Dell Inspiron XPS M140 Notebook
Mouse moves on its own
Your palm might be brushing on the touch pad while you are typing that is probably why the cursor jumps to a different location. as for disabling the touch pad I think that it is not possible unless you install a synaptics driver for your laptops touch pad.
Apr 01, 2009 | Gateway Laptop Keyboard for MX6930,...
Disabling touchpad
dmusick,
  • Goto Start -> Control Panel then double click on Mouse
  • There you will find the to make disable your touch pad.
  • Also there might be a key (button) near touch pad this key toggle your touch pad on/off.
Thanks
May 18, 2008 | Computers & Internet
Compaq Evo N610C Notebook Logo
88 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
