Question about Parrot MINIKIT Bluetooth Hands-Free Kit Wireless Headset
Bluetooth wireless headset bluetooth model:N65 SN:06809028380 Made in China search for devices Enter passcode plez passcode fond plez plez
    President:
  • 1,932 Answers
Passcode for parrot MINIKIT is 1234.
thank you
Posted on Aug 31, 2010
How to operate
"First, turn on Bluetooth and Bluetooth visibility in your phone. This makes your phone visible to other Bluetooth devices.
Headset instructions:
  1. Make sure that the headset is fully charged, turned off and within 1 m (3 ft) of the phone.
  2. Press and hold the On/Off button for at least five seconds, until you hear along high frequent beep and the light flashes red and green.
  3. The headset is now in pairing mode.
  4. If your phone supports auto pairing, press Yes when the question "Add device?" appears in your phone. If not, continue with the next step.
  5. Prepare your phone according to the phone instructions on how to add a Bluetooth device. Please note that for some phones you may need to enter a passcode. The headset passcode is 0000.
Phone instructions (NB: these may differ a little depending on phone model. For exact instructions, see Pairing instructions for the specific headset and phone model on www.sonyericsson.com/support.):
  1. Enter the main menu and go to Settings, then select the Connectivity tab.
  2. Select Bluetooth > My devices.
  3. When New device appears, press ""Add"".
  4. The phone starts searching for devices. Make sure that the headset is in pairing mode.
  5. When the headset becomes visible in the Devices found menu, highlight it and press ""Select"".
  6. Enter the Passkey (0000 by default) and press ""OK"".
The headset is now added to the list of paired devices and is ready to use."
Mar 26, 2011 | Sony Ericsson HBH-IV840 Bluetooth Headset...
I am using xperia X10...and i want to connect to my HBH-GV435 bluetooth to this phone..but the HBH-GV435 blue tooth is already paired with some other phone.so i want to reset the bluetooth and connect it...
Headset-
1. Make sure the headset is fully charged, turned off and within 1 m (3 ft) of the phone.
2. Press and hold the On/Off button for at least five seconds, until you hear a long high-pitched beep and the light flashes red and green. The headset is now in pairing mode.
3. If your phone supports auto pairing, press "Yes" when the question Add device? appears in your phone. If it doesn't, continue with the next step.
4. Prepare your phone in accordance with the phone instructions for adding a Bluetooth device. Please note that for some phones you may need to enter a passcode. The headset passcode is 0000.
X10-
1. From the Home screen, tap the applications bar.
2. Tap Settings > Wireless controls > Bluetooth settings.
3. Mark the Bluetooth check box.
4. The phone starts to search for the device. Make sure that the device is in pairing mode. If needed, tap Scan for devices.
5. When the device becomes visible in the Bluetooth devices found list, tap to select it.
6. If needed, tap the text bar to enter the passcode (0000 by default) and tap OK.
7. You can now start using the paired Bluetooth device. The status of the pairing and connection is shown below the name of the Bluetooth device in the Bluetooth devices list.
Good Luck!
Mar 23, 2011 | Sony Ericsson HBH-GV435 Bluetooth Headset...
Cant pair my wep 500 with my phone
passcode = 0000 (4 zeros) USER GUIDE
The first time you turn on the headset it will enter "Pairing" mode. In this mode you can connect your headset with your phone or other Bluetooth enabled device. If you have already connected one device to the headset, you can enter Pairing mode by holding the multi-function button turns solid blue.
Once in pairing mode, set your phone or other Bluetooth enabled device to search for the headset. While each device is different, the setting is often found in a "Settings" or "Bluetooth" menu and the "Search" or "Discover" Bluetooth devices option. On the list of discovered devices, choose "Samsung WEP500" and select "Yes" or "Ok" to connect to the device. When asked for the passkey, enter 0000.
Feb 05, 2010 | Samsung WEP500 Wireless Headset
Can't pair
You have to search the device from your phone and enter the passcode when it is detected.
Make sure you have enter the correct pairing code and your phone has bluetooth 2.0.
Jan 28, 2010 | MyNetDeals BlueAction Wireless Bluetooth...
Ive lost my instructions for my headset device i need to know how to turn my phone to headset pairing mode
Hello my friend,do these steps
Pairing with another Bluetooth device
By pairing your KU990 and another device,
you can set up a passcode protected
connection. This means your pairing is
more secure.
1 Check your Bluetooth is On and Visible.
You can change your visibility in the
Settings menu.
2 Touch Paired Devices then New.
3 Your KU990 will search for devices.
When the search is completed Refresh
and Add will appear on screen.
4 Choose the device you want to pair with
and enter the passcode then touch OK.
5 Your phone will then connect to the other
device, on which you should enter the
same passcode.
6 You passcode protected Bluetooth
connection is now ready.
Using a Bluetooth headset
2 Follow the instructions that came with your
headset to place your headset in pairing
mode and pair your devices.
3 Touch Yes to Connect now. Your KU990
will automatically switch to Headset profile.
If you have any questions you can try reading the manual here
http://www.in.lge.com/Product/Manual/KU990.pdf
Jan 11, 2010 | LG KU990 Viewty
IPhone wont connect to V12
click on "settings"
click on "General"
click on "Bluetooth"
If Off, click it ON
It should start searching for devices to pair with (make sure your other device is on and "discoverable")
If the iphone locates the headset it should prompt for the code.
Mar 05, 2009 | Blueant Caller ID V12 Bluetooth Headset...
I cannot connect my handset.
Turn on your cellphone's bluetooth, try searching for a new device. If found, select Jabra BT150 and enter default passcode "0000". Nice bluetooth headset, Goodluck.
Dec 13, 2008 | Jabra BT150 Wireless Headset
Lost instruction to my bluetooth device
first u have to check ur device support bluetooth and on uf device bluetooth on ur bluetooth device also and find device and it will show moto 700 then pair it u have to enter passcode and ur done passcode is 0000
Jul 02, 2008 | Motorola Mobility H700 Wireless Headset
Parrot MINIKIT Bluetooth Hands-Free Kit Wireless Headset Logo
300 people viewed this question
Top Parrot Radio Communications Experts
Hjalmer Lamminen
Hjalmer Lamminen
Bill Boyd
Are you a Parrot Radio Communication Expert? Answer questions, earn points and help others
