Question about Linksys Wireless-G Broadband Router
Linksys wireless adapter
I'm having trouble getting my adapter to aquie a valid ip address. Any suggestions?
  • Franklin Ramsey May 11, 2010
    It would help if you gave more information such as the model of the adapter, what operating system you are using, and if you are getting any error messages.
  • 156 Answers
Reset your modem and reset your router...Wait a few minutes and try again. I
f you need to hold the reset button on the router in for 10 seconds to default the router to factory... then reset the modem again. wait a few mins and try again.
If your still having the same problem let me know here and we will resolve it.
Posted on May 09, 2008
Using a linksys wireless g usb adaptor and can't get an Ip address
If you are not getting ip address on it in that case,please check its connect wireless,
one very important thing is security key(if it is incorrect ,you won't get IP on it)
Hope it can resolve your query
happy to help
Thanks for using Fixya
Apr 03, 2010 | Linksys WUSB54GSC Compact Wireless-G USB...
Laptops stopped connecting wireless
how about to reset your router and setup it the proper address by your internet provider..
laptops only connect to the router automatically if you enable it reconnect and detect its network without manually connect internet, this procedure can see in your wireless properties by enabling it.
And also ask your internet provider if theres a problem also with their internet connection.
Jul 18, 2009 | Linksys WRT160N Wireless Router
Linksys Wireless-G not connecting to internet
Make sure you are plugging the SMC into the WAN port on the Linksys router and not the LAN ports.  Your internet connection (which is your SMC) should always plug into your WAN port on the Linksys.  Any computers that you may need to plug in, like Desktops that are "wired" and not "wireless", should plug into the LAN ports on the Linksys.  If you are not using the WAN port on the Linksys for your SMC modem, then that would explain why you cannot get to the internet on wireless or wired computers.
Here's why you are getting the "low connectivity" message:
Computers don't understand why the Internet is connecting or not connecting...so the "low connectivity" message you keep receiving has nothing to do with your wireless signal strength.   To a computer NIC, "low connectivity" means your network adapter could not find a DHCP server and receive a valid IP address.  When this happens, your network adapter assigns an IP address to your computer in the following range...169.254.0.0, and will display the "low connectivity" message until it is able to receive a valid private IP address from the DHCP server.  You can verify this by going to START | RUN and typing "cmd" (without the quotes), then hit ENTER.  A black box will pop up....then type "ipconfig" (without the quotes) and hit ENTER.  This will show you your IP address, subnet mask, and gateway address, and you can verify that your IP address is in the 169.254.0.0 range.  A valid private IP address is typically in the 192.168.0.0 range, but could also be in the 10.0.0.0 range, or the 172.16.31.0 range.    Also, make sure you have DHCP server enabled on the Linksys router for the LAN.  This will ensure your "wired" and "wireless" computers receive a valid IP address.
The WAN port on your Linksys router should be configured to "Obtain an IP address automatically using DHCP".
Cheers!
Apr 19, 2009 | Linksys Wireless-G Broadband Router
Connects to Access Point but the internet cannot be found
The main reason why you have this error message because your computer is not getting a valid IP address from teh wireless network, and the reason why its not getting a valid IP address is the wireless security or sometimes called WEP/WPA kay are not type in to the correct place, If you have a WEP enable on your wireless network you will have two option on the Linksys WLAN monitor where you can type in teh security key, you will see two boxes there when you try to connect to the secured network one says Passohrase and one says WEP key1 and if yuo have a wireless key that has a total of 10 or 26 key character you need to type that on the WEP key1 box leave the passphrase blank...But if it still didn't work you can contact this number for help 1-877-787-8749....
Oct 15, 2008 | Linksys WUSB54GSC Compact Wireless-G USB...
I can't reach my ip to change my lan config
yeahlife,
The default IP Address for Linksys routers is 192.168.1.1. You may want to try accessing your router's configuration by typing this IP Address in your browser.
If you have any additional troubles, please let me know.
Regards,
moriarti5
Jun 02, 2008 | Linksys 2.4 GHz 802.11b Wireless - B PCI...
Wireless router
My suggestion would be to first disable any encryption on the router to make your wireless network simple first to try and troubleshoot these problems. check if any MAC or IP Address filters are active on the wireless router, you can either enter the IP address of the slingbox wireless adapter or its MAC address if you HAVE enable filtering, but again, try diagnosing without filtering or encryption enabled. Also ensure your slingbox wireless adapter has its settings set to 'automatically assign IP address (enable DHCP)' so it gets its address automatically.
May 04, 2008 | D-Link Wireless
Will not connect
If the connection is correct, make sure that the tcp/ip settings on your pc is set to OBTAIN IP AUTOMATICALLY. There might be a STATIC ip set on your adapter.
Mar 13, 2008 | Dell 1450 (D1450U) Wireless Adapter
Computer found router before why doesn't it now?
Download Network Magic (no need to buy, free one will work) once installed look at your network map, you should see your router click on it and note the IP address. Type this address into your browser.
Dec 09, 2007 | Linksys Wireless-G WGA54G 802.11g/b...
Problem connecting to the net
You router may be set to be DHCP enabled so that it allocates the ip addresses automatically to each pc, so check that the pc's network card with connection problems is set in the properties on the TCP/IP line is set to obtain an ip address automatically. You can also try, Start>run then type ipconfig /flushdns to clear the pc ip address and dns. and restart pc. Lastly if you pc is both network cabled and wireless, ensure one or the other is dissabled as this can confuse the ip adress alocation.
Apr 29, 2007 | Linksys Wireless-G WRT54GR Router
Linksys Wireless-G Broadband Router Logo
22 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
