I need the master and slave pin settings seagate st3160215ACE.
    President:
  • 1,851 Answers
Here is the way for setting the jumpers on your disk:
In case you need the whole manual here is the link for you to download it.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on Aug 31, 2010
I need the installation book to install it.
The power connector (Molex) has a red wire (one of four) - the data wire has a red stripe on one side - the red stripes go toward each other. If you have a 80 conductor data ribbonn cable, this is for "Cable Select" position in the shorting plug. If yours is 40 conductor, you are NOT cable select. The Master or '0' drive goes at the end of the cable while a slave or '1' drive attached to the plug close to the end plug. The other plug of course goes to the mother board. Look for a small '1' on the motherboard (red srtripe). Use either Cable Select (if appropriate) or Master (if appropriate) or Slave (if appropriate) when selecting the shorting pins on the back of the device.
For your info, the little connector you will find inside adjacent the Molex is called a Mini Molex.
The Master is where the device "C" should reside (and have your operating system). All other drive designations will be set by your BIOS.
If you need more help, go to www.seagate.com/support and look up your drive for complete instructions. I think they have downloadable "tools' there to help you as well.
I hope this information helps you ... Thanks for your quesiton @ FixYa.com
Feb 14, 2012 | Seagate DB35 ST3160215ACE - 160GB -...
Reset pins to original position
There is normally a pin diagram printed on each Seagate disk drive that would show you the correct pins for setting the drive as a Master, Slave or using Cable Select.
Jan 10, 2012 | Seagate (ST36423A) 6.4 GB Hard Drive
Need to know where to set slave pin
The pin settings are nest to the power connector.
If the location is not shown on the label then it will be marked on the circuit board.
MA = Master
SL = Slave
CS = Cable select
Sep 28, 2010 | Seagate Barracuda 7200.7 ST380011A 80 GB...
How to set master, slave settings in sata hdd
In first HDD put the jumper in first vertical pair of pins from power socket side, it will become master and second HDD put jumper in second vertical pair of pins from power socket side it will become slave.
Regards
Ashly
Feb 02, 2010 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Can I use this Hard Drive as a slave on my PC ?.
Hey,
Ofcourse you can, look at the top of the hard drive to find the jumper settings lable, change the jumper so the drive is slave.
Then connect it to your computer with a ide cable, if you have another hard drive on the same cable the other hard drive needs to be set as master, and be preferably on the end of the cable and slave on the center of the cable.
Then check your bios / cmos / cmos setup / computer setup, right when you turn on the computer to see if the hard drive is detected and properly installed.
heres a video on how to use bios
http://www.wonderhowto.com/how-to/video/how-to-use-bios-69712/
if everything is okay it should show up in windows, if it doesn' then right click on my computer, select manage, then on left side select disk management, you may have to initialize and or partition the disk first before it shows up on my computer.
Thanks and good luck.
Ekse
May 05, 2009 | Computers & Internet
WD drive won't work as master when Seagate 80GB drive connected as slave.
The jumpers on the Seagate must be set to slave.
otherwise they are conflicting for the Active partion and bootloader.
Regards
Richard.
Apr 26, 2009 | Western Digital Caviar WD200BB 20 GB Hard...
Slave jumper setting
SATA drives don't have jumper settings.
You can set master/slave in BIOS.
Mar 29, 2009 | Seagate 500GB Maxtor Diamondmax21 SATA2...
Computers & Internet Logo
410 people viewed this question
David Payne
David Payne
