Whirlpool top loader stops and starts within the cycle
  • rbrotherssr May 10, 2008
    Model LSR 7010PQ2 Westinghouse
    Genius:
  • 1,073 Answers
What is the model number of the washer
Posted on May 09, 2008
Whirlpool washing machine top loader will not rinse or do final spin
If your machine fills and agitates through the wash cycle and then stops, check the lid switch.
http://www.youtube.com/watch?v=bV8C6aLBL9w
Mar 03, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care will not stop spinning
I work on these every day for the past 8 years and have never once seen this problem. If i had to guess i would assume its a stuck contact on the timer. The timer is the only thing that sends power down to the motor but its an expensive guess.
Hope this helps _MJ_
Jan 29, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
How to change the belt in my whirlpool washing
It's probably the washer transmission. Belts aren't common anymore & besides it wouldn't work at all if there was a belt broken.
Jun 18, 2009 | Whirlpool Washing Machines
Door switch problem top loader
I fixed mine with a toothpick and a piece tape. Make the tab on the door longer that activates the switch. Try triming the lid bumpers
Apr 09, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Very loud shuddering noise when spin cycle stops
thats what happening,,the brake needs a little wd 40,,lube,,when unit stops the tub yanks.....
Dec 22, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
You either have a defective pressure switch or water inlet valve. Start to fill the machine with warm water so that both solenoids on the water inlet valve (hot and cold) are activated. After about 30-60 seconds, push the timer knob in to stop water flow. If the water continues to flow, replace the water inlet valve. If this is the case, it may take a few times of starting and stopping water flow to allow solenoid to heat up and become symptomatic. If water flow stops abruptly each time knob is pushed in, you most likely have a defective pressure switch (water level switch).
May 09, 2008 | Whirlpool LXR9445JT Top Load Washer
Washing machine - knocking sound at end of cycles
Hi there is it a top loader or front? If a front loading machine it might be the concrete block has come loose under the top cover.
Thanks J
Feb 26, 2008 | Whirlpool LSB6200KQ Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
