Question about Panasonic Office Equipment & Supplies
Why is my projector not switching on - Panasonic Office Equipment & Supplies
  • Panasonic Master
  • 17,130 Answers
Can vary from the fuse , surge protectors and possible compoents in the SMPS, the swittch mode power supply.
So use a meter to check for short inthe SMPS, if so check after suspectng on the rectifier, the filter capacitor or the OSC/DRIVER output. If not on the primary side and all voltagesare correct, then a short onthe seccondary side can switch offf the SMPS with the feedback current limiter. If so you will need to check one by one to disconnect and find the voltage build up to center on the fault.
Posted on Aug 31, 2010
  • 1 more comment
  • Bram Jan 30, 2011
    Some models do have an option to disable all the controls, including ON/OFF/SBY. E.g. Panasonic PTL720 has the option FUNCTION ON or OFF.
    To reset the FUNCTION back to ON do the following, POWER ON/OFF toggle switch to ON, the RED SBY light must come ON. Press and HOLD the ENTER button and simultaneously press the MENU button for more than 2 seconds. The blower shall turn on and the RED SBY light shall turn GREEN. Projector is now ready for normal ops.
    Regards Brasto
  • Bram Jan 30, 2011
    Regards Brasto
  • SCAdmin Dec 13, 2012
    Brasto's suggestion worked for me.
Shows a blue screen
Make sure power is plugged in and power switch set to on.
Make sure TV or projector is plugged into video out.
Make sure the input switch is set to Main and not video in.
Nov 20, 2009 | Elmo Projectors EV-200 Slide Projector
Projector won't switch off either with the remote
Im sorry but it needs a new switch. i can help with ording online.
Oct 26, 2009 | Sharp XV-Z2000 Multimedia Projector
When you are watching on projector sanyo PLV-Z2 it goes off and
overheating. possible fan malfunction. clean out the projector with canned air. dust keeps in the heat.
Oct 24, 2009 | Sanyo PLV-Z2 Multimedia Projector
Optoma projector overheat issue - fan comes on but switches off
Most projectors have air filters. Yours may need to be removed and cleaned. No air flow = overheat.
May 28, 2009 | Optoma EP721 Projector
Sharp pgm20x switches off immeately after switching on
It turns out that i fixed this issue, I opened up my projector and took a look at the board to make sure that there is nothing wrong. It turns out that the projector needed a good cleaning. Just use caned air to clean out the projector make sure that all the vents are clear and not blocked. (note: do not spray the caned air while the bulb is hot, if you do this the bulb can cause the pressurized air to temporary flame up, Please make sure the projector has had at least 30 minutes to cool off) While the board is off press the power button and the projector should power up. Replace the covering, and this projector will work.
Jul 10, 2008 | Sharp Notevision PG-M20X Multimedia...
SWITCHES TO MEMORY STICK
If you unplug the unit for a few hours prior to use this will fix the problem .
Apr 12, 2008 | Sony VPL-HS20 Multimedia Projector
No image
1-SWITCH YOUR PROJECTOR OFF.
2-CONNECT EVERYTHING AS NORMAL CONNECTION.
3-SWITCH DOCUCAMERA ON.
4-SWITCH YOUR PROJECTOR ON.
5-CONFIRM THAT INPUT OF PROJECTOR IN RIGHT INPUT TO CAMERA.
6- CONFIRM THAT CAMERA CABLE IS GOOD BY PLUGING IT IN VIDEO INPUT OF ANY TV.
Mar 06, 2008 | Epson - PowerLite S1+ Multimedia Projector
No access to half of menu
dry solder joints or bad input placement. Try jiggling the vga port on the projector or use a different projector
Jan 26, 2008 | Optoma MovieTime DV10 Multimedia Projector
804 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
