Question about Autodesk AutoCAD 2010
Autocad 2010 not responding windows 7 , first five days working fine but this time not working. curcer not moving. aplication only hanging.
  • 71 Answers
SOURCE: I have an issue with autocad 2010 on windows 7. im
have you tried add/remove programs in control panel, then reinstall? if it was recent it could be a service or process still running in the background. check the task manager and make sure there are no applications or process still running. please rate me if this helps. thanks and good luck!
Posted on Sep 18, 2009
RescueTechLA
  • 2653 Answers
SOURCE: AutoCAD 2004 / Windows 7 compatibility?
If it works in Vista you shouldn't have any problems. Easiest way to find out is to install it!
You can always just uninstall the program fi you run into problems.
Posted on Dec 06, 2009
  • 13 Answers
SOURCE: Autocad hanged
1. Please check your computer specifications. Normally 2010 Autocad, require a good ram and video card.
2. It also hangs when opening a lower version of cad file.
Posted on Mar 29, 2010
  • 644 Answers
SOURCE: Autocad 2010 hangs at startup
autocad is a graphical program so it does **** up resourses of the pc, the graphics and the memory being most effected, the solidworks 2010 is also high end program that needs alot of memory and graphical resourses, so as the computer gets more used and the hdd starts to fragment you will see the pc hanging more in the programs, my advice would be to upgrade the pc's memory and graphics and defragment the hdd more regullar. hope this helps.
Posted on Aug 21, 2010
SOURCE: when I install autocad2004 in
yes can be, just follow these steps:
Not compatible or not working well with windows 7?
Maybe, It doesn't work because the driver/application you installed is for other versions of operating system. I am also using windows 7 like you so don't you worry, You can still use your old installer/driver from other versions of operating systems. Just remember that before installing any program in a windows 7 Operating System Computer, Use "troubleshoot compatibility". Right Click the Icon of your program installer/application first, then choose "troubleshoot compatibility". This will allow you to choose on what type operating system your program will run. Just reply back if it still doesn't work.:D rate and vote for me:))
Posted on Dec 06, 2010
AutoCAD Windows 7 64bit
AutoCAD 2008 is not supported to run on Windows 7 (2010 is the first release that is). Try running the OS in XP / Compatibility Mode for increased performance.
Philip
AutodeskCare' Community Manager
TW ' PI ' YT ' BLOG
Aug 17, 2012 | Autodesk AutoCAD 2008
Autocad 2009 hang when i open it
Open up Windows Task Manager and look under the Processes tab and see if WSCommCntr2.exe is running. If so stop this process and see if this makes a difference.
Feb 03, 2011 | Autodesk AutoCAD 2010
HOW WE INSTALL AutoCAD 2011 ON WINDOW 7
how to install autocad 2011 step by step
Sep 09, 2010 | Autodesk AutoCAD 2010
How to install autocad 2004 in windows 7
I had no issues installing AutoCAD onto a Windows 7 x86 Professional system. User is making and saving new drawings as well as opening existing drawings.
AutoCAD 2004 works fine on Windows 7 Professional 32-bit.
Aug 04, 2010 | Autodesk AutoCAD 2004 for PC
Autocad hanged
Jan 12, 2010 | Autodesk AutoCAD 2010
I am trying to install AutoCAD 2004 on my new computer with windows 7 and wont install. Any ideas?
AutoCAD 2004 and Windows 7 are NOT compatible. You will need to upgrade to AutoCAD 2010 either 32-bit or 64-bit. Even with the upgrade, there are known limitation issues.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=14056444&linkID=9240617
Jan 03, 2010 | Autodesk AutoCAD 2004 for PC
Autocad 2010 problem
If you run Win7 in XP mode, all should be fine.
May 06, 2017 | Autodesk AUTOCAD LT 2008 SLM 10 SEATS...
Unable to initialize adlm at windows vista
use Autocad in windows 7 is great. vista is **** and doesnot support most of problems. i use autocad 2010 in windows 7 with no problem.......
Nov 05, 2009 | Autodesk AutoCAD 2010
Autodesk AutoCAD 2010  Logo
745 people viewed this question
Top Autodesk Computers & Internet Experts
JM Computer Service
JM Computer Service
Jerry
Jerry
Are you an Autodesk Computer and Internet Expert? Answer questions, earn points and help others
