Question about Garden
Hi there! I recently bought a second hand Partner 352 - (Electrolux / Husqvarna) chainsaw 35.2cc. Still in pretty good condition... starts up first pull every time! Just one problem... the bar is not getting oil. I cleaned the bar, 2 x oil holes etc. I took off the bar and chain and ran the motor to see if I could find some oil coming out... nothing. Found this little hole, stuck a thin metal pin in to see if there might be a blockage, so a few drops came out (this little pipe goes all the way straight into the oil tank) Is that the oil feeder or just a breather pipe? I decided to throw out the oil inside the tank and found some wood chips inside. Any ideas? Ewan
  • 76 Answers
SOURCE: Chainsaw oiler issue
THE FIRST THING I WOULD CHECK IS THE BREATHER IT HAS TO LET AIR IN SOMEWHERE AS THE OIL FLOWS OUT IT MAY BE CLOGGED TRY RUNNING THE SAW WITH THE OIL CAP OF DONT DO ANY CUTTING JUST RUNSEE IF IT OILS THEN IF NOT MOST SAWS HAVE A OIL FLOW ADJUSTMENT SCREW TAKE THE BAR OFF AND LOOK AROUND WERE THE OIL COMES OUT THE ONLY OTHER THING IT MAY BE IS A CLOG IN THE LINE
Posted on Jun 25, 2009
  • 76 Answers
SOURCE: husqvarna 235 oil not getting to chain
try using thinner oil
Posted on Jul 16, 2009
dontbother10
  • 2220 Answers
SOURCE: husvarna chainsaw hole in oil lubrication tank
J-B Weld is probably your best option. Cleaning it so it adheres properly is the hard part. Did you ask your local Husky dealer? They may have some options the average owner does not. Phone calls are inexpensive.
Probably cast aluminum, maybe magnesium. HTH and Good Luck.
Lou
Posted on Feb 16, 2010
Testimonial: "thank you for your help problem is now solved"
nedkelly900
  • 345 Answers
SOURCE: The oil pump on my Husqvarna chain saw is not
oil pump failure, common on husqvarna
Posted on Apr 28, 2010
wentlanv
  • 710 Answers
SOURCE: I have a husqvarna 137
Hi marcus,
The bar and chain oil goes into the oil tank on the side. The oil for the engine is mixed with the gas before filling the gas tank.
Hope that helps.
Handy Andie
Posted on Mar 20, 2011
Replace oil pump in partner 352 chainsaw
The oil pump on this saw is located in the oil tank. Access it by removing the bar and chain, then the metal cover over the oil pump. You will see the oil pump and oil line.
Jul 06, 2014 | Husqvarna Partner K650, K700, K750, K950,...
Husqvarna 141 starts with choke and then cuts out
If the chainsaw has been used recently i would say It sounds like the screen filter inside the carburetor is dirty item # 507432582 or the metering diaphragm is dried out item # 530035165. Also check that the fuel lines are in good shape. If that doesn't solve your problem you should do a pressure and vacuum test to check the seals and gaskets.
Feb 01, 2014 | Husqvarna Garden
Husqvarna k750 partner starts and runs fine up to limiter but will only idle for a few seconds then dies
I had a saw with a similar problem. I beleive you need a new carberator. I changed mine and my saw never ran so good. I think from all the vibration all the shafts/bushings have wore and now air is being sucked in from too many unwanted places keeping enough vacume to **** the gas out of the carb bowl.
Sep 24, 2012 | Husqvarna Partner K650, K700, K750, K950,...
Looking for the intial setting for the 2 screws on side of carb on k750
Hi, most, if not all chainsaws start with both hi and low screws set at 1 and 1/4 turns out, but when you turn the screws in, don't turn them tight-soft metal! Mark the screwdriver and turn them out , once chainsaw started the high speed screw can be turned in one eighth. The tickover is turned in just enough that sounds right and the clutch isn't engaged!
Aug 03, 2012 | Husqvarna Partner K650, K700, K750, K950,...
Partner k650 wont start when warm
This is a pretty common carb issue, the needle in the carb is leaking, if dirt has been throgh it then the needle seat will be worn, the only answer to this is a new carb unfortunatly.
Jul 08, 2012 | Husqvarna Partner K650, K700, K750, K950,...
I bought it second hand and it won't start
Take out the plug, earth the plug to the side of the engine with insulated pliers (otherwisw you will get a shock) switch the on switch on and give it a pull - Look for a strong blue spark from the plug. If it is not the ignision it is the fuel supply. They are a good saw. Good luck!
Aug 11, 2010 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Husqvarna 2100 runs for only a few seconds
Hi, I spent most the day yesterday fighting the same problem on my husqvarna 45. My symptoms were that it ran for 2 seconds then died. The spark plug would come out wet, and if I kept cranking the starter, I could see gas coming out the exhaust. Obviously flooding.
It turned out to be the inlet needle valve being stuck open. I replaced the needle valve, still no luck. This is the valve that regulates the gas coming into the carb, normally pushed by a float. Chainsaws use a rubber diaphragm instead of a float because they need to run sideways.
I had a closer look at the cavity the valve fits into (two pairs of reading glasses!) and saw some greenish hard stuff that my carb cleaner spray would not remove. So I took an electrical tye wrap that's width matched the diameter, and rotated it till the crud was gone. A wooden bamboo skewer or toothpick might also work, don't use metal.
Reassembeled, and runs fine. Your carb may be a Zama which has a good technical guide online: TechGuide_2007.pdf. Walbro diagrams might also be online. Good luck.
-Chris
Aug 27, 2009 | Husqvarna Garden
Hi the spring on the pull cord isnt working, how do i fix it please. partner electrolux chainsaw p/n 958900234 s/n/ 01-049254
They have split off Electrolux and are now part of the Husqvarna Group.
I found this web site but it is primarily for industrial tools. I'd try contacting them, you have nothing to lose. If you find a parts source please advise of where.
https://ecommerce.husqvarna.com/order/index.jsp?brandid=HC&COMPANY=UAS
Atta boy/girl for providing make, model and serials. GL
Lou
Apr 02, 2009 | Garden
Chainsaw Service manual for Husqvarna in New Zealand
here's a Contact in your Area:
Husqvarna New Zealand 15 Earl Richardson Avenue, Manukau City Auckland
Auckland
New Zealand
Tel: +64 9 920 2410
Fax: +64 9 920 2429
Web: http://www.husqvarna.co.nz
E-mail: carol.osborne@electrolux.co.nz
Nov 17, 2008 | Husqvarna Chain Saw 20" Bar
Garden Logo
344 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
