Garmin Nuvi 660 GPS Receiver Logo
Posted on May 09, 2008
Garmin 660 locked up / frozen
I was just listening to an audibook I loaded onto my 660 and the nuvi locked up suddenly and now is frozen with the screen on. the touch screen does not work and the power button has no impact. any advice? also, does resetting the nuvi erase anything saved on the unit (ie maps, audio books, favorite lists, etc.)? Thanks!
  • Anonymous Mar 13, 2014
    frozen on welcome screen
Anonymous
Level 1:
Problem Solver:
  • Contributor 18 Answers
  • Posted on May 09, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
18
Questions
0
Helped
2290
Points
28
Resetting the device merely resets the power connection, on some devices there is a reset to manufacturer defaults on settings, but not your stored data. Working with GPS's 40 hours a week I constantly have to use the reset button when they lock up. Just press it in for a few seconds then if it doesn't power back up just hit the power button and everything should be fine.
My garmin nuvi 600 screen freezes
screen says it lock cannot change anything
4helpful
My garmin nuvi 660 is frozen . how can I do?
Reset the nuvi 660:
1 Disconnect from external power.
2 Flip antenna up.
3 Locate and press small button labeled "RESET" in the antenna recess on rear of nuvi 660.
4 Connect to external power source.
The nuvi will reset, power up and operate normally. If this was helpful, please rate it 4 thumbs up - thanks & good luck!
Will my garmin play music?
Yes, if it has a media player. The 660 will. It will play MP3's but you have to load the MP3's onto the GPS using a USB cable between the GPS and your PC.
- Jim
SHARCNET-USA
Can I do route planning on my pc and then load it onto my Garmin nuvi 1310.
Mapquest will let you download your maps into your Garmin
On the Mapquest page sent it to ......you will see Garmin unit there
My garmin nuvi 660 na is locked and i cant unlock it
There should be a small pinhole for a reset button. Press and hold this reset button for 60 seconds. Then turn the device back on.
How do i download music from my itunes file into my garmin nuvi 650?
You will have to convert them to MP3 format and then load them onto your NUVI.
2helpful
Cant enter pin or screen is frozen
Look near the SN # and press the reset button.
or
with the garmin off, hold down the right bottom of the screen and turn the garmin on, it will then ask you if you want to perform a hard reset. Choose yes and that should fix your problem.
Garmin nuvi 660 frozen
I did connect it to the computer via my USB cord - a Garmin menu came up and after opening a couple of the choices the Garmin was workable again. I don't really know why. But all is good here.
Top Garmin GPS Experts
vince
Jesse Walters
Jesse Walters
Are you a Garmin GPS Expert? Answer questions, earn points and help others
