Question about Gateway FPD1975W 19" LCD Monitor
My monitor come on and shut off when my coumptor come on i get black screen what is problen
  • 11,361 Answers
First, try it with another PC to make sure it is not the PC problem, if it still does not work then you will have to open it up. Power supply caps and backlight inveter circuits will have to be troubleshoot. Please post back what you see inside first.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Aug 31, 2010
Why does screen go black after a few seconds
Hope this helps.... Your monitor has an inverter issue. You know it's an inverter problem when:
1. Your monitor starts normally and displays the startup/desktop screen for a while.
2. Then it suddenly goes off, leaving a blank (black) screen or a very dim display.
To fix this black screen problem, change the inverter board (based on your monitor brand).
Source(s): http://lcdmonitorrepair.annics.com
May 05, 2014 | ASUS VK193D LCD Monitor 19-inch - Black
Screen stays black but lit when shut down
If the monitor led is indicating stand by and it seems as if the monitor is still on, could be a sign of an aging monitor. As long as the led changes along with the function of the monitor there's really no way to indicate the monitor still on after shut down especially when the led is amber telling you it's on standby mode.
Mar 01, 2014 | Acer Aspire Zs600 All-In-One Desktop Pc,...
I have a computer monitor that has suddenly gone to a black screen with this note: "out of frequency range set resolution lower or see monitor instruction manual. How do I do this if the screen is black?
if you have a video card in your PC shut down, remove the card and this should do it, if you want to install the card again, shut down re-install card, and it should also work
Dec 29, 2009 | Compaq CV 7500 (Carbon, Silver) 17 in.CRT...
Monitor goes black after running for a few minutes. Brand new 22 inch sceen.I prees the button to turn it on and it says Analog and goes black again. I have to shut down the computor to get it to come back...
Sounds like the computer is shutting it down and the monitor is fine. Check for viruses then check your settings in device manager for the screen saver and power down (screen off) options.
Aug 10, 2009 | Dell Computers & Internet
Lg 17" moniter power disconceted after 3 or 4 miniutes & many time power not on what is the problem
check ur power connection from wall socket to ur pc.....also make sure its tight to ur screen....including all othere cables going to screen
if this not solves the problen bring ur monitor for service........could be a problem inside with power pac
Jul 03, 2009 | LG Flatron F700P 17" CRT Monitor
Dell monitor goes white when computer shuts down
does the monitor stay white after shut down or does it go back to a black screen?
Jun 26, 2009 | Acer Aspire One PC Notebook
My screen stays black but my pc is on
it sounds like your mointer is ****, i highly doubt the game caused it. try another mointer, or sell that one on ebay and buy a new one
Jun 14, 2009 | HP Computers & Internet
Monitor flashes on then goes black.
I think you have the display shut off. the button on the bottom left will shut screen off. It will come on for a few seconds if you touch the screen, but will shut off again. just push the display button again and it should stay on.
Apr 02, 2009 | ViewSonic OptiQuest Monitor
Starlogic 20 inch widescreen monitor screen keeps going black
This is probably a back light problem. Take a bright flashlight and while the monitor is on, point it at the LCD and try different angles, etc. If you can see an image, it is the back light, probably the back light voltage converter unit in the lcd. It could also be the back light bulbs.
If you don't see an image with the flash light, then it could be the main logic board.
ort11
Mar 08, 2009 | Computers & Internet
Gateway FPD1975W 19" LCD Monitor Logo
29 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
