SOURCE: how do you connect awa
Hi.
Only audio connectors at the back of this combo are audio in. This combo has no audio out. If you had an headphones out jack you could connect using a Jack/RCA audio cables connector. I haven't seen an headphone plug in this TV. Unless there is an headphone connector, this particular TV will not allow any audio output connection, hence no way to connect directly sound to an ordinary stereo.
If you are using a sound system, the HDMI cable also carries sound. You can try routing signal from HDMI out to a BRD player or DVD, and then use the audio out from the DVD.
