Question about Hyundai Televison & Video
SERVICE MANUAL FOR HYUNDAI TV HU-25N01 - Hyundai Televison & Video
Head torq settings for hyosung gt250r
Hi, Nickey sorry you can't find the first and best tool you ever bought for your Hyosung despair not for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://www.hyosung.hu/download/pdf/data/service-manual/GV250-GT250-EFI-service-manual.pdf
http://www.hyosung.hu/download/pdf/data/alkatresz-katalogusok/GT250%20PARTS%20CATALOGUE.pdf
http://www.hyosung.com.au/downloads/manuals/GT250.pdf
Hyosung GT 250
Apr 16, 2016 | Hyosung Motorcycles
How to remove blinker on a yamaha fz6
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Turn Signal Removal Installation
removing stock turn signals
http://fz6.uw.hu/service/2004-Service-LIT-11616-17-50.pdf
OEM parts for Yamaha
http://fz6.uw.hu/service/2005-Owners-LIT-11626-18-43.pdf
Jun 28, 2014 | 2005 Yamaha FZ6 Fazer
Abs light on yamaha fz6
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $ you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
ABS problem or need brake pads
Had the Fazer into the shop for the ABS light flashing
Apr 19, 2013 | 2007 Yamaha FZ6 Fazer S2 ABS
Need a code for a hyundai television serial number 6011604481
HYUNDAI HU-TV2121 processor N403 KALORA HHEN16MD01.Videoprotsesor LA76810A - the very bottom hidden button (right of the circuit), click once highlighted FACTORY. More P + and P-switching options.
HYUNDAI C2910, C2519, C2988
1. Set the volume -0
2. Press the remote button "MUTE"
3. While holding "MUTE", press "MENU" on the front of the TV.
4. On the top right corner will light up the letter "D", and in the left corner shows an adjustable parameter and its value.
5. Pages menu change button "CAL"
Switching parameters conducted green and red buttons on a blue field panel. Change made a yellow and blue buttons on a blue field.
HYUNDAI H-LCD2000
To enter service mode simultaneously press "MENU" and "STANDBY".
Press "MENU" again.
HYUNDAI, ITT 29M03 C2131 chassis CPU M37160M8-064FP
In the main menu code 6, 4, 8, 3.
Tools submenu contains the switch to the next of which is done by putting 6, 4, 8, 3.
HYUNDAI 359, 387, 8FHIFI, CB5373Z, 6578F processor CCU SEL04 / SEL07A
Mode 1: Close contact in the hole near the keyboard and just press "S"
Mode 2: Close contact in the hole near the keyboard and just press "S" again and click on contact. Exodus - LOAD.
HYUNDAI processor SAA1293-03-03 SAA1293A
With remote control TV "Horizon" graphics without clicking "SERVICE", the indicator shows a CH, a paz-click on 'appears OP, then choose the volume of registers numbers "1-4" and numbers "1-9" change bits. Then click on "Memory" (you can also lock the pins 15 and 23 in the control circuit SAA1250). Exodus - POWER OFF.
HYUNDAI
chassis CCU11 - "•?" (C) (H)
Chassis CCU12 - close contact in the hole near the keyboard and just press "S". Exodus - LOAD.
HYUNDAI chassis M1, ITT, NOKIA, SALORA 6390, 7190, MV4000, PL14 24 101 852 SAT SOLI, 882 SAT SOLI, 885 SAT SOLI processor CCU-SALO-07 (CCU20XX)
entrance "C"> "*"> "O / V"> "#"> "M". Exodus - "power".
HYUNDAI chassis EUROSTEREO-1. DIGIVISION 1963 .. 2, 1971 .. 2, 2 .. N6 processor NES3-... NES2-..
Log "-/--" "MENU" "TV" - for a second. Exodus - POWER OFF.
HYUNDAI chassis STEREO PLUS. 5575SFN, 28T7 processor ST92T93
Entrance - "i" "M" "P +", output - TV.
HYUNDAI 3875EX DIGIVISION
Gun "AV7 universal" fully fit.
Sign in service "1-/11. (Button with painted upper corner). TV must be turned on and display a feed.
Recommended initial value: V.AMP-027. V.LIN-038. S.COR-020. V.POS-023. H.POS-041.H.AMP-022. P.TILT-013. P.AMP-024. P.CORN-007. GREEN-032. RED-032. BLUE-032. V.BRE-005. LUM.DEL-000. AUDIO-032.OPBYT1-002. OPBYT2-064. OPBYT3-000. PRLOSK-000. RESERVE-000. Writing in memory - click "E".
Memory 24c08 can put a clean, turn on TV it propyshe processor itself.
from electronics-planet .blogspot
Jun 12, 2011 | Hyundai Televison & Video
I need free of charge users guide for hyundai tv model hu-d34
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download if available, by model number, Customer Instruction Manuals, list of Dealers, for spare parts and service, Driver downloads and Installation Instructions as required.
This is the best way of ensuring up to date drivers for your system and they are free of charge!
I hope this helps.
Jan 23, 2011 | Hyundai Televison & Video
I need users guide for hyundai tv model hu-d34
If you were to log on to the manufacturer's web site, I think you may be pleasantly surprised as usually, if available, one is able to download, by model number, Customer Instruction Manuals, list of Dealers for spare part supplies and Driver downloads (if applicable) as required.
The information is normally free of charge.
I hope this helps.
Jan 23, 2011 | Televison & Video
Dears; I have hyundai tv it's model(HU-TV25051T), and when i switched on the screen turns blue screen and has a closed padlock on the top left corner, what can i do to make the tv work normally? please...
U have a lock codes password.Enter ur password?Tries press 000 enter,might reset the codes and release it.Don't know lock codes is impossible to release,tv a couple years old.
Mar 22, 2010 | Televison & Video
TV screen shows 'SKYWORTH' when turned on. Activated this by mistake and can not get back to previous mode. This caused channel reception to be bad and all channels are either not showing well or showing...
HI I have the same problem There are things you can do... For the tuning problem I suspect changing the "RF AGC" will fix that. You need to go into service mode. Turn off TV then hold Vol + and - on front panel and turn on. The TV will come up with extra service menu. Just keep pushing menu till you see "RF AGC" and dont change any values untill you write down what they are or take photo etc. Then just change the "RF AGC" value and see how you go with the tuning. ALL THE BUTTONS ABOVE ARE ON FRONT OF TV. NOT ON REMOTE....Hope this helps....
Jun 10, 2008 | Televison & Video
Televison & Video Logo
145 people viewed this question
Top Hyundai Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jay Seifried
Level 1 Expert
Are you a Hyundai Televison and Video Expert? Answer questions, earn points and help others
