Question about Garden
411a keeps stopping on for 4 mins off for2 mins on forabout 3 mins then off again and so one
  • norhod Aug 31, 2010
    hansons repair dept in preston says no thermal switch in this particular machine
  • 905 Answers
This is a Karcher #411a, right? Just wanted to make sure about the manufacturer.
From the symptoms that you are describing, your motor is cycling on the thermal overload protector. For some reason, the protector is heating up, tripping (opening the circuit to the motor), and when it cools down, allows you to use the pressure washer a little bit longer.
Given the fact that most of the pressure washers are stored outside in a shed or in garage, consider disassembling your washer. You are looking for nests made by insects (be careful!), as well as to locate the overload protector.
If your water pump is detriorating (losing oil perhaps), it may be putting a higher load on the motor, causing it to heat up abnormally.
I wasn't able to find your exact model #, perhaps there is a product # on the name tag as well. This site has a listing of all the Karcher part and assembly manuals.
Posted on Aug 31, 2010
  • Sheldon Dedek Aug 31, 2010
    If there is not a thermal protection in / on the motor, then the fault lies in 1 of 3 other areas:
    1) Wiring connection is heating up, losing contact, cooling, and re-establishing contact.
    2) GFI protection, if equipped, has an intermittent connection
    3) The pressure sensor is having issues.
    Since "Hansons Repair Depot" in Preston obviously has experience and will be able to physically check out this unit, I suggest that you take your pressure washer to them for repair / refurbishment.
    2) Motor Protection, if equipped, has an intermittent connection
Siemens iq 750 keeps stopping after 3/4 mins of drying
Is your water jacket empty? Could be something simple like that.
Aug 07, 2016 | Siemens Dryers
Change coil packer all 4 ok forabout two week now trouble starting now and again
CHECK THE MODULE COIL PACK MOUNTS ON, CAN HAVE INTERMITTENT ISSUE, RUNS WARM BUD HARD START COLD IS COMMON PROBLEM AREA
Mar 10, 2014 | Car Audio & Video
1997 Plymouth Breeze Engine keeps shutting off.
You need to do an OBD2 engine control module fault code test to see if the fault is recorded in the memory of the computer control module. Autozone and others do this testing for free.
Jun 24, 2017 | 1997 Plymouth Grand Voyager
Alarm c1 oil pressure
check oil level srart for2 seconds disconect the -- earth of your battery let for 15 min conect then start after 10 min.
Aug 09, 2012 | Cars & Trucks
Heater motor
its under dash on right side 3 to 4 bolts 7mm or 1\4 one plug one vent tube unbolt ( if new fan dosnt come with new blade pull c clip pull off put on new)
Jan 14, 2012 | 2001 Pontiac Grand Am SE
How to forward a sms in lg gt540.i dont find any forward option
Just keep your finger on the sms for2-3 seconds. Then a menu will pop-up... One of the options given is what you need...
Lazaros Mavridis
Dec 05, 2010 | LG GT540 Cell Phone
Karcher pressure washer 411A. loss of pressure...
411a when i turn on it gos for 1 min then i have too press it on and off 3or 4 times befor it works and it only stays on for 1 min.
Mar 07, 2009 | Karcher K2.26 Electric Power Washer
RCA HD52W59 color goes green then black screen
This set has flyback problems. you would need to check a few things to make sure. What about RP020 is this open? Check also RP231 and IP190. Check make sure all cables are seated properly too. For more info visit ctechnicians.com
Jan 03, 2008 | RCA HD52W59 HDTV Projection Television
Garden Logo
156 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
