Question about Tecnik TKL9290 Front Load Washer / Dryer
Tkl9290. How do you open the door after wash finished?
Red light will not go out so I cannot open the door
Generally machine take time approx 5 minit to open automatically open the door if not open please check door switch or pcb
Aug 07, 2016 | Washing Machines
Zanussi washing machine FA 621-622 or FA 626-674. I cannot open the door after the wash programme has finished
make sure the wash prog has really finishe, & try to cut electricity before you open the door
Jul 02, 2011 | Zanussi Washing Machines
Indesit wd 125. Wash cycle had finished, door lock was off but
Unplug machine, take lid off and locate the door lock. You will have to use a small screwdriver or something to release the lock. Then replace your door handle.
Jan 19, 2010 | Washing Machines
The wash is finished but the door will not open?
You door switch is most likely faulty.
Open the drain filter door in the bottom corner of the machine. See if you can locate a lever or ring to pull down. This will manually release the door.
Regards
Ash
Oct 21, 2009 | Miele Washing Machines
Door will not open on my WM1480FHD after wash
Hi ii_goldie,What about the RINSE cycle... maybe the washer knows the "full cycle" is NOT finished.
The washer will display DONE... and make the door available to you. If not the cycle may not be finished. OR, turn it off, however, DON'T open the door if your machine has not drained all the water out, allow the system to finish.
Aug 19, 2009 | LG Washing Machines
Washing Machine won't spin
Could be worn carbon brushes, or possibly defective shock absorbers
Mar 26, 2017 | Tecnik TKL9290 Front Load Washer / Dryer
A problem with my Bosch washing machine
It usually takes 2 minutes after the wash to open the door; do not force the door. Doesn't matter if the active light is on. Just try.
Oct 05, 2007 | Washing Machines
Washing Machines Logo
46 people viewed this question
Top Tecnik Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Tecnik Washing Machine Expert? Answer questions, earn points and help others
