Question about Panasonic Kitchen Appliances - Others
Keep warn light is ok but cooker light doesn't work
    New Friend:
  • 50 Answers
Check if there is a continuity of the cooker light by using vom tester, if there is a continuity it means the cooker light is ok. also check the connection maybe it is loose..
Posted on Sep 01, 2010
My battery light comes on while driving for about a minute than goes off the alternator and battery are fine i had it checked
The Battery warning light comes on because the Alternator output voltage has fallen below the voltage (about 12.8 volts DC) required to keep the battery charged, this low Alternator voltage causes the light to come on while this condition is happening. In your case unless the Alternator is tested while the battery warning light is on it will test ok/no problem. The battery itself doesn't turn the light on, only the Alternator malfunctioning. I would think you have a part called a "Diode" failing in the alternator or a wiring issue at the alternator connector(s), either way you need to isolate the problem, it will get worse and you will end up with a no start.
Oct 17, 2011 | 2002 Mazda Tribute
Hi There,i need to know,my russel hopps steamer is making a beep sound the whole time. what am i doing wrong? the sound is very annoying
Hi, ok I also had that problem whereby the steamer keeps on beeping. It's a warning alarm. we need to fill the steamer with water directly into the reservoir and NOT into the side. the side is only for top up during the steaming process.
Hope this helps.
Sep 27, 2011 | Russell Hobbs RHST3 Rice Cooker
My igniter on the cooker doesn't work, it doesn't click or make any sound
Here is a tip that I wrote to give details about why your cooktop will notspark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
May 17, 2011 | Ovens
Slow cooker light does not come on and crock does not heat up when plugged in
Have you checked another receptacle? If you plug it into a known good receptacle, and it still doesn't work, it's broken. You should just buy a new one.
May 06, 2011 | Rival SCVP609 6-Quart Slow Cooker
My rice cooker, its not responding. Panasonic SR G06. power is ok , but its just dont want to cook! why??
check replace the micro switch of your rice cooker it is the switch that is connected to the cook and warm button....check for the heating ellement it is the coil that heats to do this open the bottom cover of your rice cooker you can see a round shape fillament examin whether this fillament is not brocken and is connected to the power source
May 20, 2010 | Panasonic SR-W06NA 3-Cup Rice Cooker
Presure weight plastic is off
You can remove the plastic cover from the vent valve and it will work fine. If you remove the plastic cap, you will need to manually tilt the valve with a utensil to "quick-vent" the cooker. Watch out for steam burns! Should work fine after that. You need to unplug the cooker and re-plug it to reset the "E4" error message.
Feb 13, 2010 | Wolfgang Puck 5-Quart Electronic Pressure...
Hob broken
It sounds like the wiring has broken down inside the cooker at the terminal block or a leg of power is missing if the cooker is supplied by three phase electricity. Then there may be a problem in your service panel. Is it a 3 segment circut breaker or 3 fuses in the panel?
Dec 29, 2007 | Ovens
Kitchen Appliances - Others Logo
178 people viewed this question
Top Panasonic Kitchen Appliances - Others Experts
Irene Tulloch
Are you a Panasonic Kitchen Appliances - Other Expert? Answer questions, earn points and help others
