Question about Philips 23PF5320 23 in. HD-Ready LCD Television
No or bad video
I have a very dark screen when using the tuner.. too dark to watch... and with any av source there is no display but the sound is fine
  • electroman25 May 21, 2008
    PHILIPS 42PFL7422D/37 42-inch 1080p LCD HDTV. I'm having the same problem with my 42"lcd hdtv. The lcd screen is completely dark, the sound is fine and clear, you could somehow see some kind of movement in the background of the dark screen. Nothing else works. Anyone with advice, solution or any help will be very much appreciated. Thank you all so much
    Scholar:
  • 72 Answers
The picture is really dark but u can see movement on the screen, right ? Sounds like you might have a bad inverter on you LCD, a bulb burnt out or a faulty power supply. Problems to an lcd are not very many. More than likely bad lcd on each side of LCD panel there is a board that has a cable running from the power supply to it. Probably 8 to 14 pin connecter. If u have a meter check the DC voltage were the pin connector plugs in. 2 to 6 pins in a row should read 12 to 24 ( all should read the same) the other pins on the connecter will be a ground. Oh make sure the Inverter that u are checking is the Master and not the Slave.
Posted on May 09, 2008
We have a digital tv but an anologue vcr so we bought a strong srt 5430 so we can record through our vcr but are having trouble conecting the vcr and set top box
You need a cable to go between the yellow (picture), red and white (sound) sockets on the strong to the VCR.
Those cables will connect to one of the VCRs AV inputs. You then need to use the VCR remote control to switch from the now defunct analogue tuner to the Line or AV input. Put your TV on the channel you use to watch video tapes. Switch on the Strong receiver. Do the switch to the Line or AV input on the VCR. When your VCR is on the correct input then you will see the picture from the Strong receiver on the TV. You can confirm it is the correct source by displaying the Strong's EPG.
When you come to make recordings, the Strong will need to be left on the channel that you want to tape. If your TV already has an aerial feed and isn't relying on the strong for its signal then you can watch another channel on TV.
Aug 27, 2014 | Televison & Video
Palsonic tv wont work in television mode only works when watching movies on av mode
did you try source you need to get out of Av if you have it sounds like the tuner could be faulty
Apr 15, 2013 | Televison & Video
While watching tv through the cable connection I get just static. but when I swithch to video mode or play a PS3 game, i see the picture just fine. What can I do to fix this.
You may have a bad cable fitting or a bad tuner--you have actually answered your own question:
Way around this issue is to connect a cable box that has the audio/video output jacks on the back to one of the rear AV inputs and BYPASS the tuner completely---watch cable from that input and change channels with the box.
May 25, 2012 | Toshiba 51H94 51" Rear Projection HDTV
I cant change my VT2230-M to the tv setting. I turn it on, the power light turns blue, and then the parrots come up. then the Monitor goes blank.
I had the same problem. It appears to be due to a bad tv tuner. Turn on your computer and leave the coax unplugged. Leave it for a while (15-30 min). When you see "snow" on your screen, you will be able to use the source button to change to another input and see if you can get a signal. I am running my cable through a dvd recorder and using the AV input to watch tv. Also, my HDMI, component and RGB work fine. After thank don't try to access the TV source until you have had your tuner replaced.
Apr 12, 2011 | ViewSonic VT2230 TV
Sanyo lcd-32k40 features
  • Model: Sanyo 32K40 Multi System LCD TV
  • World-Wide NTSC/PAL/SECAM Color System - Watch any video signal on this TV!!
  • World-Wide NTSC M, PAL BG, PAL I, Secam BG, DK/ PAL DK TV tuners
  • 32 inch LCD TV with 3 HDMI inputs and PC input
  • USB input for direct media playback
  • 45,000:1 Dynamic Contrast: While viewing either very bright or very dark scenes, it can be difficult to distinguish main images which blend into the background.
  • Dynamic Contrast dramatically mitigates this problem by adjusting the backlight intensity, providing up to a 4X improvement in contrast.
  • 6.5ms Response Time
  • Widescreen 16 X 9 Format
  • World-wide Dual Voltage 110-240 volts 50-60 hertz
  • HDTV monitor (HDTV tuner required for HD reception)
  • This is a multisystem TV. All Multi System TVs in the market do not have a digital TV tuner: What does this mean?
  • To watch digital channels (ATSC Broadcasting in US and DVBT broadcasting overseas) you need a digital source/tuner like a cable box, digital tuner, satellite service, etc.
  • To get the best quality video on this TV you need a source that has a digital connection like HDMI or component.
  • Wide Screen Mode allows you to watch conventional 4:3 aspect ratio broadcasts in wide screen (16:9) mode.
  • Steady Sound® equalizes volume levels so there is consistent output between programs and commercials.
  • Built-in hidden speakers includes 2 (5W x 2) speakers to deliver dynamic sound.
  • Component Video Input offers the best video quality for DVD (480p and 480i), and digital set-top box (1080p, 1080i, 720p, 480p and 480i) connections.
  • PC Input allows you to connect your PC and display the PC screen on your TV.
  • Surround Sound Audio Effect
Mar 04, 2011 | Sanyo 42 in. LCD TV
Philips 32PFL5322D/37 Black w/any of the analog inputs. Tuner ok
WHEN IT BLACKS OUT, GENTLY PUSH OR TAP ON THE SCREEN. YOU SHOULD SEE A SLIGHT WHITE DISCOLORATION WHERE YOUR PUSHING. IF THIS HAPPENS YOU PROBABLY NEED A MAIN TOTAL ASSY. DO YOU STILL HAVE AUDIO WHEN IT BLACKS OUT?
Sep 25, 2009 | Philips Televison & Video
I am getting sounds only out of my tuner selection (radio) source
I would start off by doing exactly that removing the black box tuner out of the equation. The next question is did you install the black box or did you have someone else install it for you. If the box is not installed propperly then the audio outs could not be wired up correctly. Double check all of your connections. It could be something as simple as bad or no power to the box.
Mar 01, 2009 | Crossfire VR1000D Car Audio Amplifier
Dark screen
the sound is locked off the TV good picture
Feb 20, 2009 | JVC AV-27320 27" TV
Input feed problem
I would suggest using the AV inputs instead of the coaxial input. It looks like there might be a tuner intermittent failure but using the AV inputs bypasses the tuner.
Good Luck.
Jul 21, 2008 | Proscan PS50670 50" Rear Projection...
MY TV!!
try using AV im puts with dvd or vcr if this work your tuner is bad new cost aruond $90 to 120 if available but next year you wont have use for it
Sep 25, 2007 | JVC AV-48WP74 48" Rear Projection...
Philips 23PF5320 23 in. HD-Ready LCD Television Logo
44 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
