Question about HP ScanJet 2400 Flatbed Scanner
Hi, Im using HP scanjet G2410. when I scan, it is showing one thick black line in the middle of the scanned copy. please give me a reason and solution. Thanks in advance .
  • 466 Answers
This kind of problem - continuous black lines - is usually caused by a speck of grit or dirt on the scanner head. The dirt is immobile in relation with the head, so the latter "sees" black wherever it goes. It's possible that the head is damage, but that is a very rare occurrence indeed, while dust is far more frequent.
You need to remove the protective glass (be careful when releasing the lock, and use gloves if possible - fingerprints may be inconvenient to remove; use solvent-free window cleaning fluid and a little water, in case) and clean the head using compressed air and a soft, lint-free cloth. Then reassemble.
In some models - don't know about the G2410 though - it is also possible to reach the head from two small openings on the sides of the platen glass. You launch a scan, so that the head moves from its resting position until it's nearest the openings. Then unplug the power, thus marooning the head in a reachable position. Most compressed air cans come with a thin straw which will allow you to reach the head without opening the scanner (and voiding the warranty, more often than not). CAREFUL not to invert the air can: the white spray of freezing liquid (it's not really "air") coming out from an inverted air can may damage or permanently stain the scanner head. If the grit is visible and the opening large enough, you may even be able to arrange its removal with a long thin wooden skewer or even a drinking straw.
Posted on Aug 31, 2010
In hp g2410 scans only the page top properly , remaining page is scanned as black inB&W or greenishyellow if color
it is not a problem with the scanner,are you closing the lid everytime??,your settings are not correct,or update the drivers, HP Scanjet G2410 Flatbed Scanner
Jul 11, 2015 | HP Scanjet G2410 Flatbed Scanner
How to increase scanning speed in hp scanjet g2410
Install the drivers for it from the HP website. Other software for it should be there as well. As to scanning speed, setting it to scan at lower resolutions can speed scanning. Scanning for color is slower than scanning for Black and White, FYI.
Aug 16, 2012 | HP ScanJet Office Equipment & Supplies
We have an HP MFP 3035 which shows a blackline at the middle after scanning using the bulk scanning features. How do i resolve this?
11_16_2011_11_06_05_am.jpgClean marked area with good squeezed wet cloth, ensure that no marks should not be deposited on this area...
Nov 16, 2011 | HP LaserJet M3035 MFP Printer
How to scan in hp scanjet g2410
First install the required drivers for the HP Scanjet G2410 Flatbed Scanner.
Simple way is to scan is use PICASA
GOTO http://picasa.google.com/
Download picasa 3.8
  1. Make sure everything is connected and turned on!
  2. Put the photo on the glass of the scanner - face down
  3. In Picasa, click 'Import'
  4. Click the arrow for the drop down list of devices. You should see your scanner listed ... select it
  5. Now you will see a screen that depends on your scanner. There should be an option to 'Preview'. Click that.
  6. You should now see your picture, there may be some settings you want to change here, but if it looks OK then
  7. Click the button to Scan
  8. When it's done scanning, you're back at the standard Picasa Import screen. Click Import all.
  9. Select a folder to put it in. I made a folder called 'Old Photos' for the first one, then, for each subsequent scanned photo, I selected that existing folder from the drop-down list.
If you satisfy with my solution please rate/vote for me.
Rating/Voting will encourage me to help others
Jun 09, 2011 | HP Scanjet G2410 Flatbed Scanner
Black lines on scan
Dear all
I have the same problem Please Help
Mark
Jun 04, 2010 | HP ScanJet 2300C Flatbed Scanner
Lamp error in HP Scanner
It would cost more to replace the scanner assy than a new machine would cost you.
Nov 17, 2009 | HP Scanjet G2410 Flatbed Scanner
Hp scanjet G2410 not sending email documents to outlook express
scan using Scanner and Camera Wizard
1.From "My Computer" right click the appropriate Brother FAX, MFC or DCP machine.
2.Select Get picture using Scanner Wizard.
3.Click "Next" at the welcome screen.
4.Select the save options that you require and click "Next".
5.The Wizard will now start to scan using the settings you specified.
6. Select the "Nothing. I'm finished working with these pictures" and click "Next".
The images will then be saved to the the location that you specified in step 4.
later you can attach the scanned file to your outlook express.
Sep 03, 2009 | HP Scanjet 4470c Flatbed Scanner
Horizontal Lines
This might be a hardware problem, but it could also be caused by an outdated (or corrupted) driver; you could uninstall the original driver, then download and install the newest version directly from HP here:
http://h10025.www1.hp.com/ewfrf/wc/product?cc=us&dlc=en&product=446435&lc=en&jumpid=reg_R1002_USEN
If that link is broken, or doesn't work for you, use this one:
http://tinyurl.com/2n7lge
Also, I've copied the following information directly from the HP 4850 Scanjet user's manual:
If you have the HP Image Zone software installed, you can use the onscreen Help to solve other problems with the scanner. To gain access to the Help, open HP Solution Center, click Help, and then click HP Scanjet 4800 series scanner Help. The Help system provides information about the HP Scanjet 4800 series scanner hardware as well as information about the HP Image Zone and HP Scanning software itself. Also, see Scan troubleshooting in the general Troubleshooting and support section of the Help.
Good luck with this; let us know what you learn...
Jan 26, 2008 | HP Scanjet 4850
HP ScanJet 2400 Flatbed Scanner Logo
675 people viewed this question
Seeker5211
Seeker5211
