Question about Refrigerators
Refrigator oart is not working
Refrigator is on but temperature is not working
  • 828 Answers
Is your refrigerator a frost free model? If so do you have any frost in the freezer compartment such as on the back wall? It is possible that you have a defrost cycle problem, or your condenser coil where heat is transfered to the outside air is restricted, or your refrigerator could have a leak of refrigerant and with the
Posted on May 09, 2008
How to repair a refrig
Sounds like a temperature control module issue. If you have a little time, patience and technical knowhow it can be a simple fix. Google your make and model number with the term "+temperature control module" and it should help get you there.
Jun 12, 2014 | Refrigerators
No Temperature in Refrig
It indicates that there is problem with your thermostat .
How old is your refrigerator ?
Are you facing this problem frequently ?
SAM ANDERSON
Sep 30, 2008 | Amana ABB1924DEB / ABB1924DEW / ABB1924DEQ...
Refrigerator area is freezing, frost forms in the back (not visible) Visible only if you take it apart. temperature goes from 34 to 46 in temperature on a RS257BARB. We took it apart and defrosted back...
the defrost heater under the evaporator in the freezer or if in the refrige section which is a heater grid in front of the evaporator is bad,or the defrost thermostats in either case near the evaps could be bad,or the adaptive defrost controls in the refrige area could be bad too
Aug 01, 2010 | Samsung RS2630SH Side by Side Refrigerator
Refrigerator cold control doesn't work; temperature stays at or below freezing. Freezer control OK.
check the damper door between the refrige and freezer compartments,its behind a plastic cover,if its iced up in the fully open condition it will allow too much cold air into the refrige,if this is the case defrost it with a hair dryer and recheck operation,otherwise the temp control in the refrige is bad
Mar 18, 2010 | Refrigerators
My refrig is freezing items on the refrig side.
likely a bad temperature control. also, some model GE's have a bad fresh food inlet cover, that fails to cutoff airflow from the freezer.
Feb 19, 2010 | Refrigerators
Kenmore refrig/freezer. freezer side is cold,
Check your condenser coil (should be below the refrig.). If dirty, you can clean it with a condenser brush from Home Depot or Lowe's. Turn the appliance off while cleaning. Be careful not to damage the refrigerant tubing (copper). If this doesn't solve the problem, then there may be an issue with the defrost thermostat, defrost heater(s) or the main temperature control assembly.
Contact an appliance service company.
Feb 17, 2010 | Kenmore Refrigerators
Whirlpool Model ED5SHAXML12 is freezing food in refrigerator even when dial is at off. Happened from one day to the next.
At the refrig controls , the freezer control , controls how much air goes into the refrigerator section . Open the refrig door , and up at the top left , put your hand over the damper (air vent) . Turn the freezer control from high to low , and feel the difference in the air flow . If you turn your freezer control to a lower setting , less cold air will enter the refrig . Think of it as : the freezer control adjusts the temperature , and the refrig control , tells how long to run the compressor . In actuality , this is how it works . However , with the dial (refrigerator thermostat) in the off position and refrig still running , this indicates a bad thermostat . Pt # 2198202 .
Sep 09, 2009 | Whirlpool Refrigerators
Frost inside and ice on floor of freezer
The water can only come from 2 places, the drain is blocked or the ice maker is over filling.The temps are too good to have any other things going wrong. Let me know, Thanks, Sea Breeze
May 18, 2009 | GE Refrigerators
I can not find the freezer temperature control
this model refrig does not have a seperate freezer control. the only control will be the refrig control. thanks peyton
Feb 26, 2009 | Hotpoint Refrigerators
Kenmore 50392
We were low on freon . This refrig's internal fans don't run until the proper temperature is reached
May 21, 2008 | Kenmore 53092 / 53094 Side by Side...
Refrigerators Logo
113 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
