Question about Microwave Ovens
I need to get a replacement burner for a Chef Consul gas stove. Who, if anyone, stocks these parts?
  • 1,711 Answers
Posted on Aug 31, 2010
I have a Magic Chef microwave MCO160UB. I was cooking on the stove (microwave wasn't on) and the fan came on as it has done before. After a few minutes, it shut off and is now completely dead. I...
If the microwave is above the stove, the heat sensors in the microwave
may turn on fans to cool it even though the microwave itself is not
running. It tries to save its life. It should turn off when the stove is not
heating it.
Aug 29, 2011 | Magic Chef MCO160UB Microwave Oven
Oven will not heat up. The Oven igniter glows but the gas pipe does not light up. The broiler gas pipe at the top of the oven lights and so does the stove top burners. Do I need to replace the Flat...
Microwaves use a magnetron to emit the waves, they make a very characteristic (and loud) humming sound when they 'kick-in.' If it is not making this sound that's your problem. It is not a user-replaceable part so please take it to an appliance repair shop, or purchase a replacement (which will probably be the same or lesser cost than repair unfortunately.)
I hope that this will help in solving the problem....
Aug 08, 2011 | Microwave Ovens
I am disassembling a Kenmore stove top gas burner to clean under the stove top. To do so you actually need to unscrew the burners, which I've done, but then I need to unhook the spark electrode, which...
The electrode is held onto the burner head with a screw through the mounting tab. They can get crusted over and it's not always easy to see the screw head, but it's there.
Jul 04, 2011 | Microwave Ovens
Magic chef gas stove model # 3468vvv making clicking noise
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Apr 19, 2011 | Microwave Ovens
All the burners are turned off on my gas stove, but one keeps sparking uncontrollably...its been all night now. I have lifted burner cap off and can see the spark but have no idea how to stop it. Our...
This is dangerous.
You should be able to stop it by unplugging the stove. The automatic spark requires electricity to work.
Unplug it and leave a comment with the make and model and I will assist you in finding a replacement.
Mar 31, 2011 | Microwave Ovens
When stove is on a yellowish orange flame comes from burner.This has not occured until now. We own this viking oven for about 10 yrs without any issue whatso ever. Can you help to resolve this issue
You need to replace the burner if you want blue flame. Since its 10 years old, it's about time to replace the burner with similar size and shape. Old burner have big hole causing yellowish flame compare to new one.
I hope I solve your problem.
Mar 30, 2011 | Microwave Ovens
I have a whirlpool stove and one of the burner doesn't work but the light on switch works. What could be the problem and how can I fix. Help pls.
1.TURN THE POWER OFF TO YOUR STOVE! In most houses, the electric stove is on it's own circuit breaker. If you are in an older home, you're probably lucky you even have a stove...just kidding! If you had your kitchen updated, every electrician should have wired your stove to its own circuit breaker. Shut off the circuit breaker.
2.Remove all the burners and catch plates under them. You are going to lift the top of your stove up. Once you've done that, see what kind of receptacle you have. You'll now have to shop around to find the part. The local appliance store charged us way too much. Lowe's or Home Depot might not have your parts, or they might. Amazon might have your part and if they don't, they will direct you to someone that will. We could have saved half the purchase price if we'd gone there in the first place.
*A quick note* The receptacle is wired to the switches at the front of the stove. They complete the entire circuit, so that is the only thing you need to worry about--from the switch to the receptacle.
After the stove top is lifted, you will find another tray under it. If the wires from the receptacles go under the tray to the "on" switches at the front of
your stove, you'll have to lift this tray up as well. Remove the tray and any other panels you need to in order to get to the switches.
3.Follow the wires, which should be color-coded for that stove top burner, until you find the switch it hooks to. If you have not purchased the parts yet, go ahead and disconnect the wire from the switch and pull the receptacle from it's aluminum cradle. You'll want these parts to take with you to find their replacements.
*note* Your new wire receptacle should consist of the housing for the burner to fit snug into, and two wires that extend from the other end. Electricity works in a circle. If the circle is broken, you have a short and that is where the spark comes from- your electrical current was trying to reach the other side and sparked to get there.
If you do have the parts, compare them to the old ones to make sure they are the same. Nothing worse than spending time on a repair with the wrong parts.
If you have the RIGHT parts, find the correct end of your wires and just slide it over the terminal at the switch. They might be the screw types. Whatever you have, connect it. It does not matter which one went where. As long as you are using the empty wire terminals you just uncovered with the old wires, you are completing the circle.
*Note* I have seen some receptacle kits that do not give you enough wire and require you to splice wires together. Not only is that a bad idea, but does not conform to electrical codes requirements and could result in fire. If the new equipment did not come with long enough wire to reach all the way from receptacle to switch, purchase a longer wire at your local hardware store. For a few pennies more you could be saving your family's lives.
4.Once you have hooked the receptacle ends to the switch harness, tie down the wires alongside the wire bundle until you get to the end.
5.Attach your burner receptacle to the aluminum clamp.
6.Attach your aluminum clamp to the stove top.
7.Screw down all the pieces you removed- anything covering the switches and the bottom tray. Put down your stove top and put in place all the shields and burners. Turn the circuit breaker back on for your stove and try it out!8_10_2012_8_42_55_am.jpg
Feb 12, 2011 | Microwave Ovens
I have a kenmore stove whose burners wont light. oven works fine. burners will spark but no gas comes out. recently I turned off the power to the stove by turning the fuse off. what do I need to do to get...
If the gets give no gas then sounds like a Thermocouple, this is a device that allows the gas to come on after a period of time ensuring that the pilot is lit and heated up this thermocouple, once it heats it then allows gas to enter and ignite the main burner..hope this helps ,please leave feedback.
Apr 12, 2010 | Kenmore 66469 / 66462 / 66464 Microwave...
Microwave Ovens Logo
74 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
