Question about Saeco Royal Professional Espresso Machine
The display screen has a message saying "decalsify". what needs to be done to clear the message? unfortunately the manual has been misplaced! the machine is still working but obviously needs to be cleaned.
    President:
  • 1,618 Answers
Use the instructions below to descale, then press menu button and navigate to descale to clear message.
Posted on Sep 03, 2010
How do i decalcify prime?
Priming and decalsifying are two different issues. To prime, direct the steam wand into the tray and turn the water on. Once it has "primed", the screen will change and you will be done. To decalsify, you can use the starbucks decalcifying solution and follow the instructions on the box. Hope this helps!
Oct 31, 2010 | Starbucks Saeco Italia Digital Barista...
NTL VS205 lost manual
Lets see if I can get my hands on a manual. one moment
Jun 27, 2008 | NTL D6000 Cordless Phone
When i hit the y= button, it says "ERR: INVALID" and i cant fuigure out whats wrong.
If you got the message while trying to draw a graph
  1. Press [2nd][Y=] (STAT PLOT)
  2. Choose option [4:PlotsOff][ENTER]. Screen displays Done
If message popped up while doing something else that involves lists or matrices, the length of lists may be different, or the dimensions of matrices may not be compatible.
To Clear the lists:
  1. Press [2nd][0] (CATALOG)
  2. Press [PGRM] (C) to jump to first command that starts with c.
  3. Use arrow to scroll down to ClrAllLists, select it [ENTER]
  4. Calculator displays Done
  5. Start the new problem.
To reset the Ram press [2nd][ ] (MEM) [7:Reset][1:All Ram][2:Reset]. Press [CLEAR] to erase the Ram Cleared message.
When the RAM is cleared, the calculator is reset. The calculator resets itself after a battery change.
Aug 31, 2010 | Texas Instruments TI-84 Plus Calculator
My idect D1i phone keeps asking me to register
Hi , The phones which keep saying Register mean that they have lost the coding for the Base. To re-code them all you do is
press the menu button,
Press down Button 3 times until Setting comes on the screen,
Press the Button Phone/Ok,
The Display should display HANDSET SETTING,
Press the Button Phone/Ok ,
Then Press the Down button about 4 times until Register Comes on the screen,
Enter Base pin ( 0000 )
The Display will show REGISTER IN PROGRESS,
then immediatly press the Handset Locator Button on the Base and hold it in until you hear a tone.
Thats it , the screen should display Register Done.
Mar 06, 2010 | Lands Phones
Error 0xc18a0401
I found this on the web. Should clear up problem.
If you find this information helpful, pls rate me.
It is a good forum., for all types of problems.
http://www.fixyourownprinter.com/forums/printer/50063
Christina: Let us perform some steps to isolate the issue and find a fix for it.
Christina: Please perform the following steps and let me know the message that will be displayed on the printer.
Christina: A. - Press and hold the “*” key.
B. - Press the “#” key and release both keys.
Display should say “Enter Special Key Combo”
C. - Press and release in sequence the “1”, “2” and “3” buttons.
CustomerName: ok
CustomerName: screen says "support" R0631M
Christina: Fine.
Christina: 2. Press and release the right arrow button until the display says “System Configuration Menu”.
Christina: 3. Press and release the “OK” button.
Christina: 4. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
Christina: 5. Press and release the “OK” button.
Christina: 6. Display should say “Hardware failure status: Clear. Press OK to clear”.
CustomerName: yup
Christina: 7. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
CustomerName: ok
Christina: 8. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
CustomerName: ok
Christina: 9. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
CustomerName: done
Christina: Fine.
Christina: 10. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
CustomerName: done
Christina: 11. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK. The Printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
CustomerName: made a buncha noise, and it didn't print a diagnostic page
Christina: Good.
Christina: Is the error message still being displayed on the printer?
CustomerName: nope
Christina: Good.
CustomerName: should I try to print something?
Christina: Let us print a self test page to check the functionality of the printer.
Christina: Press Setup menu on the All-in-One then scroll using the arrow key and select Print Report then select Self Test Report.
Good Luck.
Feb 26, 2010 | HP Photosmart 8250 InkJet Printer
I have a Mitel Superset Phone 4025 and the display screen says Messages Phonebook and there are no messages.
That just means there is a call me back message. If you push messages and clear the ones you have then the light will stop blinking.
Jun 03, 2009 | Mitel Superset 4025 Corded Phone...
Hp c6180 Error Oxc18a0507
CustomerName: ok
Christina: Fine.
CustomerName: yup
CustomerName: ok
CustomerName: ok
CustomerName: done
Christina: Fine.
CustomerName: done
Christina: Good.
CustomerName: nope
Christina: Good.
Mar 18, 2009 | HP Photosmart C6180 All-In-One InkJet...
Decalcify
Did you use the auto descale or the manual descale.
If you did it the manual way, then fill tank with water and press the Double elipse button(left of menu button) that will run the auto descale and clear out the message.
Mar 02, 2009 | Gaggia Titanium Espresso Machine
"NEED TO PRIME" alert is on. Have run a couple of tanks of water through the wand making hot water, but still says NEED TO PRIME. The pressure on the water seems a little lower than normal. Tried to...
That message indicates that water lines may be dirty. How long ago or how often had you descales your machine? If you have not routinely descaled then the water lines have to be cleaned ( by opening the machine) manually and/or replaced. Another possibility if you have been descaling it regularly, is that a water line may have small crack. And yet another possibility is that the pump may be going bad and/or the flow meter is clogged ( needs cleaning and/.or replacement). Best suggestion at this time is to have an Authorized SAECO Service Center check your machine. Contact Saeco USA Inc. to located a Service Center near you at 800-933-7876 (toll-free), ask for customer support, or contact SAECO via e-mail at : outlet@saeco-usa.com
Jun 11, 2008 | Starbucks Saeco Italia Digital Barista...
Cant get rid of blinking error message, nothing works
H4-00 is a fuser related service code. you need to get into the simulation programs and run sim 14 to reset the code. Make sure there is no paper jammed in the fuser. (The hot part on the right side inside the door)
Dec 02, 2007 | Sharp AL-1655CS Copier
Saeco Royal Professional Espresso Machine Logo
109 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
