Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Display problems When I power up, the screen is flickering with different horizontal shades of blue. This happens no matter which devices, if any, are attached to the unit. There is also an error message about checking RGB connection. Does this sound like a lamp replacement problem, or something different?
  • SteveAZ26 May 11, 2008
    I think I have the same problem. It's a big square area with flickering shades of blue & green regardless of device. If I leave it on it indicates no signal.
  • Mitsubishi Master
  • 8,617 Answers
Sounds like bad 1000uf capacitors on the FMT board there are 3 100ufs on that board that can cause that symptom
Posted on May 11, 2008
Samsung UN40D6000SFXZA TV has blue screen with vertical lines of various shades of blue.
You may try a new T-CON, but most of the problem could be a display panel.
Nov 01, 2017 | Samsung Televison & Video
I have a tube tv. I have never had problems before. One night watching a dvd movie with no problems, the next day i put in a different dvd and the screen is blue. I can see the movie but all in...
It sounds like your tv might be on the way out. You will have to check this by putting another device on it. If the TV is working fine for all your channels then it is the DVD player or the DVD. A Blu Ray will not work on all TVs or all DVD players without what is called a scan converter.
Apr 06, 2014 | Samsung Televison & Video
Monitor intermittent power problem and horizontal green flickering lines
separate wiring. touching wires creates cross-talk of signals.
Jan 28, 2014 | Computers & Internet
Screen flickering
Probably the problem comes up with two different reasons. 1st is Horizontal control section in LCD may failed or in irrecoverable situation. 2nd is display drivers crashed or not supporting the laptop.
Nov 15, 2013 | HP EliteBook 6930p Notebook PC
Tv powers on, see three birds in color then flickers and fades to white
The problem must be with its main digital processor board. It will be best to make it confirm. Contact any service technician. Try this link. http://electronicshelponline.blogspot.com/ There are more than two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help.
May 20, 2013 | ViewSonic N1930W 19 in. LCD TV
Led problems
Why do I have a green line on the edge of my screen? If you have a thin green line on the edge of the screen when using an HDMI cable to connect to a cable or satellite box this is usually caused by the box.
To test to see if this is a box issue you will want to take the following steps:
If the TV has a Horizontal position setting in the menu you can adjust the position to see if the line disappears.
You can also change the Wide setting to the Zoom or Panoramic option to see if the line disappears.
If the line disappears you will want to look into getting a different source box.
Your display may be flickering for several reasons. You will want to take the following steps to rule out the most common reasons for the display to flicker:
1. Reseat all cable and connections to the television from your devices. Physically remove the cables from both the television and the device and reconnect them.
2. Check your Advanced Video settings in the Vizio TV menu some of our Vizio televisions will allow you to adjust the following settings under the Advanced Video settings:
Ambient Lighting
Backlight Control
Advanced Adaptive Luma
If you have any of these options available please turn all of them off to see if this resolves the display flickering.
If the above steps have not resolved the issue please take the following steps in the order presented:
1- Power off TV
2- Unplug TV from outlet
3- Press and hold in the power button on the TV for 30 seconds (while it is unplugged from the wall)
4- Release the power button
5- Plug in the TV into a different outlet
6- Power the TV back on
There is also a factory reset option in your menu under the SETUP section. It will say either "reset all settings" or "system reset". We recommend that you reset all settings as well to see if this resolves the issue. If this does not resolve your problem please contact our technical for further assistance.
If the line stays in the same spot when changing the above settings please contact our technical support.
Dec 04, 2011 | Televison & Video
BLUE screen problem(monitor)
It is the picture picture board on your monitor that is malfunctioning, since the power led or button is on, but blue shaded screen, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity or any service center to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Apr 26, 2010 | SAMTRON 55V 15" CRT Monitor
Compaq mv540 monitor suddenly can't adjust screen features
Please somebody give a solution as same is experienced by me tooo.
Jan 22, 2010 | Compaq MV 540 15" CRT Monitor
Wavy screen
Sounds like power interference. Try a different wall plug or power cable
Apr 16, 2009 | Computers & Internet
Horizontal blue lines with a slight blue wash in the screen
Its because of Over Voltage of Screen (G2) to Blue CRT.
Take off front lower cover (speaker grill) and unscrew board. There you will need to find Focus Block mounted having 6 control knobs. 3 knobs are for Focus control and 3 are for Screen volts control. Find Blue Screen control knob and turn is Counter Click Wise slightly until bluish shade disappear on screen including few blue horizontal lines.
If you select AV input to adjust that will be fine as you do not need to wait for dark-scene.
Apr 09, 2009 | Sony KP-65WS500 65" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
42 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
