Question about Maxi-Cosi CabrioFix (Black Reflection) Infant Car Seat
When can i remove my babys head rest from his car seat
When can i remove my babies headrest from her car seat?
Posted on Feb 28, 2011
How do i take headrest off of my graco 3 in 1?
There is a gray tab on each side where the head rest slides in if you push them in it will allow you to pull the head rest out part way then push in the red head rest adjust button and it allows you to pull it the rest of the way out.
Aug 02, 2012 | Graco Nautilus 3-in 1 Car Seat
How do I remove the head rest to convert this car seat to a booster? The back plate and the head rest are connected and held on by a metal bar on the back of the car seat.
This car seat does not convert to a booster. It becomes a "Belt-positioning booster". The back and headrest remain while using as a booster. You remove the 5-point harness and use the car's shoulder strap seat belt.
The belt positioning is done by the plastic parts at the top on either side of the seat.
Following is the link to get the instructions for this seat: http://www.coscojuvenile.com/usa/eng/Instructions
Oct 16, 2010 | Cosco Alpha Omega Elite 5-Point 22-155
We need to remove the drives side head rest to install a seat cover, but we cannot figure out how to remove the head rest. How do you remove the driver's side head rest?
Head Restraints Removal
  1. Unscrew front seat head rest guide rod retainers (610A18) .
  1. Pull up on front seat back head restraint (611A08) . Compress foam in area of front seat head rest guide rod sleeves (610A16) .
  1. Remove front seat back head restraint positioning springs. Pull front seat back head restraint up and out.
Installation
  1. Slide front seat head rest guide rod retainers onto front seat back head restraint posts.
  1. Compress foam in front seat head rest guide rod sleeve area. Install positioning springs on front seat head rest guide rod sleeves .
  1. Insert front seat back head restraint posts (notches on posts facing rearward) into front seat head rest guide rod sleeves and push down to engage positioning spring.
  1. NOTE: Front seat back head restraint must operate smoothly throughout its range of travel, must remain in any fixed position, and must not be freely removable from the seat back. If any of these conditions are not met, check for proper installation of positioning spring onto front seat head rest guide rod sleeve .
    Tighten front seat head rest guide rod retainers onto front seat head rest guide rod sleeves .
  1. Adjust front seat back head restraint by applying hand pressure, either up or down, to center area of front seat back head restraint .
Aug 21, 2010 | 1998 Ford Taurus
Hi do you have a re placement head rest?
mcdevito75 here, The label on the car seat should give contact info for any replacement parts you need.
Jun 26, 2010 | Baby Trend Flex-Loc Infant Car Seat -...
When should you take off the head rest on a baby's car seat?
If you are refering to the buffer that goes around a babies head in some car seats then you are usually faced with a sweaty head versus the need for proper protection. When a baby can support its own head and actively start moving around it may get in the way but with many car seat related things it is better to leave it as long as possible. Any extra protection or support in the event of it being needed is a bonus.
Jul 19, 2009 | Maxi-Cosi 22371HFL Infant Car Seat
How do you remove the headrest on a 1996 ford crown victoria?
Head Restraints Each front seat is equipped with dual-post design front seat back head restraint (611A08). The front seat back head restraint is installed as follows:
  • It travels on dual posts which have notches to engage a spring-loaded catch in the guide.
  • The front seat back spring assembly retains the front seat head rest guide rod sleeve (610A16).
  • The front seat back head restraint is adjustable from its normal position to a raised position of approximately 25 mm (1 inch).
  • Pull up on the front seat back head restraint to raise it. Pushing down will return it to its normal position.
Removal
  1. Unscrew front seat head rest guide rod retainers (610A18).
  1. Pull up on front seat back head restraint (611A08). Compress foam in area of front seat head rest guide rod sleeves (610A16).
Installation
  1. Compress foam in front seat head rest guide rod sleeve area. Install positioning springs on front seat head rest guide rod sleeves.
  1. Tighten front seat head rest guide rod retainers onto front seat head rest guide rod sleeves.
  1. NOTE: Front seat back head restraint must operate smoothly throughout its range of travel, must remain in any fixed position, and must not be freely removable from the seat back. If any of these conditions are not met, check for proper installation of positioning spring onto front seat head rest guide rod sleeve.
    Adjust front seat back head restraint by applying hand pressure, either up or down, to center area of front seat back head restraint.
Mar 01, 2009 | 1996 Ford Crown Victoria
How do I remove the head rest from the ferrari high back booster?
I have the same problem. I want to remove the headrest so that i can wash the cover. my car seat looks like the one on this pagehttp://4.bp.blogspot.com/_MrQjKKC90Ik/TKXqOfzH-cI/AAAAAAAAEic/Oe3gQmMldtM/s1600/ferrari+2.jpg
I cant load this page http://www.coscojuvenile.com/instructions.asp
Feb 26, 2009 | Ferrari High Back Booster
Headrest removal
trying to take of the cover of the car set where my baby sits becues it wet for i can wash it do you know how to take it off
Nov 29, 2007 | Baby Gear
Maxi-Cosi CabrioFix (Black Reflection) Infant Car Seat Logo
443 people viewed this question
Top Maxi-Cosi Baby Gear Experts
Dorel UK
Dorel UK
Kristy Richie
Kristy Richie
Level 1 Expert
Bear Mark
Bear Mark
Are you a Maxi-Cosi Baby Gear Expert? Answer questions, earn points and help others
