Question about Garden
Will a timber bandsaw cut thin plastic or will i need a plastic cutting blade on my clarke bandsaw. The teeth are very fine on the timber saw thats in now thanks
  • 487 Answers
Hi, yes it will cut plastic, but if its a brittle plastic you will need to guard against splitting. To guard against this you can brace the plastic with a thin sheet of plywood underneath whilst cutting.
Posted on Aug 31, 2010
Can anyone tell me if there is a replace blade for clarke bandsaw model tb1015a
I get my blades on sawblade.com. I am using bi metal blade for cutting structurals and beam and hard back blade for cutting wood.
Oct 28, 2014 | Saws
My poulan 18 inch chain saws blade turns but only cuts in about an inch and won't go any farther. It's two days old and worked fine cutting the first 2 trees down.
It sounds like the chain does want sharpening, it depends on what you are cutting ( type of timber, dirty timber,burnt timber etc ) as to how long before it needs sharpening, if the chain comes into contact with the ground below the tree it will lose its edge instantly.
Dec 29, 2012 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Delta 28-185 bandsaw cuts crooked after 4" of straight cut adjustments have been made as per manual
Sounds like your blade is getting hot, causing it to expand, causing it to be too loose. The blade gets hot when it's teeth are rubbing or scraping the material more than they are cutting. . You might see some improvement by increasing the blade tension and feeding the material a bit more aggressively. . But you will see greater improvement by using a blade with fewer teeth. For a given blade, the thicker the material is, the more teeth there are engaged in cutting at the same time, so each tooth gets a smaller share of your feeding force. . The optimum number of teeth that should be engaged in the cut at a time varies by the material, the style, quality and condition of the blade, and the rigidity of the saw---- but you can use 3 to 10 as a rough guide. . Good luck, and thanks for using FixYa. Al Kupchella
Apr 15, 2010 | Delta BS100 Shopmaster 9 Inch Bench Top...
Replacement blade
Use a 10" blade. As for the number of teeth...the more teeth the finer the cut will be. The only drawback is a a finer toothed blade will cut slow. For your purposes I'd suggest a fine toothed blade.
Mar 07, 2010 | Craftsman 10" Table Saw
I just purchased the ryobi 9 inch bandsaw, used it once or twice and have noticed that the teeth on the blade are crooked. is that a typical problem, is it a problem at all?
If you mean that the teeth alternate sides in which they point, this is normal. This aids in the blade clearing cut material from the path of the blade making sure it does not clog. Almost all saws for wood have this tooth pattern. If you have doubts look at a new replacement blade for the saw.
Jan 19, 2010 | Ryobi 9 in. Benchtop Band Saw
MBS 240/E proxxon bandsaw
the 24 TPI is the one to use. It sounds as if the blade is running to fast and over heating the blade and causing it to lose the temper in the balde steel. Try slowing the blade speed down if you can. Also you can try putting some cutting oil on the balde to stop it from clogging up. You can also rig up a small air line to blow on the cutting area to cool it down and remove the metal chips. I've also applied some wax to the blade every so often. A candle will work for this too. Hope this helps you, Jeepfxr
Jan 10, 2010 | Proxxon 28174 24-Tpi Fine Toothed Band Saw...
Clark 6x4 bandsaw
there should be an adjustment knob on the back that changes the angle of the top wheel and this will center the blade so it stays on. I do this by jogging the saw on and off while I adjust it. hope this helps you
Sep 23, 2009 | Grizzly Saws
My blade cut one 12mm round bar and broke tried anothertoo two blades they broke
Ok, I am gonna give you the secret. When they make band saw blades for metalwork,(assuming the blade is spec'd right for the application, the cutting teeth are not completely hardened for heavy use. Simply put, you have to break the blade in. This can be done in one of two ways. You can either reduce the speed of the band OR you can use half of the infeed force into the work piece. In other words, half speed or half feed for about 20-30 mins of cutting time and the teeth actually harden the rest of the way. This is not an accident. As a rep for a bandsaw company, this was the abolute #1 problem I got complaints about in the field. Of course, if you don't know the secret, you have to buy more blades from them. Convenient,huh? Try it my way and lemme know how it turns out.
Aug 15, 2009 | Makita 2107F Portable Band Saw
Band saw blade wanders.
cut freehand. A bandsaw blade will always run off to one side or the other, even using a fence.
The rip fence is intended for re-sawing only, and very thin strips
Jun 28, 2009 | Ryobi 9 in. Benchtop Band Saw
Grinder support
They range in blade composition, number of teeth (cutting bits or surfaces), the amount of set (the width of the kerf removed by the blade), and the blade quality. * One of these circular saws will probably have a plain HSS (high speed steel) saw blade in it when it is bought new. * TCT (tungsten carbide tipped) blades are much more durable, especially in tough hardwoods. Also plywood and composite boards are hard on blades so TCT blades are needed on them. o Blades with fewer teeth (say 28) and with less rake to the face of the teeth, are designed for ripping along the length of timber, with the grain. They typically give a quick rough cut. They are cheap to buy and cheap to sharpen, since they have less teeth. o Blades with more teeth (say 40) are designed for crosscut type work. They give a lot neater cut in most circumstances. * Abrasive blades are made from carborundum or other abrasive materials bonded together in a resin or other synthetic binding material, and are used for cutting concrete or metal. They tend to wear away rather quickly, but for small projects, they are inexpensive and make fast cuts. * Diamond rim blades. These blades are made of special alloy metals with industrial diamonds embedded in the rim (around the outside diameter of the blade), and are for cutting hard concrete, cement composite materials, and masonry products like block or brick. * Special tempered allow blades. These blades have tempered carbon steel teeth, which are very fine (small, and closely spaced) for cutting sheet metal like galvanised roofing metal, or aluminum, copper, or brass tubing. * Dado blades. These are blades which can actually be adjusted to cut different width kerfs (the width of the material removed in the blade path). These blades make it much faster and easier for cutting dados and rabbetts, used for joining lumber. * Trim and panelling blades. These blades have fine teeth for making smooth, accurate cuts on finished materials like mouldings and panelling.
Aug 27, 2008 | Speed CGW ABRASIVES 35606 "24 GRIT" HIGH...
Garden Logo
66 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
