Question about Acer Aspire 3690-2196 Notebook
Memory card not working not picked up up by my acer 3690 took memory card from digi foto frame to load up some pics and inserted it id sd slot but acer does not see it ... nothing
    President:
  • 2,291 Answers
Check ur driver , go to manage disk and run troubleshoot, download reginout that may solve ur issue
Posted on Aug 31, 2010
How to remove/load sd card stuck in Huawai M860
The SD memory card slot is spring loaded, to insert the memory card insert the card into the SD memory slot with the SD card contacts going in first and gently push it in until it locks in place. NOTE if the SD card does not slide into the slot easily then the SD memory card has been inserted back to front, turn the SD card around and insert it again.
To remove an installed SD memory card, press the SD memory card and it will pop out slightly then you can then pull out the SD memory card.
Mar 12, 2013 | Cameras
Kodak EX 1011 does not recongnize memory card
On the contrary. The EX1011 is designed to work with SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible and the frame will not recognize it as a memory card. You need to use SD cards, 2GB and smaller.
Jan 31, 2012 | Kodak EasyShare EX1011 Digital Picture...
I received a 7" pandigital
If the photo frame has a slot for an SD card, you can drag and drop the images you want to the card and then insert it into the frame. Connecting the card to the computer can be accomplished by using a card reader or, if the computer has a built-in SD slot, just insert the card.
Jan 21, 2011 | Cameras
I do not understand the method for downloading/copy pictures from the SD disk onto the DP 700 Ditial Photo Frame.
Don't know a lot about the frame, but I did a quick search via Google. It looks like it has a built in SD card slot. Insert the SD disk, access the system menu. There should be a settings or Explore function where you can transfer the pics from the SD card to the frame's memory. Or you can run the pics directly from the inserted SD card.
Jan 08, 2011 | Cameras
Do not know how to transsfer pic fromcomputer to the Kodak pic frame
On one side of the frame there should be memory card slots and a usb slot.
two ways to do it, take the memory card from the camera and put it in the frame.
Or down load the camera to tyour computer and then with a usb cable upload the picture fram with the pictures you want
Or from your computer load a memory card and then stick it in the frame
Feb 20, 2010 | Kodak EasyShare SV811 (8858946) Digital...
How do I download photos from pc to camera memory card to then put on a digi frame?
you probably wanted to put -em from the the camera in pc ..to edit ..and after that into the frame ...the things are easy ...the camera is connecting with the data cable ...and downloading its kids game ...puting em back to the camera just look into the my computer when the camera is connected and you will find it as a removable storage device ..that is the actually SD card..and copy paste em back ...in fact you can also proceed the same when you take em out ....after editing and so ...it depends on which way the frame accept info ...from usb cable ...from usb stick ..or from memory card...if the frame has memory card than you can just put the card into a card reader and load the photo direct with copy paste ...or ..if the frame has a cable connection you have to make the connection with your pc ...and upload pics or with the camera ...depend on the frame type ..and the way it connects ...for better and more precise information let me know the exact digi frame model ...or at least how it accepts uploads..
Aug 03, 2009 | Samsung Digimax 530 Digital Camera
SD CARD is not working
I reccomend that if you can find a driver for your sd card slot, install it so that your slot could be compatible with all sd cards including HCSD cards.
Jan 26, 2009 | Acer Aspire 3690-2196 Notebook
I just bought a vltech digital photo frame and i'm not sure how to download the pic's on to the fram from my computer or my iphone. do i need some type of memory card to upload pic's? model DPH3080E
Does you picture frame have a usb port on the back or the side of it? If not, do you have an SD slot on the back or the side of it? If so, load your pictures onto a thumb drive (flash drive) or SD card, and insert that into the port if it's a flash drive, or slot (if it's an SD card). It should take over from there. Let me know if that helps.
Rob
Dec 29, 2008 | Vtech Kidizoom Digital Camera
I lost instructions to my Optimus 7" Digital Photo Fram
You can change out your pictures by having an XD or SD Memory cards if you have a card reader for your computer plug in the memory card put the photos on to it that u want on ur pic frame and plug it in to the xd/sd card slot on the left hand side of the photo frame and there u go. If you want ur pics off the internal memory u can transfer them from the frame to the card via the options button or menu button that is.
Nov 30, 2008 | PANDIGITAL 7-Inch Digital Photo Frame with...
Can I get pics from computer put on memory card for digital camera?
Put your SD card into a card reader / slot in your computer. Go to "My Computer" Identify the drive letter allocated to the card slot and drag and drop or copy and paste.
May 05, 2008 | Cameras
Acer Aspire 3690-2196 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
