Question about HP Pavilion dv6000z Notebook
I have a problem with my dvdram sdvd8821h, it doesn't read, I have looked the device manager it looks like it hasn't drivers i do nowhy.i tried to download the that drivers but it is not found.
  • 10,421 Answers
Need drivers for cdrom
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver if you physically unplug your cd/dvd then plug them back in restart your computer the found new hardware wizard should activate if you dont have motherboard disk you will need to download the drivers http://download.cnet.com/dvdram-en-20071009085435-zip/3000-2110_4-172943.html http://download.cnet.com/dvdram-en-20070907111350-zip/3000-2110_4-170034.html http://download.cnet.com/dvdram-win2k-5025-en/3000-2110_4-172950.html http://download.cnet.com/adaptec-udf-reader-driver/3000-2100_4-10021086.html Adaptec's UDF Reader enables MultiRead CD-ROM drives to read UDF-formatted CD-R and CD-RW discs (such as those written with DirectCD) under Windows 95/98/98SE/NT 4.0/2000. Hope this helps.
Dec 28, 2012 | Gateway GT5678 Desktop PC
I Nedd CD de Instalacion and Drivers
if these packages are not the right
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
you might have to try a few times to get it right
hope it helps you
Apr 12, 2012 | IdeaSoft Nexis 100AP CD/DVD Publisher...
I need an install driver
hope this helps you
Feb 03, 2012 | Micro Solutions Backpack (164550) External...
I HAVE A TSSTcorp CDDVDW TS-L632N ATA Device ON MY LAPTOP,THAT WONT READ OR PLAY CD OR DVD..IS THERE A UPDATED DRIVER? OR HOW CAN I FIX THIS ISSUE?
Click start control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
If this does not fix the problem you might try
or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
you might have to physically unplug the leads for this cd-rom then plug them back in this should activate the found new hardware wizard
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives if you see a yellow question/exclamation mark or a red X right click to update driver
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
if your computer came with a motherboard disk the drivers could be on it
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps you
Nov 29, 2011 | Computers & Internet
The computa don't read the dvd when is conected to the usb?
this could be a driver issue
if you are having trouble with your drivers
here is a general look at the drivers and how to update them
if your computer came with a motherboard disc the drivers could be on it
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver hope this helps
Jun 15, 2011 | LG DVDRW DL LIGHTSCRIBE 8X USB 20BLK ...
Philips dvdram sdvd8821h
Ok almost ANY DVD CD that will physically fit into the space will do they are all more or less the same... Just get yaself a replacement bare DVD from ya friendly PC store and then simply open up the PC ya will see where the DVD is mounted, undo the screws holding it... remove the two cables the Data and Power they can only go on one way... replace the new DVD put screws back reconnect Power and Data .. ya good to go. Otherwise if ya don't wanna do that maybe get yaself an external DVD via the USB port... and just disable the old one in device manager and use USB one.. anyway GL.
Jul 28, 2008 | Philips (DN4S2S05F/17) (5 Pack)...
did you clean the drive with a dvd cleaner or spray the drive out with conpressed air
if this not work then goto http://www.quickpcsolutions.org/Drivers/test/device.html?gclid=CNOhpKfywJQCFQWVFQod2FwSTQ this will test all your drivers and tell you what ones u need to run the dvd
i hope this helps out have a good day
Jul 12, 2008 | Computers & Internet
Dvd ram driver
is there any solutions for these problem? i also have same problem with this? is there anyone can help?
Mar 25, 2008 | Philips LM1200 PHILLIPS 12" 2GB OPTICAL...
GMA 4082n device driver not working properly code 39
sounds like your cd/dvd is mechanically shot. time for a new one.
Mar 09, 2008 | Lenovo 3000 C200 Notebook
HP Pavilion dv6000z Notebook Logo
95 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
