Question about JVC AM FM CD DET FACE CAR STEREO
Where does the yellow wire go on the unit
Ihave a kd-s5050 that i bought used apparently the yellow wire was pulled out of the units plug where does it go
  • 38 Answers
Yellow = Always +12V
http://farm2.static.flickr.com/1099/1469548639_4827e6b806.jpg?v=0
Also check pg 27 of the installation manual here http://resources.jvc.com/Resources/00/00/95/GET0171-002B.pdf
Here's a tip. if the yellow wire's missing from the harness connector, and you're not using an additional amp or power antenna, use a pin to unlock either of the 2 blue remote turn on leads. Remove the lead, desolder the thinner gauge blue/blue-white wire, carefully solder a thicker gauge yellow wire to the end of the lug and slip it back into the connector till it locks.
Jango
Posted on May 27, 2008
I bought a JVC KD-R620 and I can't get To power on without having the ignition wire(red) and the battery wire(yellow) connected. And it won't save my settings either..I don't have a blown fuse...
Ok, just so I get this right. You want this unit to power up, without hooking the 2 power wires??? Red is constant power, yellow is switched power. Did you use a wiring harness to hook the radio up or did you hard wire it? I alway recommend a harness. This would make the install easier. If the unit works witht them wired, use it.
Sep 03, 2011 | JVC Car Audio & Video
Why does my jvc kd-r526 reset to factory default everytime i turn it off
Try connecting the yellow wire to a constant power source. That is, a source that still has power when the key is turned off. The yellow wire controls the memory of the radio.
Jun 02, 2011 | JVC KD-R800 Car CD/ MP3 Player
How much was the jvc-kd-s5050 new when they first came out?
The list retail price for this unit originally was $120. However it has been around for a good few years and by 2006 it was retailing for around $75.
Hope it helps. Please leave a vote for the solution. Thanks.
Jan 25, 2011 | JVC KD-S5050 CD Player
I need to know the color for the remote wire for jvc-s5050 cd player
the remote wire for your source unit is "BLUE with WHITE" stripe. it can be used for either a power antenna or as a trip wire for an amplifier.
hope this helps and please dont forget to rate.
cheers
Jan 13, 2011 | JVC KD-S5050 CD Player
CONNECTING AN AUX CABLE TO PLAYER
Unfortunately, you can't. I have the same deck, and it has no aux in capability. The S5050 is simply a CD player, not even an MP3 player.
Mar 25, 2009 | JVC KD-S5050 CD Player
Sound turns on when it wants to.
disconnect all of your speakers , then hook them back up one at a time when the radio starts to malfunction u have located which channel on the radio is bad.check ur wire installattion
Aug 30, 2008 | JVC KD-S5050 CD Player
Remote wire
i don't know which wire is for the remote, but blue is usually for the antenna up/down function.
May 05, 2008 | JVC KD-S5050 CD Player
JVC Wire Harness
If it fits it will work, If the manufacturer stays the same so does the wiring loom.
Feb 06, 2008 | JVC KD-S5050 CD Player
Kd-s5050 wont stay ON
This is Common on Vauxhalls...
The Accessory position on the Ignition fails!
so the Ignition connection is temperamental... The unit has power and so certain functions using the constant 12v.
I normally connect the ignition to a different source.
Or a quick fix is to connect both red & yellow to the constant12v
Apr 27, 2007 | JVC KD-S5050 CD Player
JVC AM FM CD DET FACE CAR STEREO Logo
215 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
