Question about Mitsubishi WS-65413 65" Rear Projection Television
Mitsubishi turn on then turns off
Hi again ok I did what you said to ,I pressed the input/device botton and menu together and entered into diag.The LED started to blink fast 2 times and then 1 more time ,total of 3.( blink blink-- blink)-- =pause what does that mean ? thanks Todd Mitsubishi Medallion Hd 1080 model-ws48413
  • Mitsubishi Master
  • 8,617 Answers
Your model has the V22 chassis when it blinks a 21 cide which is what yours is indicating that maens the set is shutting down due to xray protection. Which means a votage is raising which trips the xray protection circuit and keeps your set from operating
1. SELF- DIAGNOSIS INDICATE X-RAY. CHECK FOR PROPER SEATING OF CONNECTIONS TO AND FROM THE HIGH VOLTAGE BLOCK. 2. SELF- DIAGNOSIS INDICATE X-RAY. CHECK FOR A SHORTED IC5A03 PART # 270P704010 AND AN OPEN R5A73 82K ¼ WATT OFF PIN 2 OF IC5A02 ON THE MAIN PCB. 3. SELF-DIAGNOSIS INDICATES SHORT PROTECT. CHECK FOR A SHORTED IC4B01 PART # 270P261020 (VERTICAL OUTPUT) LOADING 24-VOLT SUPPLY LINE. LOCATED ON THE MAIN PCB.
Posted on May 09, 2008
PC HDMI W4201C 42 CONNECTION
Hi Caleb,
To resolve this, please perform the following steps:
  • Turn off the TV and unplug the power cord
  • Connect the HDMI cable to the HDMI port of your laptop.
  • Connect the other end of the HDMI cable to the HDMI input on your HDTV
  • Connect your device using the HDMI connector (Refer to image below)
  • Plug in the power cords for the TV and Xbox
  • Turn on your TV and Xbox
  • Enter the TV Menu and select Setup (Refer to the image and steps mentioned below)
  • To enter the TV Menu, press the Menu button on Remote control
  • Use the left and right buttons (volume buttons) to move between the icons
Select correct input source
  • Input allows you to select the proper source based on how you have your TV and video equipment connected.
  • Press Input on the remote to go directly to the Input Select menu
  • Select HDMI 1 or HDMI 2 (Refer to image below)
If the TV does not work, please follow these steps:
Verify the PIP/POP/PBP function is disabled ( PIP/POP/PBP Compatibility - The only input sources that cannot work together are HDMI with HDMI)
  • Press the Menu button on the remote control or TV
  • Use the Left and Right arrow buttons (Vol +/-) to select PIP/POP/PBP, and then press <Enter>
  • Use the Up and Down arrow buttons (Ch Up/Ch Down) to select PIP/POP/PBP/OFF
  • Use the Left and Right arrow buttons to select Off
If issue is still persists, please move to the next step
Reset the TV current input to its default configuration
  • Use the left and right arrow buttons to select Setup, and then press Enter/OK
  • Use the Up and Down arrow buttons to select Factory Reset, and then press Enter/OK
  • Select Current Input Setting and press Enter/OK
  • Re-check the TV functionality
Feb 19, 2014 | Dell W4201C 42 in. Plasma HDTV
My Mitsubishi WS-65809 turns on and then off after 4 seconds. I have pressed the input/enter together and got 2 and then 4 blinks. What do I need to do to fix it?
First to be sure, unplug the set from power and then plug back--this clears the error buffer. Repeat the self check:
PRESS AND HOLD "device"(input) and "menu" buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC's is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
As you can see 2,4 is vertical problem----might want to remove speaker grill, inspection plate behind it and look up front--vertical is on middle board at right front as seen from front of set.
Look for ANY tiny drops of clear liquid which damages parts and is toxic-----glycol is what I would look for first.
Nov 04, 2012 | Mitsubishi WS-65809 65" Rear Projection...
We bought a samsung tv off display and the tv is on store mode and we do not have the remote to change it.
frist turn on tv
press the menu botton
press the channel donw botton to go to setup
on setup press the volume +
press the volume botton again
press the source botton to enter in the plug and play option
press source botton and select store or home by pressing the volume botton
and then press the source botton again
after this just turn ur tv off and than on
Nov 30, 2010 | Samsung TV Remote Control
Mitsubishi Model WS 55511 was made in March of 2003. I turn it on and it goes right back off again. On the front of this TV I only have an Enter button, a menu button. an A/V Reset Button and a Device...
Device is the same as input--try the self check, when power light goes off press and hold it and menu at same time for five seconds and release.
Device means input.
Let me know error code and I will help you more than anyone else.
SD TECH
Sep 18, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Collor, the picture haven't color
Make sure the monochrome setting isn't on.
Press the menu button go down to advanced and press enter.
Go to monochrome and press enter. Make sure it is on off and press enter. Press exit.
Please note what input you are in.
If this does not resolve the issue press the menu button and scroll over to setup. Scroll down to reset and press enter. Yes enter, yes enter again.
The tv will turn off and turn back on again.
Go to the right input.
If this does not work please change the cables you are using or try another input with the same and different cables. Attach another device to the tv to see if it is also a black and white picture.
May 19, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Printer displaying paper out on on control panel
You may be able to calibrate the paper out sensor to fix the problem.
Set the printer to Offline.
Press the Enter and Line Feed keys together and hold pressed until the alarm sounds (typically 3 or 4 seconds).
You should have seen briefly displayed, Tech Access On
The display will again say Offline.
Press the Mode Key, display will show Offline Normal.
Press either Arrow key until display shows Offline Test.
Press the Forms/1 key.
Press either Arrow key until display shows Test Diag.
Press the CPI/2 key.
Press either Arrow key until display shows Diag Prnt Cal.
Press the LPI/3 key.
Press either Arrow key until display shows Pap Out.
Press Enter
Follow the instructions on the LCD display, which will advise on removing and reinserting the paper.
After you have compleated the calibration place the pritner ONLINE to exit the menu.
And finally turn the printer power off, wait ten seconds and turn the printer power on again.
If the problem still exits you may need to repalce the lower tractors or the main logic board.
Sep 11, 2009 | Tally Line Matrix T6100 Printer
Printing not clear (its so Blur)
Perform these operations:
  • Test->Diag->Clear->NVRAM
  • Test->Diag->Clear->CalData
  • Then re-calibrate the printer.
Procedures:
  1. Turn ON the Tech Access feature (hold ENTER and LINE FEED keys depressed approx. 5 seconds - until printer "beeps")
  2. Turn ON the Fault Override feature (hold ENTER and FORM FEED keys depressed approx. 5 seconds - until printer "beeps")
  3. Press the MENU key then UP Arrow to Offline - Test Menu
  4. Press ENTER then UP Arrow to Test Menu - Diag
  5. Press ENTER then UP Arrow to Diag - Calibrations
  6. Press ENTER then UP Arrow to Calibrations - Print Engine Cal
  7. Press ENTER and follow the instructions on the display
  8. Turn OFF the Fault Override feature by holding the ENTER and FORM FEED keys depressed until the printer "beeps"
  9. Turn OFF the Tech Access feature by holding the ENTER and LINE FEED keys depressed until the printer "beeps"
Mar 18, 2009 | Tally T6218 Matrix Printer
My mitsubishi ws-55809 wont turn on
Does the LED light up when you press power? have to tried to enter the self diagnostic blink code by pressing menu and input on the front of the set both in together for 8 seconds and see if the LED will blink a two digit code? If so let me know what the blink code is.
Jun 18, 2008 | Televison & Video
Mitsubishi VS-50703
To Fix TV: Press Menu then 1-7-3-0.
Make sure Initial is highlighted in yellow and press Enter.
To get additional input channels:
Press Menu/SetUp/AV Connection/Locked to Input 1: Should be on NO.
1(800)332-2119 Mitsubishi Customer Support
Apr 16, 2007 | Mitsubishi VS-50703 50" Rear Projection...
Mitsubishi WS-65413 65" Rear Projection Television Logo
283 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
